Custom turbo setup advice wanted
Old Aug 14, 2020 | 04:20 AM
  #61
Conway_160's Avatar
Conway_160
Originally Posted by 0taku
Water/Meth and 11:1 why not
That is my set up. I just wish my haltech had two maps. One for meth and one without.
Old Aug 14, 2020 | 05:36 AM
  #62
0taku's Avatar
0taku
I’m definitely fortunate to have a very easy supply of E85 around here. Although the upgraded fuel system cost kinda ruined it.
Old Aug 14, 2020 | 07:09 PM
  #63
Conway_160's Avatar
Conway_160
The larger fuel system price is a pain but if your serious about power with a "cheap" fuel E is the only way to go.
Old Aug 15, 2020 | 04:26 PM
  #64
0taku's Avatar
0taku
Definitely a great cheap racing fuel. I love it because it gives so much more breathing space on the 11:1.
Old Aug 17, 2020 | 04:54 PM
  #65
RiggZie's Avatar
RiggZie
So would I be ok running 11:1 on my twin turbo setup? I found a pair of rods and pistons for fairly cheap but it only comes in 8.8:1 or 11:1 it's a really good deal but I don't know if 11:1 is too high or still ok
Old Aug 17, 2020 | 06:09 PM
  #66
bealljk's Avatar
bealljk
damn! feast or famine!
Just my opinion - those two choices are too far on either side and I would continue to look.
Old Aug 18, 2020 | 09:48 AM
  #67
0taku's Avatar
0taku
+1, if adding watermeth or higher octane is an issue then I'd just search around for like a 9.5:1.
Old Oct 20, 2020 | 05:07 PM
  #68
RiggZie's Avatar
RiggZie
Hey everyone a huge update (sorry it took so long). I decided to go a different route after my vq spun a bearing. I am still doing a twin turbo build, however i chose to go the "LS" route. Picked up a 5.3 l59 from a junkyard. in a couple weeks i will be ordering the majority of the necessary parts including but not limited to the holley terminator X system, ISR motor mounts and trans brace, wahlboro 520 pump, an crap load of braided stainless lines and corresponding fittings to makeup fuel return system, power steering lines, etc. , Sikky clutch master cylinder 1000cc injectors, Collins adapter (ls to cd009), and a few other things. Here is also a picture dump of the carnage and tear down.
She's out
Thats not supposed to have a hole
dropped the oil pan and this **** came out
prepping for the LS
This block might be salvage
**** the crank bolt
Old Oct 20, 2020 | 05:30 PM
  #69
Conway_160's Avatar
Conway_160
That sucks, You got this.
Exemption
Jan 9, 2012 10:49 AM
Silntseker33
Dec 11, 2011 06:12 AM
dagaleag35
Mar 25, 2009 07:20 PM
Importlife.com
May 7, 2003 10:20 AM
