TimRod's V7 YSi Coming!
Old Apr 20, 2021 | 05:13 PM
  #81
bealljk's Avatar
bealljk
Originally Posted by OldManZ350
22 Inch Header Extensions with PPE Long Tube Headers for The DragStrip.
I did a set of these for my greddy twin kit ... it was indeed loud and it sounded great ... very gurgly!
OMZ - you should do them with V-Bands rather than 2bolt flanges
Old Apr 20, 2021 | 11:25 PM
  #82
OldManZ350's Avatar
OldManZ350
Looks Good! You have a lot of sensors in there.....
My Extension are Done!
I will only use them for the Drag Strip 2, 3 times a year.
Old Apr 26, 2021 | 04:44 AM
  #83
350z-Helsinki's Avatar
350z-Helsinki
You can control the fuel pumps with the G4X. (I'm using G4+).
It's interesting to see that you went with the surge tank setup. The trunk is the best place if you don't mind having the fuel inside the cabin. In my case I relocated battery and fitted the surge tank were the battery used to be. The problem with my setup was that E85 temps were way too hot. In order to tackle the issue I installed a Aeroflow fuel controller and changed the piping a bit. I'm not sure if this will solve the issue, but have you considered a fuel cooler in the return line?
Old Apr 26, 2021 | 08:08 AM
  #84
bealljk's Avatar
bealljk
Elaborate - How do you use the G4+ to control the fuel pumps?
Old Apr 27, 2021 | 08:58 AM
  #85
OldManZ350's Avatar
OldManZ350
Yes, I might add a Fuel Cooler.
Temps are not to bad when I have 1/2 a tank or more, but their is some Heat.
Old Aug 4, 2021 | 11:50 PM
  #86
350z-Helsinki
Sorry took my time to answer this one.
You can use the analog outputs to control the fuel pump itself or a fuel pump speed controller. If you need just on off switch you control a relay with the G4+ (G4x) and hook the relay to a fuel pump.
Old Aug 9, 2021 | 01:41 PM
  #87
OldManZ350's Avatar
OldManZ350
UPDATE:
Still Tuning Street Map 93 Octane, so far to 5600 rpm
@ 5600rpm making 16.50psi, 10* Ignition Advance, 517wtq
Should continue to make Tq to 6800rpm
I took off the bra after 17 years and made some changes to the from facisa for cooling.
Old Aug 9, 2021 | 02:10 PM
  #88
bealljk's Avatar
bealljk
Looking good!
did you make a laptop mount?
how are you getting your HP numbers?
Old Aug 9, 2021 | 02:21 PM
  #89
OldManZ350's Avatar
OldManZ350
Originally Posted by bealljk
Looking good!
Yep, I made the Laptop mount.
Wtq numbers are coming from an accelerometer in the ECU. It has to be set up correctly though.
Just using the numbers for Tuning , just like a Dyno, it's a Tool...
Old Aug 9, 2021 | 09:19 PM
  #90
bealljk's Avatar
bealljk
the g4x has an accelerometer?
Old Aug 9, 2021 | 11:38 PM
  #91
OldManZ350's Avatar
OldManZ350
YES
Old Aug 10, 2021 | 06:42 AM
  #92
jhc's Avatar
jhc
General & Tech Moderator
Dam, that intercooler makes my TD10 look like an oil cooler! Love it!
Old Aug 10, 2021 | 11:07 AM
  #93
OldManZ350's Avatar
OldManZ350
It's a TreadStone Tr-1245, and it works great. On a hard pull only 8-10* above ambient temp.
Old Aug 10, 2021 | 09:19 PM
  #94
bealljk's Avatar
bealljk
I bought the same one (after OMZ recommendations) and my IATs look wrong they are so close to ambient.
Old Aug 11, 2021 | 10:26 AM
  #95
OldManZ350's Avatar
OldManZ350
Haha......
Old Aug 30, 2021 | 12:13 AM
  #96
OldManZ350's Avatar
OldManZ350
Small Update:
I had a 2.90 Serp Pulley on, was having to reduce the Ignition Timing to much, & was begining to get to much Boost for 93 Pump Gas and the Street.
So, I put back on the 3.20 Pulley. This was my Original plan to have the large one for the street and smaller one for the Drag Strrip.
What may end up happening is keeping the larger 3.20 pulley on full time or at least the 1st time out at the Strip.
As I've been Tuning with the Larger 3.20 Pulley, I'm seeing more and more Boost numbers in the Higher RPM.
So far, 23.4 @ 6750 rpm, this gets me to 26-27psi @ 7500rpm. When I put the Bellmouth Intake on the SC that will another 2-3psi, and if I have to run it past 7500rpm thru the traps that will be even more boost.
What I've found so far is that, this setup really comes on hard @ 6200rpm & keeps pulling. Still making Torque at 6800rpm
Even with this 3.20 pulley only at 8.5* ignition Timing @ 6500rpm on 93 pump gas.
Very Close to being done with the Street Tune.
Can't wait to get some C16 in this Car!
Got the Shifter Handle with Line-Lock Button Done & Fire Extiguser Mounted.
So stuff is done in the Interior except for the RollBar
Old Sep 17, 2021 | 08:13 AM
  #97
gtzero's Avatar
gtzero
Bro! It's looking amazing! Looking forward to seeing the times you put down.
--Dee
Old Nov 6, 2021 | 01:45 PM
  #98
OldManZ350's Avatar
OldManZ350
RollBar is Done!
Old Nov 6, 2021 | 01:48 PM
  #99
OldManZ350's Avatar
OldManZ350
Mid Race Tune is Done!
This is a Mix of 93 Pump & Race Gas about 102/104 Octane.
Data in Pic
Intended to run it out to 7500rpm, but tires were spinning to much, & I already had to lift out of the throttle @ 6000rpm because of tire spin.
Old Nov 6, 2021 | 01:50 PM
  #100
OldManZ350's Avatar
OldManZ350
VP C16 & Q16 Tune, with 1/4 Mile Et and MPH Coming Soon!
