Need Help getting the O2 clips off
Old Nov 19, 2005 | 12:25 PM
HoldThisForMe's Avatar
HoldThisForMe
Exclamation Need Help getting the O2 clips off
anyone know how to get them off so I can remove my cats??? also what size is that bolt that bolts them in??? im having to use an adjustable wrench and the damn thing hardly fits...which is why im trying to unhook the sensor from the clip...any help please
Russ
Old Nov 19, 2005 | 12:32 PM
plumpzz's Avatar
plumpzz
use a flat head screw driver to unclip them. Use a monkey wrench to get it off. Careful not to break off the actual sensor.. 100 bucks a pop.
Old Nov 19, 2005 | 01:27 PM
HoldThisForMe
i got them off there lil hanger thing that mounts to thr tranny...but i want to unclip them from where the two snap together...or does that even come apart? I cant get a monky wrench in there to get and leverage on it to get it loose...
Old Nov 19, 2005 | 03:06 PM
Yes. The clips for the oxygen sensor wires can be removed ( blue on the driver side, green on the passenger side). Unclip the two wires next to the blue and green things. The clips are just a bend clip. Pull the black tiebacks in the upper left and right in the photo. Now the wires hang. You can separate the black-blue connectors, and white-green connectors with a simple squeeze and pull.
With the cat out and on the ground, remove the oxygen sensor. Use a little liquid wrench and let it sit for 5 minutes. There’s a special long socket with a cut out at the top for the wire. If you don’t have one, a regular wrench will do.
Old Nov 19, 2005 | 04:07 PM
HoldThisForMe
THANKS a bunch...i got them off...man that whole install was a pain...had to make a trip to hardware store to get some bolts and nuts but its done...it is raspy now but not to aweful bad...it is extremely loud considering i have an RS*R catback lol. performance so far just from a trip down the road and back is better. ill see more about that later...Thanks agian fellas
Russ
Old Nov 21, 2005 | 07:19 PM
NismoNitsuj's Avatar
NismoNitsuj
Stupid question...does the RSR eliminate the cats? I want to get one, but I want to pass emissions in CA.
Thnx
-Justin
Old Nov 22, 2005 | 08:00 PM
HoldThisForMe
No the RS*R is just a cat-back exhaust system. It connects after the y-pipe so really it should be called a y-back. I dont live in CA but you should pass with no problem since it does nothing to the emissions.
Old Nov 23, 2005 | 10:34 AM
I thought we had some sharp people here who should have caught my error. It should be:
blue on the passenger side, green on the driver side
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
simstad
Jul 30, 2003 04:42 PM
schindem
Mar 29, 2003 10:14 PM
JmanZ
Jul 11, 2002 01:50 AM
