Problems with HKS Hi-Power
Old Aug 15, 2006 | 10:21 AM
drumma022's Avatar
drumma022
Default Problems with HKS Hi-Power
I searched for 10 minutes and have not found anyone with this same problem. I have a friend that has a supposedly stock Track model in the Kingdom of Bahrain and he was saying that his differential has the fins like the NISMO diff cover. These fins come in contact with the HKS Hi-Power exhaust. We called HKS and they said this exhaust is for US-spec only 350Z's and will not work with the NISMO diff cover.
I've had the guy's mechanic try and readjust the exhaust a bit, but he says he keeps having the same problem.
Has anybody else seen this problem?
Attached Thumbnails Problems with HKS Hi-Power-dsc01566.jpg   Problems with HKS Hi-Power-dsc01568.jpg
Old Aug 15, 2006 | 10:24 AM
Zexy's Avatar
Zexy
Maybe you should grind down the flange a bit so it won't come in contact.
Old Aug 15, 2006 | 01:21 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
The Euro Z's seem to have a finned diff cover but it should still be a R205 rear end. I spoke with HKS this morning and they were experiencing the same problem with one of their customers which I am sure is the same person as your friend. The U.S Z's do not have that cover on the diff so clearance was never an issue.
Old Aug 15, 2006 | 01:23 PM
Chebosto's Avatar
Chebosto
cut the flanges off and reweld some where- probably would be cheaper than swapping the diff housing out-
Old Aug 15, 2006 | 01:27 PM
norapat01's Avatar
norapat01
US model also have a bit problem. Mine is knocking against a diff bolt, so i had to put a small dimple on that part of the exhaust.
Old Aug 15, 2006 | 02:30 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
we experienced this a long time ago with a customers car is Saudi Arabia - he simply ground off some of the fins from the diff housing
Old Aug 15, 2006 | 07:28 PM
superppwZ33's Avatar
superppwZ33
i had the same issue and same solution
Old Aug 15, 2006 | 09:48 PM
Cannysage's Avatar
Cannysage
I have the same problem, but I ghetto fabricated it by using a pluming pipe brace.. what is this dimple you guys are talking of?
Old Aug 16, 2006 | 06:35 AM
aalzuhair's Avatar
aalzuhair
Yeah I remember that problem
I posted a pic of the diff before ... its floating on the forum some place
Old Aug 19, 2006 | 09:51 AM
Tarek's Avatar
Tarek
I had the same problem here in Saudi Arabia. The installer had to customize the rear V shaped connection (that is hitting the diff) by cutting and welding new pipes. The result was great, and the sound too. Pipes are of the same grade and diameter.
Old Aug 21, 2006 | 10:13 AM
windydog's Avatar
windydog
You should check this out:
https://my350z.com/forum/intake-exhaust/211036-hks-hanger-broke-off.html
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
