Intake Question
on
Well guys i tried to serch for this in past post but couldnt find exactly what i was looking for so sorry..
What intakes might you guys recommend. My z is bone stock and i want to
put an intake..
Preciate it
Darrell
put an intake..
Preciate it
Darrell
You really must suck at t3h searching because there are tons of threads that will pop up if you type in intake. There is also a complete forum devoted to intakes:
https://my350z.com/forum/intake-exhaust-334/
As for your question, no you can't combine the Popcharger and the Injen. If you want a cheap performer get the Popcharger. If you want the Injen get the Injen.
Guest
Posts: n/a
on
it seems the pop chrager has so many pros than cons:
pros:
-at least 6whp gain
-easy installation
-CARB approved
-price (you can get one for 109-120)
cons:
-heat soak (that heat sheild isn't fooling me. i have had short rams before and they don't do squat)
the Injen 1986sp
pros:
-most power i've seen in an intake (cloudy had an independant dyno)
-no heat soak
-can turn into a short ram
cons:
-one of the more expensive intakes (around $250)
-in a CAI configuration there is a higher chance of hydrolock (but still unlikely if you're carefull)
-not CARB approved
-installation will take a while
....from what i've read that's about the gist of it.
pros:
-at least 6whp gain
-easy installation
-CARB approved
cons:
the Injen 1986sp
pros:
-no heat soak
cons:
-not CARB approved
04-04-2016 07:52 AM
