5AT (automatic transmission) Owners With Forced Induction Please Read
Old Apr 18, 2009 | 11:25 AM
  #161
coachk's Avatar
coachk
Bazooka....I seriously doubt the OEM tranny can go any further than where I went(505). I wouldn't try it (550).
Raj...my tranny dipstick looks nothing like the one you show in the pdf file. Interesting......I wonder if the Z uses a different one than the G
Old Apr 18, 2009 | 11:55 AM
  #162
rcdash's Avatar
rcdash
I agree. I was told the stock clutch packs (even with the VB and cooler) were good to a max of 500 by Thomas at SGP. But I don't know that good data exists on this point. I would say in the 500 range you'd want to upgrade the clutch packs. On the other hand, I don't think you'd destroy your trans by seeing where it starts to slip (other than requiring a rebuild, which is what you'd be doing anyway). Post up data if you decide to push it!
Coach, interesting that your dipstick is different. I guess you'd have to go off the procedure in your car's specific FSM.
Old Apr 18, 2009 | 12:03 PM
  #163
tiguy99's Avatar
tiguy99
Originally Posted by fowlman01
Mine is not all that slow, it is just inconsistent and it will be at least .04sec faster if it shifts the way it did before the vortech.
There are a lot of people that don't think raising the rev limit is a good idea.
I have a 3.55 ear end, so I would still have to shift short.
And I would still have a tranny that didn't shift fast enough.
What if you added the 3.3 VLSD pumpkin with taller gears? That should help slow the revs some right? Would make sense to me. Especially with all the extra power you're putting down now
Old Apr 18, 2009 | 12:12 PM
  #164
coachk's Avatar
coachk
tiguy....the 3.3 is what the 5ATs come with. Fowlman has the 5AT so if he wanted to swap he would have to go with the 3.5 from the 6MT. It looks like in Fowlmans post that you quoted, he already switched to the 3.5
Old Apr 18, 2009 | 12:30 PM
  #165
tiguy99's Avatar
tiguy99
You're right CoachK. The 3.5 accelerates quicker. This + the extra HP and TQ = faster revs. I can only imagine his whoas if he went with 4.083 FD gears
Old Apr 18, 2009 | 02:43 PM
  #166
BaZooKa's Avatar
BaZooKa
Raj and Coach thnx for the info, well i guess in future i might push it and try
Old Apr 18, 2009 | 11:51 PM
  #167
nothix's Avatar
nothix
drained some fluid out to get in between the checkered markings when warmed up
(15min of idle.revving, normal coolant operating temp)
Did not affect the issue.
One thing I have noticed, no matter how hot the car is, if i simply turn it off, then turn it back on, the transmission works perfect. hard shifts, absolutely no slipping, but the problem returns within about 1-2 minutes.
I was going to pull the battery off and let it reset overnight, but its already too late, and I'm tired. I'll do the reset procedure tomorrow during the day.
PS i followed that procedure, the one I got from the FSM was a little less detailed. I warmed up the engine, shifted through each gear(position), checked the position while the car was running, and flipped the dipstick backwards. I dont think I made a mistake with the level readings.
From my limit knowledge of automatic transmissions, its sounds like I have blown a seal. It has a really hard time shifting between each gear once its warmed up, and then eventually starts popping out of the gears if i rev to high. (ie 3rd at 3000 rpm).
The only way I was able to get it to behave normal was to keep the rpms under 2000 at all times.
Old Apr 19, 2009 | 12:06 AM
  #168
nothix's Avatar
nothix
I'm ordering the Transgo VB kit tomorrow, should I invest in an upgrade AT cooler?
Old Apr 19, 2009 | 12:05 PM
  #169
BaZooKa's Avatar
BaZooKa
if you feel that the tranny gets hot from abusing the car, then order the tranny cooler
im ordering the tranny cooler in a few weeks, just to make sure the tranny is getting cooler oil
Old Apr 19, 2009 | 12:34 PM
  #170
mrg1981's Avatar
mrg1981
My transmission did the exact same thing...right before the big bang! I don't know exactly what caused the delays, but nobody could figure out a tuning or other electrical cause. We narrowed it down to a mechanical issue. Then the transmission went out completely and we sent it out to be fixed. Upon tear down, we discovered that the transmission was stock!!! It was supposed to be a full race 5AT from SGP, but apparently, they like to NOT do the work they are paid to do. Anyway, the point is that it may be related to the pump or a seal, since both of those went out on mine and it did the same thing.
Old Apr 19, 2009 | 01:12 PM
  #171
nothix's Avatar
nothix
did you notice the same affect of turning off the car and turning it back on?
Maybe its a pump going out?
Old Apr 19, 2009 | 01:39 PM
  #172
rcdash's Avatar
rcdash
I think this is a great opportunity to fully build that trans of yours. I'm not sure the VB and cooler will rectify the problem at this point, as I'm sure you suspect.
Old Apr 19, 2009 | 01:44 PM
  #173
coachk's Avatar
coachk
Nothix...how long were you driving around after the fluid change(days,weeks,months)?
I read that if you overfill the tranny fluid, you can blow a seal. I just don't know if blowing a seal causes the issues you are having.
Old Apr 19, 2009 | 02:58 PM
  #174
nothix's Avatar
nothix
I'll see how much the shop quotes me on building it up.
probably close to 2 months, hardly any issues until friday
Old Apr 19, 2009 | 04:37 PM
  #175
fowlman01's Avatar
fowlman01
Originally Posted by j.arnaldo
...at 60, I've left my Z bone stock. Things could get complicated and, at my age...I don't think so!
____________________________________________________________ _______________________
'O4 Touring Coupe: NO feathering! NO oil-consumption issues! F-l-a-w-l-e-s-s AT!!!
I'm 70 and I have a S/C on my Z and bracket race it.
Old Apr 19, 2009 | 04:40 PM
  #176
fowlman01's Avatar
fowlman01
Yes, you can blow a seal. VB won't fix a worn out tranny. these 5AT's seem to be pretty strong though.
Old Apr 19, 2009 | 07:50 PM
  #177
nothix's Avatar
nothix
according to the manual, with my symptoms, one of the following problems:
-vehicle speed sensor
-ATF pressure switch
-Torque converter
-oil pump assy
-gear system
Old Apr 19, 2009 | 10:13 PM
  #178
mrg1981's Avatar
mrg1981
Yes, it seemed to shift more firmly if I let the ECU reset. This led me to believe that it may be some sort of tuning issue, but ultimately, I don't believe it was even related. I tried adding an HKS Fuel Cut Defensor, but I don't think it did anything for that issue.
Old Apr 20, 2009 | 05:09 AM
  #179
nothix's Avatar
nothix
has your tranny been replaced mrg? did you get the built GTM 5spd?
PS father is bringing it into a recommended transmission shop this morning
Old Apr 20, 2009 | 06:49 PM
  #180
nothix's Avatar
nothix
alright tranny is in the shop
they drained the oil and removed the pan.
Burnt oil, gotta open up the tranny.
Owner suggests I build it since I'm already paying for labor to fix the issue.
What mods should I do?
Definitely going to order the Transgo VB.
Should I get anything else from the GTM site?
GTM DIRECT CLUTCH DRUM PISTON - $316.35 (is this an oem replacement?)
GTM HD BILLET SERVO PISTON ASSMEBLY - $187.00
GTM HIGH-LOW REVERSE DRUM PISTON - $233.00
GTM RE55R05A FORWARD CLUTCH POWER PACK - $169.98
GTM RE55R05A HIGH-LOW REVERSE CLUTCH POWER PACK - $192.71
GTM RE55R05A INPUT CLUTCH POWER PACK - $205.11
GTM SURFACE TREATED DIRECT CLUTCH PRESSURE PLATE - $95.00
GTM SURFACE TREATED HIGH-LOW REVERSE CLUTCH PRESSURE PLATE - $80.00
RE5R05A BAND ASSEMBLY - $43.11
GTM TORQUE CONVERTER UPGRADE - $462.00
RE5R05A COMPLETE OVERHALL KIT - $395.11 (not sure if shop can get the equvalent elsewhere)
RE5R05A FILTER ASSEMBLY - $33.29 (same as above)
RE5RO5A TRANSMISSION PAN GASKET - $14.35 (is this already included in the rebuild kit?)
GTM RE55R05A LOW COAST CLUTCH POWER PACK - $162.00
GTM RE55R05A REVERSE CLUTCH POWER PACK - $175.11
GTM RE5R05A DIRECT CLUTCH POWER PACK - $224.11
