revised HR Build
Old May 12, 2012 | 10:40 PM
  #421
thisishk350's Avatar
thisishk350
You should pick this up
https://my350z.com/forum/intake/5554...p-capable.html
Old Jun 8, 2012 | 09:02 AM
  #422
ace32x's Avatar
ace32x
Originally Posted by thisishk350
i dont need that though, theres a reason he isnt using it lol
Old Jun 8, 2012 | 09:04 AM
  #423
ace32x's Avatar
ace32x
update, had the car tweaked a bit yesterday had some timing pulled because it was getting a bit of knock and we played with the cam phasing.
end result have a much safer pump gas tune and with the cam phasing adjustment, ended up picking up 30 whp and 55tq. sitting at 656 and 582 now on 92 on just osiris. going to get the haltech tuned on it next week sometime and see if we can bump it a tad more with adjusting the dwell and cleaning up the spark up top a little
Old Jun 8, 2012 | 08:18 PM
  #424
Eno's Avatar
Eno
Ace you going to run both or just go to haltech?
Old Jun 8, 2012 | 09:22 PM
  #425
ace32x's Avatar
ace32x
both
Old Jun 9, 2012 | 08:18 PM
  #426
Eno's Avatar
Eno
Nice!
Old Jun 10, 2012 | 08:23 AM
  #427
Mr.Squeeze's Avatar
Mr.Squeeze
Glad to here everything is working out for you
Old Sep 10, 2012 | 08:00 AM
  #428
ace32x's Avatar
ace32x
update, the wrong slave unit i had from the twin OS was causing engine noise and tripping my CEL. so when i destroyed that imput shaft and got the correct replacement cleared all that up. no engine noise no CEL's now. We retuned the other night started with the same map that made 650/580 in 50 degree weather and dide a base run and put down 550/540 with ambiant temps in the shop at 101 degrees. after an evening of starting on fresh maps (cleared up a starting problem i was having with having to feather the gas to get it running, it now starts perfectly hot and cold with no throttle imput) it put down 640/590 on 16 psi heat soaked in 101 degree temps. pretty confident when it cools down here in a few weeks it will be over 700 easy. very happy with how the car is running now ^_^
Old Sep 11, 2012 | 08:17 AM
  #429
Mr.Squeeze's Avatar
Mr.Squeeze
Nice number's man what kind of dyno was this on?
Old Sep 11, 2012 | 11:57 AM
  #430
Nismo350z#0310's Avatar
Nismo350z#0310
None of my business but I am seriously curious. How much was the check the insurance company cut you? Sounds like you got a sweet deal man.
Old Sep 11, 2012 | 02:00 PM
  #431
ace32x's Avatar
ace32x
ended up with 9200 out of it. enough for labor to pull and install a stock long block minus depreciation of 15%. took 6 months of fighting to get that aswell, and of course they wouldnt compensate any down time or anything because of thier delay. im just happy i got anything out of it
Old Sep 12, 2012 | 08:16 AM
  #432
davboy's Avatar
davboy
You running the car off the Haltec now? And who is tuning your car now.....same place as before?
Old Sep 12, 2012 | 08:21 AM
  #433
ace32x's Avatar
ace32x
no haltech, lawrence at intec is doing the tuning
  #434
ace32x's Avatar
ace32x
i have the haltech up for sale for a great price atm actually, not using it its just sitting around. works fine i just want to hastle paying for it to be set up. cars running fine as is XD
Old Sep 12, 2012 | 08:26 AM
  #435
davboy's Avatar
davboy
Yeah its hard to mess with a car once its running well. I wanted to yank my FCON out a year ago, but then I found a guy locally that can tune it. He cleaned the tune up and now it runs so much better...he even asked me who the hell tuned the car before because they didn't set the FCON or the knock amp up very well.
Old Sep 12, 2012 | 08:32 AM
  #436
ace32x's Avatar
ace32x
o nice man! good to hear its cleaned up and running better, and yea lots of the shops dont seem to set up that knock amp very well it seems
Old Sep 12, 2012 | 06:12 PM
  #437
jomamahama's Avatar
jomamahama
who built your block an ITNKICN's block? I've been lurking both threads but they are getting too long to keep straight!
Old Sep 12, 2012 | 08:52 PM
  #438
ace32x's Avatar
ace32x
Intec racing
Old Sep 13, 2012 | 06:40 AM
  #439
350zhp306's Avatar
350zhp306
Are you still experiencing CEL p0300? If not what did you do to resolve it?
Old Sep 13, 2012 | 07:41 AM
  #440
ace32x's Avatar
ace32x
no we cleared it up, when i broke my imput shaft and swapped transmissions and got the correct csc unit (my old one was to small and wasnt fully engaging or disengaging apparently) it went away and idled way odly enough.
