Eliminating Check engine light???
Anybody know how to get rid of the damn thing just put in my test pipes after a couple drives it finally poped up Any kind of device to get rid of this ??
Which year model Z do you have? You could possibly use non-foulers if you don't have the 2007 model.
If you have an 07, then all I can tell you is to go to autozone to have them clear it out for you. But it will come back again. There is also a device you can use to clear the code yourself, I forget what it's called. But even using that, the code will reappear.
I'm waiting for a fix for the 07's.
disconnect the battery and go to sleep. Reconnect in the morning. That is what I was told to do and it worked. Mine came on after installing turbonetics and seemed to be a common issue. Resolved now
A diagnostic code scanner can be used. It will tell you the code and what it means; you can also erase the CEL however as stated above it will reappear if the root cause is not dealt with. They run around $150 for a decent one.
You need Spark Plug Non-faulers. Two for each side. Then drill two of them with a 1/2 drill bit. Place your O2 senso in it and then screw it to the tesp pipe. Reset engine light and you are done. Do a search for a DYI, I know is on the site somewhere.
Originally Posted by DaZfan619
Where can i Buy these foulers you guys are talking about need them asap....pm me please
