Supercharger Dyno Numbers
Old Feb 28, 2017 | 04:58 AM
  #121
4SHIZZIL's Avatar
4SHIZZIL
Nice, I wonder if it compares to the old TTRIM I had.
Well done my friend, we'll done in deed!
Old Feb 28, 2017 | 05:00 AM
  #122
4SHIZZIL's Avatar
4SHIZZIL
Originally Posted by meanz
Technically i was at 580/490. I'll dig up a dyno
I'll update. No reason to lie here. We would hunt you down and leave your car on Jacks. Lol
I kiiiiiid I kiiiiid
Old Apr 27, 2017 | 10:29 AM
  #123
philthethrill's Avatar
philthethrill
Made 580 on e85. Will post dyno soon. I dont understand how i made such low numbers. Iys inna dyno jet. I was makimg max power at 17psi and msx psi at 21. Power fell of after 6200rpm
Old Apr 27, 2017 | 10:35 AM
  #124
philthethrill
Here ya go
Old Apr 28, 2017 | 06:24 PM
  #125
2bad240's Avatar
2bad240
What pulleys and cogs
Old Apr 28, 2017 | 08:45 PM
  #126
OldManZ350's Avatar
OldManZ350
Yep, same question.
Old Apr 29, 2017 | 07:43 AM
  #127
philthethrill
34/28 cog 2.87 serp, fluid dampr
Old Apr 29, 2017 | 01:13 PM
  #128
0taku's Avatar
0taku
Cams? Headers?
I'm running the 2.87/Fluidampr/34/28 as well. I have stock heads and headers. but I'm choking at 10psi.
494whp/403ftlb 11:1 comp on E85 @ 10psi.
Old Apr 29, 2017 | 02:37 PM
  #129
craig12895's Avatar
craig12895
I don't understand how you are stuck at 10psi. Thats crazy low. I have the 2.87, 34/28, stock crank pulley and I hit 14psi.
Something is really holding your car back
Old Apr 29, 2017 | 05:11 PM
  #130
philthethrill
I have tomei headers,and as i was explained by old man the lack of cams is killin me.i max out at 17 psi with power although i produce 21lbs. If i had cams and head work im sure id be seeing 700whp.
Old Apr 29, 2017 | 05:13 PM
  #131
philthethrill
Originally Posted by 0taku
Cams? Headers?
What exhaust
Old Apr 30, 2017 | 06:29 PM
  #132
OldManZ350's Avatar
OldManZ350
You are NOT Choking at 10psi, something else is going on.
Also, no way you're making 500whp with only 10psi
Post your Boost Log.
What are the Detail of your Build?
Cams? Headers?
Old Apr 30, 2017 | 06:35 PM
  #133
OldManZ350's Avatar
OldManZ350
But, their is something else going on, causing your Power to fall off so early.
You do not seam to have any belt slip in your dyno.
Old Apr 30, 2017 | 07:25 PM
  #134
philthethrill
Is it ppssible.my blower is hurt maybe bearing problem.since im spinning it so hard..
Old Apr 30, 2017 | 07:51 PM
  #135
OldManZ350's Avatar
OldManZ350
Anything is possable.....
This is why I want to see your Air Filter setup.
But your boost is climb like it should, so wait until your done at the tuners.
Old May 1, 2017 | 11:07 AM
  #136
philthethrill
Wide band sensors should be thrre by 3, im having him remove my filter and do a pull so will see if thats a restriction. I have a pipe running from chraher inlet under my fender with a huge k@n tho. Will see
Old May 1, 2017 | 06:07 PM
  #137
BluestreamDE's Avatar
BluestreamDE
The oem K&N filter for the Vortech is VEERY restrictive. I use a Turbo Guard which is a grill mesh and silocone over the inlet of the blower. Just 50 bucks.
Old May 1, 2017 | 06:46 PM
  #138
philthethrill
Might go that route we shall see what dyno looks like with filter off. I do not have the stock vortech. I have a elboe off the chsrger going behing my wheel with the biggest cone filter you can get
Old May 2, 2017 | 06:02 AM
  #139
350z006's Avatar
350z006
Interesting...I just looked at the Turbo Guard website for my blower...are you using the regular Turbo Guard or the Turbo Guard Maxx?
They don't seems to recommend the regular Turbo Guard for superchargers, but I'm not sure why....
Old May 2, 2017 | 08:18 PM
  #140
BluestreamDE
I have the Original mesh design. Should not be an issue with the MAXX or Chrome style. Since you have a Ysi I would suggest the MAXX anyway since you could pull in the mesh and damage your impeller if the screen came loose.
