Procharged G35
Old Jan 19, 2015 | 02:26 PM
  #81
2bad240's Avatar
2bad240
I'm running stock crank pulley. But I'm running 44/22 pulleys. How many rpm is that at 8000?
Old Jan 19, 2015 | 02:30 PM
  #82
2bad240's Avatar
2bad240
Edit 43/23 I think.
Old Jan 19, 2015 | 03:54 PM
  #83
Conway_160's Avatar
Conway_160
Dang if you really rev to 8000 you are spinning your blower to 97,987 RPMs. How much boost are you hitting?
Old Jan 19, 2015 | 04:06 PM
  #84
2bad240's Avatar
2bad240
Yea I rev to 8000. I'm hitting 17psi
Old Jan 19, 2015 | 04:20 PM
  #85
Conway_160's Avatar
Conway_160
How much power you making? I think im going to be disappointed in the end of this build..
Old Jan 19, 2015 | 04:24 PM
  #86
2bad240's Avatar
2bad240
No clue with high boost. Just finished my return fuel system and I need bigger injectors. My 750s are maxed out bad. I'm looking for close to 600.
It made 400 on 7psi with very little tuning with maxed out stock maf and the 2.5" piping and old exhaust.
Old Jan 19, 2015 | 04:38 PM
  #87
Conway_160's Avatar
Conway_160
Ok, that makes me feel a lot better. I'm hoping for somewhere between 500-550. Even though it looks like that's way possible with a stock block now...
Old Jan 20, 2015 | 05:02 AM
  #88
jdm-v35's Avatar
jdm-v35
Im also debating on overspinning my procharger but not sure how "safe" it is. I currently also have 42/24 pulleys and OEM crank, debating on going with fluidampr and 43/23 but keeping rev limit at 6400. 2bad240 have you actually spun it that high already? or is that theoretical and you haven't actually done it yet?
Old Jan 20, 2015 | 02:49 PM
  #89
2bad240's Avatar
2bad240
http://youtu.be/EJn1kCyIdaY
Old Jan 20, 2015 | 03:05 PM
  #90
Conway_160's Avatar
Conway_160
Damn! what oil pump do you have?
Old Jan 20, 2015 | 03:41 PM
  #91
2bad240's Avatar
2bad240
Revup
Old Jan 20, 2015 | 03:43 PM
  #92
Conway_160's Avatar
Conway_160
Revup
Well that awesome, what is your build set up? I was looking to see if I could find it but never found it.
Old Jan 20, 2015 | 03:54 PM
  #93
2bad240's Avatar
2bad240
It's nothing crazy. Eagle rods. 11:1 weisco pistons. Acl bearings. Tomei 272 11.3i 11.0e cams. Tomei valve springs. Ppe longtubes. Tomei expreme ti exhaust. kinetix velocity manifold.
Old Jan 20, 2015 | 03:56 PM
  #94
2bad240's Avatar
2bad240
Old Jan 20, 2015 | 04:23 PM
  #95
Conway_160's Avatar
Conway_160
Looks good, are you shredding belts?
Old Jan 20, 2015 | 04:27 PM
  #96
2bad240's Avatar
2bad240
Not since I started running it loose. Procharger said the reason it was shredding before is because the belt was to tight and it was stretching under the torque and shredding.
http://youtu.be/i3MajYdA99A
Old Jan 20, 2015 | 04:39 PM
  #97
Conway_160's Avatar
Conway_160
Thats interesting, how tight is your back belt?
Old Jan 20, 2015 | 04:42 PM
  #98
2bad240's Avatar
2bad240
The serpentine belt is as tight as it can go. The back belt on the blower isnt super tight but I havnt had any issues with it at all.
Old Jan 20, 2015 | 05:03 PM
  #99
Conway_160's Avatar
Conway_160
I WANT MY CAR RUNNING! ill be coming to you for anwsers good sir
Old Jan 20, 2015 | 06:14 PM
  #100
Danoman32's Avatar
Danoman32
Damn, your running 11:1 comp on a boosted motor?
