View Poll Results: Greddy Install, pull engine or not
Pull Engine
44
95.65%
Leave In
4.35%
Voters: 46. You may not vote on this poll
Greddy Install...engine in or out?
Old Dec 24, 2014 | 11:28 AM
  #101
taywan's Avatar
taywan
Can't remeber some things, it's easier to pull with or without tranny? I'll be yanking mine for built swap within a couple weeks
Old Dec 24, 2014 | 11:58 AM
  #102
phunk2's Avatar
phunk2
why is your engine bay so clean? geez
Old Dec 24, 2014 | 11:59 AM
  #103
phunk2's Avatar
phunk2
If you are going out the top, trans has to be off. If you are going out the bottom or front, no reason to bother taking the trans off in the car.
Old Dec 24, 2014 | 02:16 PM
  #104
taywan's Avatar
taywan
It'll be on jack stands and Diy garage deal
Old Dec 24, 2014 | 02:25 PM
  #105
phunk2's Avatar
phunk2
same procedure
Old Dec 24, 2014 | 03:10 PM
  #106
bealljk's Avatar
bealljk
Atta-boy OP!
Old Dec 24, 2014 | 04:33 PM
  #107
Escobar's Avatar
Escobar
I know right! I was amazed how clean it stayed after 11 years...i rarely drive it in the rain so I guess thats why.
  #108
Escobar's Avatar
Escobar
Originally Posted by bealljk
Atta-boy OP!
Old Dec 24, 2014 | 04:36 PM
  #109
Escobar's Avatar
Escobar
just take your time, pull off the front stuff and start disconnecting everything. Leave the tranny bolted up and yank it out. I disconnected the power steering hard lines running across the front crossmember or they would have got crushed. Get a good 6 point "flare nut wrench" 12mm for them. They are tight. I ran out of time but ill post more pics as I get everything organized.
Old Dec 28, 2014 | 11:30 AM
  #110
Escobar's Avatar
Escobar
got the engine on the stand. so far so good. As far as the power steering fitting, Im about to send my stuff off to the welder, how did you guys re position this thing to be after you cut and weld it? Can you post some pics?
Attached Thumbnails Greddy Install...engine in or out?-img_4765.jpg   Greddy Install...engine in or out?-img_4773.jpg
Old Dec 28, 2014 | 04:11 PM
  #111
bealljk's Avatar
bealljk
I put mine in a vice and bent it back about 15 to 20 degrees...I'll see if I can get a few pictures...
Old Dec 28, 2014 | 04:15 PM
  #112
Escobar's Avatar
Escobar
that would be great. thanks
Old Jan 5, 2015 | 01:37 PM
  #113
Escobar's Avatar
Escobar
does anyone know where I can get one of these gaskets? its 2" (50mm ) diameter opening. It goes on the turbo where the down pipe bolts up.
Old Jan 5, 2015 | 05:08 PM
  #114
phunk2's Avatar
phunk2
Those are mostly proprietary to Greddy, never seen anyone else use them. The good news is they will out last your car. Just scrub them off with scotchbrite and reuse them.
Old Jan 5, 2015 | 05:36 PM
  #115
Escobar's Avatar
Escobar
so I have to get them from greddy direct? damn...$20 a piece. I see what your saying, they are tough. I cleaned up the other ones I have. They look like new!
Old Jan 6, 2015 | 12:40 PM
  #116
kilogram's Avatar
kilogram
Kamak sells gasket kits for MHI/greddy turbos ($9.50):
http://shopping.kinugawaturbo.com/gasketkis.aspx
They also sell all kinds of upgrade stuff, better thrust bearings (similar to Holset), billet bolt-in compressors, etc.
Old Jan 6, 2015 | 05:57 PM
  #117
Escobar's Avatar
Escobar
damn wish you could have posted that earlier. got it from greddy...$20 plus $16 to ship!
Old Jan 6, 2015 | 07:54 PM
  #118
phunk2's Avatar
phunk2
They are just stainless shims, they have no stopper beads or anything like that... nothing wears out. A cleaning is all they need, I have reused them several times over for years, never had a leak.
Old Jan 7, 2015 | 12:18 PM
  #119
Escobar's Avatar
Escobar
sweet. I was missing one so I really didnt have a choice. Pisses me off these companies that charge as much for shipping as the part costs.
Old Jan 7, 2015 | 01:05 PM
  #120
phunk2's Avatar
phunk2
Oh that makes sense then. You would be surprised what shipping costs. Only USPS is inexpensive but they are extremely inconvenient to deal with for the shipper. We only use USPS for international because the cost savings is extreme... but for stuff inside the US we try to avoid it because its a hassle. Residential delivery through FedEx and UPS has gone way up the last few years and I would expect around $12-13 or so to ship a small box with that gasket to your house. $7-8 for commercial address. Then you have the fact that the website shipping calculators are never dead on, gives you a few bucks of error right there.
