Momentum turbo kit RELEASED!
Old Jan 19, 2011 | 07:52 AM
  #61
S&R Performance's Avatar
S&R Performance
Vendor - Former Vendor
that's all we're trying to say. It's a very impressive kit. We're very happy with it so far and look forward to building many more Z/G's with it.
Old Jan 19, 2011 | 08:01 AM
  #62
dbrown's Avatar
dbrown
Looks like to me that momentum just sat back and then came out with a heck of a kit.
  #63
2004Black350z's Avatar
2004Black350z
Exhaust Whore
good lord this went from interesting to typical. Im fully for SUPPORTING your shop but if you dont have the kit never tested the kit dyno etc then STFU and GTFO
Old Jan 19, 2011 | 08:15 AM
  #64
rcdash's Avatar
rcdash
Originally Posted by S&R Performance
it was only at 12psi, buddy.
12psi and just straight pump gas. It's a forged internal build but std compression.
you took my posting the graph entirely the wrong way. I was trying to show what it has already done for us. There is no attempt to skew or alter the appearance of the chart. That's the format that the Land and Sea dyno plots the chart. You can see the power curve, you can see when peak torque is hit and no matter how you etch a sketch it, the numbers don't change.
So 10.3 compression? That explains the efficiency somewhat, but that's great power at 12 psi. Congrats.
... and I would recommend just ignoring the unofficial marketing arm and muscle for PowerLab and Intense (the AZ mob) ...stretched dynograph, lol, puhleeeze.
Old Jan 19, 2011 | 08:43 AM
  #65
rh_334's Avatar
rh_334
Old Jan 19, 2011 | 08:47 AM
  #66
rcdash's Avatar
rcdash
Originally Posted by thatv35guy
And I have no problem with anyone expressing an opinion, but even opinions should have some factual basis… it’d be nice if they actually took some facts into account before they open their mouth and try and say something so matter-of-fact…
Just my opinion.
This comment is spot on. I'm sure the dynographs and 3rd party substantiation will follow but it would've been nice to have the other vendor started introduction to the kit come with a full write up with technical details on the 4 shop/track cars with dynos, etc. Perhaps that is forthcoming also...
Old Jan 19, 2011 | 08:51 AM
  #67
S&R Performance
Revised Graph
It's Std Turbo Compression. I believe they are just the 8.8:1. I'll see if i can check his build sheet but i'm pretty sure the are Turbo CP Pistons.
Look, I'm NO WAY bashing or down playing PL. I don't know anything about there kit, i've never used it. For all I know it's the Jesus Juice of turbo kits. We installed this one, we tuned this one, we drove this on. We like this one.
Old Jan 19, 2011 | 08:52 AM
  #68
Vas_Z33's Avatar
Vas_Z33
Lollll
Back on topic!
Old Jan 19, 2011 | 08:53 AM
  #69
rh_334's Avatar
rh_334
Revised Graph
Old Jan 19, 2011 | 08:57 AM
  #70
S&R Performance
Originally Posted by Vas_Z33
Lollll
Back on topic!
good call.
So here is the thing. These guys did their homework. They took their sweet time to revise any issue that came up and I applaud them for it. It's a big risk these days to come out this big with a new product for a no longer new platform and it's a good thing that they did. We feel that they will be around for quite some time and we look forward to growing with them, too.
Here are a few other shots...
Old Jan 19, 2011 | 09:39 AM
  #71
Jordan_NSI's Avatar
Jordan_NSI
Originally Posted by sloppymax
Quite a few in depth pics, videos and graph of Momentum on a G coupe.
http://www.horsepowerjunkies.com/for...d.php?t=110331
Hey guys, I just wanted to stop by and make a few notes on this documentation thread I made for Kristyn's 2005 Infiniti G35. As far as quality for a turbo kit goes, it honestly doesn't get any better than the quality standards Momentum Performance has designed and manufactured this kit with. There are literally no corners cut with this system. The same quality standards are carried all the way from the research and development, to the material quality, to the weld quality, to the components chosen. Even the packaging quality is outstanding, which is funny to say, but you'd be surprised how much of an impact that has during installation.
Speaking of installation; installation is very straight forward with this system, this can mostly be attributed to the excellent fitment of the components, and the precise step-by-step full-color instructions. Almost any gear head can figure out how to bolt a part on, but it's the tricks and tips that make that installation go flawlessly, and in a time-efficient manner.
One of my favorite parts about this kit is how perfect the base map is. We completed the installation, got some oil pressure to the turbocharger, flashed the ECU with the provided UpRev cable holding Momentum Performance's base map, and one crank later; flawless idle. We couldn't believe it. Now, a flawless idle is nice, but the proof is in the drivability and performance. Once again, we couldn't believe it. First pull on the dyno, the tune was perfect and nailed with no adjustment required. The power and torque result was exactly as stated, with an excellent delivery curve. We took the car out for a couple test drives, and once again; flawless. It's truly a perfect kit.
Now, that's my opinion on the kit, but since I'm not the end user, my opinion means little without agreement from the customer. After receiving the car when the work was completed, Kristyn gave very similar feedback. She said just cruising around, it feels like a stock vehicle as far as drivability is concerned, but when you get into it, it's obviously a night and day difference over a bolt-in VQ35DE Rev-Up. Needless to say, she's very pleased with the outcome.
Momentum Performance gets two huge thumbs up from me and everyone else at National Speed, Inc.
Bobby, Sig, Bryan and Russ are doing an excellent job pushing Momentum Performance forward in the industry. Thanks for all of the support with our first Momentum Performance turbo kit installation, gentlemen!
- Jordan Watson - National Speed, Inc.
Old Jan 19, 2011 | 09:43 AM
  #72
Jordan_NSI's Avatar
Jordan_NSI
And holy cow, Marti The One Man Party, I miss you, brotherman!
Old Jan 19, 2011 | 10:18 AM
  #73
str8dum1's Avatar
str8dum1
Send Kristyn up to raleigh for a little highway roll on fun. She'll be back looking for a 76-82mm turbo
Jordan do you guys have a mandrel bender or do you pie cut for exhausts? You guys are less than 2 hrs away and I need an exhaust made and rather support our vendors
Old Jan 19, 2011 | 10:19 AM
  #74
S&R Performance
JORDAN! dude, if i could jump through the phone and hug ya, i would! Hope you guys are doing awesome over there! I'll give you a call soon, we gotta catch up. Tell Nick that the nick name has lived on and at PRI, it was shouted from across the venue several times.
Old Jan 19, 2011 | 10:57 AM
  #75
John@z1's Avatar
John@z1
Z1 Motorsports
We just dynoed 407rwhp and 405tq. Bumped timing 2 degrees and the clutch slipped dyno showed 446tq. The 407 was the box map at 8psi. More tuning soon.
Old Jan 19, 2011 | 11:11 AM
  #76
rh_334's Avatar
rh_334
Old Jan 19, 2011 | 11:36 AM
  #77
Jordan_NSI's Avatar
Jordan_NSI
Haha! No need with this kit, we'll just do a built engine, supporting fueling and drive train modifications, and settle it out at 600whp+/-.
As to not stray too far off topic, I'll shoot you a PM on that matter. I appreciate the inquiry!
Haha, same here, Marti. We're doing great, I hope you're doing well too.
Nick responds, "yeah buddy."
Beautiful!
Old Jan 19, 2011 | 11:39 AM
  #78
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Be careful Raj the AZ Mob is calling for backup by now .
Sam
Old Jan 19, 2011 | 11:41 AM
  #79
binder's Avatar
binder
any problems with the BOV being an inch from a 1200* turbo?
Old Jan 19, 2011 | 11:42 AM
  #80
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
We can dig it.
Congrats.. very nice power band.
Sam
