Procharged G35
Old Sep 3, 2014 | 06:04 PM
  #41
Conway_160's Avatar
Conway_160
So I brought the car home and one of my charge pipes came off so I coudnt get any boost action. Once I got my charge pipe put back on took the car out for a quick spin. All I can say is OMFG and thats shifting at 5k cant wait to get it 100% done.
Old Sep 5, 2014 | 03:39 PM
  #42
2bad240's Avatar
2bad240
I need to check my small pulley and see what it is. My big one is 39. I don't have a boost gauge so I don't know what it's making yet.
Old Sep 5, 2014 | 04:46 PM
  #43
Conway_160's Avatar
Conway_160
Well the car is not loving me right now, Went to close the sunroof last night and heard some grinding so did some reading and thought it just needed a reset so reset it and heard alot more and so i took the glass out of my sunroof and found alot of broken plastic. So now i need a new Sunroof and not to mention BOTH of my windows are starting to act up so may need to replace both of them...
Old Sep 6, 2014 | 05:15 PM
  #44
Conway_160's Avatar
Conway_160
Well now im eating serpentine belts...will have to call monday and see if procharger will look at my bracket and pulleys to see if they are messed up.
Old Sep 6, 2014 | 07:58 PM
  #45
jdm-v35's Avatar
jdm-v35
the top pulley(largest on procharger bracket) doesn't look like its pushed all the way on. Also i saw youve had difficulty changing pulleys. The secret to it I learned is to used a torch to heat the center of the pulley and since its aluminum will expand faster than the steel drive shaft. It will go on and off a lot easier when heated, and if not sometimes just needs a good tap from a hammer cushioned by a piece of wood. This also applies to vortech when I had my v2 on my old maxima.
Old Sep 18, 2014 | 05:28 AM
  #46
Conway_160's Avatar
Conway_160
Well lesson of the day is a very expensive one,"Remove the steel bracket under the IVT
Solenoid on the driver’s side next to the dipstick." After completing this step for the somehow the bolt never got reinstalled that actually holds the IVT into place. So on the dyno yesterday this came loose and i lost about 1/2 of oil and now my motor is seized. As soon as i get the car home today ill drain the oil and see if there is any metal shavings in the oil.
Old Sep 18, 2014 | 05:43 AM
  #47
eZg's Avatar
eZg
Damn......sorry Man.
Sounds like you got the skilz to rebuild if you need to.
Good Luck!
Old Sep 18, 2014 | 08:04 AM
  #48
meanz's Avatar
meanz
Wow this sucks.
Old Sep 18, 2014 | 08:26 AM
  #49
Conway_160's Avatar
Conway_160
Well thecar is back in my garage, time to find a borescope to look in the cylinders.
Old Sep 18, 2014 | 10:11 AM
  #50
Conway_160's Avatar
Conway_160
Metal shavings in the oil so time to start building the spare block.
Old Sep 18, 2014 | 05:58 PM
  #51
bealljk's Avatar
bealljk
the journey is the reward...
Old Sep 18, 2014 | 09:18 PM
  #52
Conway_160's Avatar
Conway_160
I'm now trying to decide if I want buy a stage 1 block or if I want to get the stage 3 rebuild kit and take it to a local engine builder.
Old Sep 20, 2014 | 11:06 AM
  #53
Conway_160's Avatar
Conway_160
Started the tear down of my original block to see how bad the cylinder walls are.
Didnt accomplish much, just got the acessorys off and the timing cover. Will do some reading tonight would like to get the motor completely disassembled tomorrow.
Old Sep 21, 2014 | 10:58 AM
  #54
Conway_160's Avatar
Conway_160
Well didn't get much more accomplished, apprently i need to add some more tools to the tool collection.
Damn Cam Shaft Bolts were a pain in the *** to get out, took two of us to break them free.
Back timing chain cover removed.
Removed the lower intake runners.
Need to go buy 10MM and 8MM allen key to get these bastards out, using my allen set and a breaker bar wasn't working.
Old Sep 21, 2014 | 12:48 PM
  #55
bealljk's Avatar
bealljk
one of my better tool purchases have been metic 3/8" drive hex sockets.
Old Sep 21, 2014 | 04:39 PM
  #56
2bad240's Avatar
2bad240
Just got my new engine in this weekend. Interested to see what it will do with the stock 7# pulleys
Old Sep 21, 2014 | 04:42 PM
  #57
Conway_160's Avatar
Conway_160
I just picked some up, lol
Old Sep 21, 2014 | 04:47 PM
  #58
Conway_160's Avatar
Conway_160
Well when I maxed out my injectors I hit 10psi and made 355. Then whem i go. t the new injectors i hit 12psi and made 365. But on the next pull is when the motor locked up so i think those numbers are erroneous. Side note timing was not messed with for those pulls and im at3175 ft above sea level.
Old Sep 21, 2014 | 06:57 PM
  #59
djamps's Avatar
djamps
Looks kinda like the motor was an oil burner to begin with (or at least ran very low at some point in the past), the heads are quite brown. Way more than my 140k mi greddy Z's are at least.
Old Sep 21, 2014 | 06:59 PM
  #60
Conway_160's Avatar
Conway_160
This motor was a oil burner thats why it was replaced.
