vortech/stock block let go...so *knock on wood, reliable build thread ;-)
Old Nov 21, 2015 | 03:39 PM
  #361
Colombo's Avatar
Looks like #2 cylinder is reading 40psi low.
Old Nov 22, 2015 | 04:16 AM
  #362
Classy's Avatar
Classy
Old Nov 22, 2015 | 06:14 AM
  #363
Colombo's Avatar
Originally Posted by Classy
It's a realistic option. I may pull motor fix piston, sell motor and blower plus all my extras and do the jump to the LS world
Old Nov 22, 2015 | 02:04 PM
  #364
Classy's Avatar
Classy
Could make 600+ rwhp on motor if that is the route you wanna go. Or go big and boost it
Old Nov 24, 2015 | 03:48 PM
  #365
Colombo's Avatar
Blower setup is up for sale in the private classified friends 👌🏽
Old Nov 25, 2015 | 02:14 PM
  #366
Classy's Avatar
Classy
Are you going for it bro?!?
Old Dec 2, 2015 | 04:44 PM
  #367
Colombo's Avatar
Motor is pulled apart in the garage. Found 3/6 upper piston rings broken and 1 cylinder took some scaring. Will be dropping the block of to see if the scaring can be cleaned up. This motor is already .020 over not 100 percent yet but I may go .040 over or just get another block, do the HR cooling mod and punch that 1 to .020 over. I'm more than likely keeping the Vq unless some
One picks up this blower before I get it back together. I'm neither here nor there. Either will make me happy. LS or this motor rebuilt
Old Dec 3, 2015 | 05:12 AM
  #368
DmanG281's Avatar
DmanG281
Get her back together man! Really, its so I don't have to consider buying the blower from you. After seeing this car in Dixie last year I am certainly keen to it. (Dustin with the Blue and Grey Z that ran with you in SSM.)
On a side note, I am in the Orlando area now. Where do you autocross in Central Fla?
Old Dec 3, 2015 | 08:24 AM
  #369
Colombo's Avatar
I live in Texas now. But if your in central Florida there is events with the FAST organization as well as a few others in that area.
Old Dec 3, 2015 | 11:39 PM
  #370
Resmarted's Avatar
Resmarted
Hey colombo, I was curious, what are the condition of your main bearings? Especially the front ones? I hear more and more about belt tension causing extra wear on mains, and all that kind of jazz. And how many boosted miles did you have roughly? Just curious, you can pm me if you want.
They look ok in the pics but, what's the first hand consensus.
It looks like you have wiseco pistons too? Yeah I think you could get away with running one bore a bit looser than the rest.
Old Dec 4, 2015 | 03:58 AM
  #371
Colombo's Avatar
I got roughly 4K track/hard driving miles on this motor. Everything inside still looks brand new. All main bearings look new still. Not a scratch on them really. Revving to 7600. I run the fluidampr maybe it helps maybe it didn't but my bearings, All of them look great
Old Dec 4, 2015 | 03:59 AM
  #372
Colombo's Avatar
And it should be noted that I'm on factory main bolts not Arp
Old Dec 4, 2015 | 02:00 PM
  #373
Resmarted's Avatar
Resmarted
Upgrade those suckers this time and rev your heart out
Old Dec 7, 2015 | 11:51 AM
  #374
OldManZ350's Avatar
OldManZ350
You got some hot spots on the 3rd main back from the front in you pic.
Old Dec 7, 2015 | 02:22 PM
  #375
Colombo's Avatar
Tim that's oil sitting in them. They all basically look brand new
Old Dec 7, 2015 | 03:16 PM
  #376
OldManZ350's Avatar
OldManZ350
That's Good!
Old Dec 11, 2015 | 04:36 PM
  #377
Colombo's Avatar
Little update. Jon from z1 sold me his spare block for dirt cheap. So I'll be building a separate block slowly in the future. I'll be using his block punched to .020 over and I ordered some JE Pistons at 96mm 10.0:1 comp. will be dropping off the block to have the HR mod done and punching it out. Should be able to start putting it all back together within the end of the month
Old Dec 12, 2015 | 03:21 AM
  #378
taywan's Avatar
taywan
why does the sheet say 4.5 v8 ?
Old Dec 12, 2015 | 04:01 AM
  #379
Classy's Avatar
Classy
Should make a VQ70 V12
Old Dec 13, 2015 | 01:41 AM
  #380
Resmarted's Avatar
Resmarted
Ive honestly thought about doing something like this.
Grafting two blocks together... its been done before.... but the heads.... and paying for a billet version and custom cams... and the crank....
It would be awesome if you could bolt the cranks together
