Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement
Old Sep 20, 2013 | 11:39 AM
  #341
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Up for a Friday
Chris
Old Sep 23, 2013 | 11:20 AM
  #342
Dynosty's Avatar
Dynosty
In stock!
Chris
Old Sep 22, 2014 | 06:26 PM
  #343
murphys_law's Avatar
murphys_law
So I know this thread hasn't been bumped in a year, but I'm curious about the revup EVT functionality. Any updates?
Old Sep 29, 2014 | 12:17 AM
  #344
_Dolle_'s Avatar
_Dolle_
Sell your Haltech and buy AEM Infinity-8.
Like I did
Problem solved
Old Sep 29, 2014 | 07:28 AM
  #345
murphys_law
Like I did
Problem solved
Sucks to hear that, but it seems that may be the only way to get reliable timing on both sets of cams.
Old Feb 18, 2016 | 11:27 AM
  #346
aln's Avatar
aln
Have Revup and my EVT is working, was a lot of to and from to get it to work, I don't have the ins and outs of it but wasn't easy but now its been working great
Anyone with a red Haltech sitting on this document somewhere? The original URL has stopped working and don't seem to find the one I saved off
"Haltech Wideband to Platinum Wiring Instructions by IP.pdf"
Old Feb 19, 2016 | 01:17 PM
  #347
rcdash's Avatar
rcdash
Google says this should work:
https://www.google.com/url?sa=t&rct=...fbIKQ8ZRfxwqBA
Old Feb 19, 2016 | 01:28 PM
  #348
aln's Avatar
aln
Thanks but that doesn't sound correct
Originally Posted by rcdash
Old Mar 9, 2016 | 05:31 PM
  #349
35reilly's Avatar
35reilly
So I just spent the last 2 hrs reading this from start to finish. I really have been thinking of going with the full standalone. I'm not a tuner AT ALL! But I'm doing everything in my power to learn and understand this. I'm running Osiris now but What is going on with the EVT? Is this a issues on the rev-up? Can you pass odb2 inspection? Im in NJ and they are *******!!!! Even have cameras you drive over to see what's under the car. ( cats ). Idk I have ways of getting inspection I'm really not worry about that. I'm concerned with the issues I'm reading about with the EVT. Anyone elaborate more?
Old Mar 10, 2016 | 04:24 AM
  #350
rcdash's Avatar
rcdash
As far as I know the Haltech can control the exhaust cams just fine in a rev up using the latest firmware. You can contact Hal @ Dynosty for confirmation. You will not regret the full standalone. The engine protection and flexibility of the numerous 2D maps is amazing.
A few of the more unique capabilities vs UpRev: ignition retard based on wheel slip vs MAP and VDC status (more traction control with VDC on), target boost by gear and rpm and fuel composition (E85 vs 93 octane), vacuum actuated exhaust cuts outs controlled by throttle and MAP, shift light blink frequency based on approach to rev limit, anti-lag launch activation with clutch fully depressed and mph < 2 and throttle > 50%, fuel compensation if differential pressure drops during boost, many "safe mode" triggers, such as lean tip in, injector fuel differential pressure drop, high oil temp, etc.
You can download the software for free and play with the base map to get a better idea.
Old Mar 10, 2016 | 04:30 AM
  #351
35reilly's Avatar
35reilly
Thxs man. I'm gonna call him today
Old Mar 10, 2016 | 09:03 AM
  #352
35reilly's Avatar
35reilly
Has it been confirmed that you can pass obd2 inspection?
Old Mar 10, 2016 | 06:28 PM
  #353
dikspiel's Avatar
dikspiel
Chestons Toilet
I don't think so
Old Apr 2, 2016 | 09:04 PM
  #354
Boosted Performance's Avatar
Boosted Performance
Anybody have issues with ECU to laptop connection? I haven't had my laptop connected to the Haltech (old red box) for well over a year...needed to look at some A/F data, and I get the "ECU could not be found" error. I had the 1.6 firmware version, but it all worked last time I needed it.
So I went on the Haltech website, downloaded all the latest firmware, and still get the same error. The ECU is just not being detected.
Checked the USB cable, and I have good continuity on all leads. Took the Haltech apart as well to check the USB connection port on the board, and all is good.
This is the most active Haltech thread here, so I thought I ask.
Old Apr 3, 2016 | 02:37 PM
  #355
rcdash's Avatar
rcdash
I have had trouble with certain cables and when using a hub. If a second cable does not work then you may have to send in.
Old Apr 3, 2016 | 04:19 PM
  #356
Cux350z's Avatar
Cux350z
hatersgonnahate
make sure windows is recognizing the haltech when you plug in and go to hardware manager to verify. Possible that a windows update screwed something up.
what windows are you using?
Old Apr 3, 2016 | 04:54 PM
  #357
Boosted Performance
Thanks for the tips gentlemen....ended up getting another laptop, downloaded software V 1.13.5, and it worked on only one of the USB ports (out of 3).
My firmware on the ECU is still 1.06, and it doesn't look like it wants to take the update.
Old Apr 4, 2016 | 04:46 PM
  #358
Cux350z's Avatar
Cux350z
hatersgonnahate
I would try your best to update. Haltech had some serious bug fixes along the way
Old Jul 25, 2016 | 12:23 PM
  #359
350z-900whp's Avatar
350z-900whp
Guys I need help on how to run multiple maps on haltech pro plug in harness. I know the ecu it self don't have this feature.
So my question is their any external product I can add to run multiple maps on fly for haltech?
Say I want to run map 1 : 15 psi , map2: 19psi , map 24+ psi on c16. Is it possible? Without going back to my laptop to load the map
Thanks
Old Jul 25, 2016 | 01:57 PM
  #360
Cux350z's Avatar
Cux350z
hatersgonnahate
Not really
you can use haltech to control boost and a trim pot to limit its output to the WG
it can detect E85 and adjust for that, but c16 not really.
