Budget Single Turbo Build! High mileage
Old Dec 2, 2014 | 08:53 PM
  #41
le mans sunsetz's Avatar
le mans sunsetz
Originally Posted by z33_cliff
have you thought about a clutch yet? You'll find out real quick that one thats worn out will let go around 3-4psi ... thats what happened to me at least when I finished my twin turbo install and thought the stock clutch would get me by for a while at low boost but after a few weeks it would slip once it seen boost in the 3-4psi range. for cheap I'd go with a southbend DXD, I have a JWT with a cheap chromoly flywheel and I "think" its slipping after being on it for about a year at 8-9psi
I've thought about it. Something I will change as it goes. Just had a new oem clutch put in 3,000 miles ago. So might as well use it. Hopefully it will hold for a good time. I want a daily driven clutch and flywheel. It's funny riding in my friends evo after his aftermarket clutch and flywheel. Clunk.. Clunk ... Clunk. Catch lol
Old Dec 3, 2014 | 04:52 AM
  #42
jdepe's Avatar
jdepe
my original oem stock clutch/flywheel. with 76k miles held 494whp/444tq @10psi for 30k miles and is still holding great. you should be good with that new clutch as long as you're not dumping it all the time.
Old Dec 4, 2014 | 07:56 AM
  #43
le mans sunsetz
Probably more work today
Old Dec 4, 2014 | 10:23 AM
  #44
le mans sunsetz
Okay guys. My goal for the day is to clock the turbo to the right direction. Mount the turbo, run the exhaust all the way back from the turbo. Start figuring out how the intercooler will be mounted. Possibly mount the intercooler
Old Dec 4, 2014 | 10:24 AM
  #45
le mans sunsetz
Depending how long that takes I will start the ic piping. Guys any tips on where to run the id hoses from bov and wastegate. Never done a turbo install before.
Old Dec 4, 2014 | 12:57 PM
  #46
iideadeyeii's Avatar
iideadeyeii
http://www.racetep.com/tnetic/60130_revC.pdf
Old Dec 4, 2014 | 05:13 PM
  #47
le mans sunsetz
Originally Posted by iideadeyeii
Old Dec 7, 2014 | 03:39 PM
  #48
le mans sunsetz
Got the turbo clocked and mounted for good. Took a while to mount as it had to be clocked perfectly to clear either side. It's a tighter fit than I imagined. Haven't been able to get much work done because of finals and work. Z has been feeling neglected and I will hopefully get a night where I can just wrench on it for 6 hours and get the rest done in one day.
Old Dec 7, 2014 | 05:41 PM
  #49
taywan's Avatar
taywan
You can grab an oil pan spacer that has the oil feed and return ports pre tapped also. I have one..
Old Dec 7, 2014 | 06:11 PM
  #50
craig12895's Avatar
craig12895
What kind do you have? Does somebody make one that is the whole pan that has the holes pre tapped rather than just a spacer?
Old Dec 7, 2014 | 07:40 PM
  #51
le mans sunsetz
Is an oil pan spacer a must?
Old Dec 7, 2014 | 08:20 PM
  #52
bealljk's Avatar
bealljk
No, but you (obviously) need to give your turbo a port to drain back into the oil pan.
Old Dec 7, 2014 | 09:07 PM
  #53
terrasmak's Avatar
I highly doubt you can get feed oil off the oil pan, just return.
Old Dec 8, 2014 | 02:57 AM
  #54
taywan's Avatar
taywan
Old Dec 8, 2014 | 10:32 AM
  #55
jdepe's Avatar
jdepe
you can run the oil feed from where the oil pressure sensor is with a "T". and use the oil pan spacer with pre-threaded ports from JWT, Z1, etc. for the oil return line. so you don't have to drill into your upper oil pan.
Old Dec 8, 2014 | 11:02 AM
  #56
iideadeyeii
If I went back and did mine over I would have drilled into my upper oil pan and saved myself the $100. (or whatever it cost)
Old Dec 12, 2014 | 08:22 AM
  #57
kilogram's Avatar
kilogram
Originally Posted by jdepe
you can run the oil feed from where the oil pressure sensor is with a "T"..
It's worth mentioning that oil from this port is unfiltered.
Phunk mentioned another port just above that one that taps the filtered side of the oil system. See: https://my350z.com/forum/forced-indu...l#post10465034
Turbos do not like dirty oil, and it's worth the time/effort to tap a filtered supply. It always surprised me how many turbo failures I heard about on Z33s until I realized that they're almost all supplying the turbo with unfiltered oil.
Update: engine already blew up because I ordered a godspeed intercooler. Lol jk
This is the sort of post you hold onto until April 1st, then watch the haters come in and make idiots of themselves.
Old Dec 12, 2014 | 07:41 PM
  #58
jdepe's Avatar
jdepe
Thanks! i honestly never knew that. That was how the setup was on my Boosted performance kit.
Old Dec 12, 2014 | 07:52 PM
  #59
jdepe's Avatar
jdepe
From that filtered port, you can run a 90 degree fitting to your oil line so it doesn't interfere with the belts.
Old Dec 14, 2014 | 01:49 AM
  #60
Resmarted's Avatar
Resmarted
Food for thought. Not EVERYONE has blown turbos.
And also food for thought, how many people have spun bearings? How many people don't change their oil as often as they should, especially on a turbo Z?
