Turbonetics Single Turbo Kit..Pics/Videos
Old Feb 23, 2005 | 08:47 AM
  #1121
LuksEaZy's Avatar
LuksEaZy
So will you have to tap the oil pan or can you get a spacer and tap the spacer?
I hope you get your car back up and running soon MIAPLAYA...
I can't wait to see some video soon in the next month or so
Old Feb 23, 2005 | 08:57 AM
  #1122
MIAPLAYA's Avatar
MIAPLAYA
You could absolutely tap the spacer and run a j tube for the return.. Me and protocav are actually working on a modified stock oil pan to add along with the spacer. We are trying to get some well designed baffles welded onto the stock pan to prevent slosh and combining that with the spacer gives you a really cheap version of the APS or PE oil pans. The plans are to tap the spacer and run a j tube for draining. We are still working on the design of the baffle to make them as efficient and worthwhile as possible. I'll post pics when we have a final design. Currently doing test fitting...
Old Feb 23, 2005 | 12:28 PM
  #1123
Peking's Avatar
Peking
You planning on making more than one for yourself? If so you planning on pitching it to the Turbonetic guys so they can include it in the kit so it just becomes a swap?
Old Feb 23, 2005 | 01:02 PM
  #1124
MIAPLAYA's Avatar
MIAPLAYA
Well we are still designing it so we are not sure which way we are going. i had planned to market it to a vendor like Mossy or someone to pretty much sell it for us or just buy our design. (Not like its rocket science).
UPDATE UPDATE UPDATE UPDATE **************UPDATE
I just got off the phone with Brad. The first 25 kits are being boxed right now. He believes the first 18 or so are already sold so if you haven't ordered order now... FOR THE TUNER KIT. MSRP from Turbonetics is going to be $5295. That about $300 less then the full version and will not include injectors, reflash, or fuel pump. Of course street price will be lower.... The part number for the tuner version is 15138. And yes it is available now. Most vendors probable do not have the info yet as this was a new decision from Turbonetics but if the vendors contact Turbonetics they can order the kit directly. They have enough for probably another 30 kits that can be tuner versions now. The next run of full kits will be out in a week or so. There will not be a cat option for the tuner version. just an FYI.... As I said before for those who want to use their own fuel management I would sincerely suggest going with the full version and just ditching the reflash if thats what you want. Even at full cost $4750 plus and emanage with all the harnesses $500 Total cost is $5250. Thats $200 less then the cheapest Greddy i have seen and thats not factoring in the price difference in install. Greddy install=~$2000 Turbonetics install= ~$800 Keep in mind also that part of the reflash is getting rid of the throttle percent opening. For those who dont remember on a stock ECU the throttle plate closes to 80% near redline. Part of the Turbonetics flash is to ensure it stays at 100%
Thats it for now guys!!!!
Old Feb 23, 2005 | 02:41 PM
  #1125
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Great news!!!
Old Feb 23, 2005 | 02:57 PM
  #1126
MIAPLAYA's Avatar
MIAPLAYA
Originally posted by nis350ztt
Great news!!!
I thought you'd be happy. BTW I asked Brad again about the bigger wheel or compressor and he said hes waiting to hear from the engineering guys on whether a different wheel (P trim) would do ok in the standard 60-1 compressor housing. If not they will need to see if a 62-1 may fit or maybe even a 68-1. A 68-1 is a LOT of turbo...
Of course if your feeling froggy their T series big boys are nice., Or maybe a nice Thumper series...just kidding I serioulsy doubt any of those would come close to fitting.
Old Feb 23, 2005 | 03:01 PM
  #1127
MIAPLAYA's Avatar
MIAPLAYA
Nis your mailbox is full.. Shoot me a PM I want to talk to you about some stuff.
Old Feb 23, 2005 | 10:46 PM
  #1128
time4aspliff's Avatar
time4aspliff
It's great to read that things seem to be getting back to normal. I haven't chimed in too much but I've been following this thread for a long time as I'm also interested in this kit.
Old Feb 24, 2005 | 05:04 AM
  #1129
LuksEaZy's Avatar
LuksEaZy
Great news on the tuner version...bad news my g/f don't want me to get it right now...she wants a ring before i get my turbo...
So labor wise it is in the 800 range for install price....that is hella good...I can't wait till I can get this thing on my car..
Thanks MIAPLAYA for the update
Old Feb 24, 2005 | 06:18 AM
  #1130
tig488's Avatar
tig488
62-1 should be an exact perfect fit.
Old Feb 24, 2005 | 06:46 AM
  #1131
MIAPLAYA's Avatar
MIAPLAYA
Yeah it SHOULD be.... they just haven't done fitment tests yet...
Old Feb 24, 2005 | 11:24 AM
  #1132
degradated's Avatar
degradated
MIA,
62-1 and 60-1 are externally exactly the same size - so there's no doubt that it'd fit. I've seen up to a T66 wheel in the 60 series housing even, but that's not usually recommended because it leaves very little diffuser section in the housing and efficiency will drop significantly.
Ryan
Old Feb 24, 2005 | 11:35 AM
  #1133
MIAPLAYA's Avatar
MIAPLAYA
Originally posted by degradated
MIA,
Ryan
Thats good info... i wonder how it would perform with the motor.
Old Feb 24, 2005 | 11:37 AM
  #1134
kcobean's Avatar
kcobean
Just an FYI for people who are sold on this kit:
AAM Group Buy Thread:
https://my350z.com/forum/showthread....hreadid=111598
Old Feb 24, 2005 | 11:40 AM
  #1135
MIAPLAYA's Avatar
MIAPLAYA
Ryan,
Are you the Ryan from Turbonetics?
Old Feb 24, 2005 | 12:38 PM
  #1136
Brandon@Forged
Ryan,
Must be, the IP address is the same as Brad's.
Old Feb 24, 2005 | 12:41 PM
  #1137
MIAPLAYA's Avatar
MIAPLAYA
Sneaky sneaky.......
  #1138
degradated's Avatar
degradated
Ryan,
That's me.
Unfortunately, I won't be able to come on here and post very often...
The 62-1 at the 9 psi of boost will be mildly more powerful - and difference in spool should only be about 100-200 RPM's if everything else is kept the same... now if you were to be running high boost (15 psi or greater), the higher flowing characteristics of the 62-1 will come into play more and could potentially make another 50-60 hp.
Old Feb 24, 2005 | 12:42 PM
  #1139
MIAPLAYA's Avatar
MIAPLAYA
That's me.
Thats what we are looking for...GREAT info...There are several members here who want to purchase a tuner kit with a bigger then average turbo to make about 600-650 RWHP. i think the 62-1 should be perfect then.
Old Feb 24, 2005 | 01:10 PM
  #1140
degradated's Avatar
degradated
600 whp might be do-able... but that could be pushing it. We usually rate the 62-1 wheel (with appropriately sized turbine) at about 625 flywheel horsepower - however I've heard of B-series Honda motors with full standalone at 25 psi of boost making over 600 whp.
Since we are dealing with the VQ35DE(T) that hasn't seen the full potential untapped yet, I suppose the possibility is there to make more power than you'd normally expect - we shall see. Tuning will probably be the key.
