HKS GTS8555 Supercharger?
Old Nov 15, 2018 | 08:53 AM
  #81
onevq35de's Avatar
onevq35de
What about Vortec's site for calculations?
107k rpm could be brought down with a Fluidampr crank pulley.
Old Nov 15, 2018 | 11:05 AM
  #82
Chinky4U's Avatar
Chinky4U
I input the numbers from above into the vortech calculator and did the v2/v3 impeller speed. Unless I'm doing something wrong here, it comes out a very low number?
ATI (6.610") + 120mm Pulley (4.724") + 7500RPM Redline: 41,207.57rpm
Fluidampr (6.120") + 110mm Pulley (4.331") + 7500RPM Redline: 38,152.85rpm
Uuuuuuuhhhh what am I doing wrong here?!
Old Nov 15, 2018 | 11:08 AM
  #83
onevq35de's Avatar
onevq35de
That could be right. I might be mistaken but I think the only two available pulleys, at least the only two worth considering are the 100 and 110 mm. 120 would probably reflect what the original HKS V1 put out.
It's been awhile since I used that calculator but you might have the pulley sizes in the wrong spots?
Old Nov 15, 2018 | 12:28 PM
  #84
Chinky4U's Avatar
Chinky4U
I thought so too but apparently not. -sighs-
Well, we already know what I'll do. I'm going to just take it easy on the 110 with the ati. It just seems more logical to me.
Old Nov 15, 2018 | 02:39 PM
  #85
onevq35de's Avatar
onevq35de
I'd be looking to get the compressors rpm up as high as possible mechanically and accommodate the threshold of 100k by reducing the the rev limiter. Safer for the engine and the compressor.
Old Nov 15, 2018 | 04:20 PM
  #86
Conway_160's Avatar
Conway_160
Maybe my math sucks but if that blower can't handle 1.07% more rpms than the 100k reccomened you should get a new blower.
besides that how often are you really going to spin it to 7500?
Old Nov 15, 2018 | 04:29 PM
  #87
onevq35de's Avatar
onevq35de
Consider the difference between superchargers. 60k for a Vortech and 100k for the HKS. That's a big f'n difference.
107,000 is 7% above the supposed limit. 7% over the Vortech equivalent is 4,200.
The HKS cannot easily and readily be replaced like a Vortech where we have Vortech and various other supercharger rebuilding companies. I've read through a long forum with BRZ's and the issues guys were having with these HKS units. We're talking about months before you get your **** back from HKS in Japan.
Old Nov 16, 2018 | 02:42 AM
  #88
BluestreamDE's Avatar
BluestreamDE
Im gonna say your math is correct, bro. Why you are seeing lower total rpm is the fact that you are not including the jackshaft cog pulley with the Vortech setup which multiplies the rotation speed rate of your drive pulley off the supercharger.
Old Nov 16, 2018 | 08:51 AM
  #89
Chinky4U's Avatar
Chinky4U
I wanna say it is because if I recall, there isnt a jack shaft on the rotrex set up, is there?
Old Nov 16, 2018 | 02:17 PM
  #90
BluestreamDE
No theyre isnt to my knowledge. Do you know the internal step-up ratio of this blower? Like if your 110mm pulley makes one complete turn, how many times does the the impeller spin?
Old Nov 16, 2018 | 10:53 PM
  #91
Chinky4U's Avatar
Chinky4U
I think the step up ratio is 9.386
Old Dec 17, 2018 | 11:26 AM
  #92
sammyG350gt's Avatar
sammyG350gt
Keeping this thread alive!
Old Dec 17, 2018 | 11:30 AM
  #93
onevq35de's Avatar
onevq35de
Ah, we're gonna need more than that sammy You're the only guy keeping this thread alive. Everybody else has their HKS in their pickanic basket or something.
Love'n the engine bay!
Old Dec 18, 2018 | 12:42 PM
  #94
Chinky4U's Avatar
Chinky4U
I need more Sammy. Any videos??
Old Dec 19, 2018 | 07:41 AM
  #95
AKS14's Avatar
AKS14
I finally got some time to stuff the engine and trans back in the car, slowly working an hour here and there to get the core support up, all the piping mounted, run the return line for the fuel system, and build out the lines for my oil cooler setup, then its hopefully off to the dyno early January.
Old Dec 19, 2018 | 08:29 AM
  #96
onevq35de's Avatar
onevq35de
Look'n good. At this stage, you've got an opportunity to seal the air filter from the engine bay which would act like a larger intercooler because the HKS wouldn't be taking in shitty bay air.
You could get some 1/16" or 1/8" abs, cut out a hole to fit the filter's pipe and attach it to the tire side of the frame rail then heat it up and conform it to the fender near the strut tower, pull it out and finish the rest once the core support and nose go back on. Make sure there's enough material so that it extends to the top of the fender as well.
DO IT!
Old Dec 19, 2018 | 07:28 PM
  #97
AKS14's Avatar
AKS14
So I just fit up the charge piping and intercooler almost completely, which is what I was figuring would give me the most headache as I’m putting it on a G35 and it’s intended for the 350z
All in all it went really smooth, the hot pipe bolted on just as it should, intake piping fit up nicely, I had to trim the core support and make an opening for the cold pipe to go into, and the G35 crash bar is a bit different than 350z so I am going to make some new brackets to mount the traction cooler, other than that it was surprisingly super straight forward.
Old Dec 29, 2018 | 10:54 AM
  #98
AKS14's Avatar
AKS14
I got the Koyo oil cooler mounted up, built some new brackets for the traction fluid cooler so it gets some cool air from the grill inlet, now I've just got to finish plumbing everything and button up a few little things and its off to the dyne soon hopefully
Old Dec 29, 2018 | 05:08 PM
  #99
BluestreamDE
The G35 bumper gives hardly any open area for the intercooler to recieve direct airflow
Old Dec 29, 2018 | 05:32 PM
  #100
Conway_160's Avatar
Conway_160
Yea the G bumper sucks for air flow.
