Okaaayy...now this is weird!
Old Oct 20, 2010 | 09:51 PM
GT-ER's Avatar
GT-ER
Default Okaaayy...now this is weird!
Okay, as I posted on the other thread. My damper broke off tonight and smashed my timing chain cover. This was good news for me as it's an easy repair....or is it?
My engine shut off when this happened and I thought it was kinda weird so when I get the car home, I remove the belt and push the damper to the side and ask my wife to start the car. The starter would turn the motor and it would SOUND normal...but the shaft where the damper was bolted on to ( the crank shaft? ) would not spin. WTF?
Does the damper bolt on straight to the crank shaft on these cars or to another part? If it goes straight to the crank shaft then how can the engine sound fine when starting up ( it sounds and if there is compression as it turns the motor, although it would not start ) yet the crank shaft not spin ( unless it snapped in half? ).
Any thoughts?
Old Oct 20, 2010 | 10:11 PM
GT-ER's Avatar
GT-ER
Here are two pics.
Does anyone think the crank could have snapped?
Old Oct 21, 2010 | 12:24 AM
hellsoldiers08's Avatar
hellsoldiers08
all that tq from the pullies lol
Old Oct 21, 2010 | 01:15 AM
350z006's Avatar
350z006
Wow....I've never seen that before...impressive...
It should be an easy fix to replace that damper...Its been done before for people who switch to aftermarket dampers...
Now buy my OEM damper! lol...
Or you can buy the ATI or Fluidampr dampers, depending on how much you want to overspin you blower...
Old Oct 21, 2010 | 03:14 AM
Quamen's Avatar
Quamen
When you turn the motor over it should spin.
Old Oct 21, 2010 | 03:35 AM
4SHIZZIL's Avatar
4SHIZZIL
WOW!
looks pretty rusted out in there... probably was a defeat if it was an aftermarket one. GO OEM man.
but now you know where that sound was coming from!
Old Oct 21, 2010 | 03:40 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
The crank pulley bolts onto the front of the crank. Sounds like your crank is broken. The timing chain is driven by the crank near the crank pulley as well, so depending where the break is there could be more damage.
What were the conditions leading up to this?
Old Oct 21, 2010 | 04:09 AM
Quamen's Avatar
Quamen
Originally Posted by 4SHIZZIL
WOW!
It is clearly OEM.
Old Oct 21, 2010 | 06:30 AM
GT-ER's Avatar
GT-ER
Ouch. I made a thread on the noise it was making that I could never figure out:
https://my350z.com/forum/forced-indu...i-related.html
Has anyone, EVER, snapped a crankshaft?
Old Oct 21, 2010 | 06:42 AM
phunk's Avatar
phunk
CJ Motorsports
the timing chain cover is broken around there, the front crank seal is falling out... even if the crank were fine you have a LOT of work to do. but its probably not fine...
reach down there and grab that large bolt that was going thru the middle of the crank pully... see what happens.
from your description, and based on the pictures... this is bad.
Old Oct 21, 2010 | 06:47 AM
GreenGoblin's Avatar
GreenGoblin
That doesn't look good.
Old Oct 21, 2010 | 07:28 AM
Quamen's Avatar
Quamen
Agreed. It looks like there is going to be some substaintial damage, especially if the crank snout doesn't spin when you turn it over.
Old Oct 21, 2010 | 07:41 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
If the pistons were moving but the timing chain wasnt, we have an interference engine right? uh oh
Old Oct 21, 2010 | 07:54 AM
GT-ER's Avatar
GT-ER
Well, there is no more mystery behind it. I thought the damper broke and took the timing cover with it...looks like I'm looking at it backwards. The entire engine blew and took the damper with it.
Take a look at my oil pan...anyone see a wrist pin circlip? LOL.
With the exception of the worm gear clamp that I just threw there...this was all I found. I identified parts of the girdle, piston side skirt and circlips.
I'm going to dissasemble the engine to see how the block is. I hope it's okay ( doubt it )...
Old Oct 21, 2010 | 08:01 AM
midz350's Avatar
midz350
Wow, reminded of my f***ed up engine.
Sorry to hear man and GL.
Old Oct 21, 2010 | 08:02 AM
cdoxp800's Avatar
cdoxp800
Wow Man. Sorry to see this. Never the less you can build it Faster and stronger now.
Old Oct 21, 2010 | 08:07 AM
Quamen's Avatar
Quamen
Wow. It's a stretch, but hope that you can salvage some of the motor. Chances are there are some bad valve, and some ruined combustion chambers but maybe you will get lucky.
Old Oct 21, 2010 | 08:21 AM
GT-ER's Avatar
GT-ER
I found an engine locally that has a bad bearing but the guy want just $300 for it. Sounds good?
Old Oct 21, 2010 | 09:12 AM
str8dum1's Avatar
str8dum1
what happened to all the quotes you made a thread for? Seems like after all that, you should buy one of those motors.
928M has some new advertising now. The engine buster
Good luck.
Old Oct 21, 2010 | 09:30 AM
Glex25's Avatar
Glex25
^Probably cause he needs to return a Core so he needs a good block
