helix test pipes - pre install
Old May 22, 2008 | 09:37 PM
roast's Avatar
roast
Default helix test pipes - pre install
yeah... so i'm installing test pipes on my 04.5 this weekend... never installed tp's before but hopefully it shouldn't be too big of a deal...
I've got impact wrenches... plenty of other tools.... I'll pick up some PB Blaster tomorrow.... and a couple packages of non foulers....
any tips or suggestions before I begin Saturday morning????
Old May 22, 2008 | 09:39 PM
Asian Invasian's Avatar
Asian Invasian
breaker bar, 20 inches of extension on the breaker bar, 02 sensor wrench.
Old May 22, 2008 | 09:55 PM
ssgohan434's Avatar
ssgohan434
your case of favorite brew?
Old May 23, 2008 | 08:58 AM
Originally Posted by Asian Invasian
02 sensor wrench.
Old May 24, 2008 | 08:49 AM
roast's Avatar
roast
ok... I've got all of the above.. but I'm a little bit irritated...
these dumbass testpipes position the o2 sensor on the passenger side downward... stock is up an in... with the nonfoulers in I doubt I can clear my pit backing out once everything is installed..... and that just happens to be the cat that has a bunch of scrapes from bottoming out....
I'm reconsidering even installing these.....
Why again do people recommend these?
Old May 24, 2008 | 08:58 AM
raf84ny's Avatar
raf84ny
Helix test pipes have been on the market for ever, many people have them and no one had really complained about the position of the O 2 sensor. Try one on and see OR donate them to me. GL w/ the install.
Old May 24, 2008 | 09:14 AM
roast's Avatar
roast
I think this thread pretty much sums it up....
https://my350z.com/forum/intake-exhaust/339008-02-sensor-problem.html
I may go ahead and install them... but I probably won't recommend these to anyone...
Old May 24, 2008 | 09:15 AM
pimpin714style's Avatar
pimpin714style
subscribing
Old May 24, 2008 | 09:30 AM
raf84ny's Avatar
raf84ny
https://my350z.com/forum/showthread.php?t=339008
Well, try to research other test pips and sell these to someone as long as you get your moneys worth. GL and keep us posted.
Old May 24, 2008 | 09:46 AM
yella's Avatar
yella
damn that sucks i just order some helix tps too
i might get it relocated but than again you used a fouler so it probably made it really low
Old May 24, 2008 | 01:05 PM
roast's Avatar
roast
It's not as bad as I originally thought it was going to be... but it's still pretty retarded....
v3 anyone?
Old May 24, 2008 | 01:10 PM
roast's Avatar
roast
....i haven't done the driver side yet... wanted to see how the passenger side was going to work out....
I got all the bolts from underneath with nothing more than an open/closed end wrench and a socket wrench (used an extension on one bolt)... I was really surprised how easy the bolts came off (relatively speaking).... car has been a daily driver in 4 salty *** winters.... it was harder to get the wrench on the nut than it was to actually break it loose... the bolt that was hardest to reach (the one you can't see) I couldn't soak in pbblaster and it was probably the easiest one to get off... I actually had the most problems with the Y pipe bolt.... that sucker wouldn't budge and I had all the room in the world... eventually the bolt snapped... no biggie was replacing it anyway....
Old May 24, 2008 | 01:22 PM
That's not right. The oxygen sensors should point up not down.
Old May 24, 2008 | 01:40 PM
SuperBlack350z's Avatar
SuperBlack350z
Mine was pointed down as well.
Old May 26, 2008 | 08:54 AM
roast's Avatar
roast
So everything is done.... the day I installed the test pipes was just a shitty day altogether...
A: I was not happy about the o2 sensor bung. It's not a matter of IF this will break, it's WHEN it breaks. Shitty design FTMFL.
B: Once everything was installed it sounds horrible. Something is definitely rattling... It sounds like it's coming from the Y pipe or the muffler. On deceleration at 4,200 RPM there is a loud and distinct rattle. You can hear it on acceleration too.. sounds like a fart can deluxe. Definitely not rasp.
C: The exhaust mounting bracket doesn't line up with the holes in the test pipes, so I had to leave it off. Now something else will probably break.
D: I got summoned for jury duty.
E: Me and my friend were cruising around, I was following him, we both get pulled over and ticketed $172 for an illegal U turn.
That about sums it up.
Old May 27, 2008 | 06:55 AM
But besides those things that you mentioned everything was OK?
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
