Fast intention test pipes! Asap
Old Feb 11, 2010 | 01:44 PM
tw8715's Avatar
tw8715
Default Fast intention test pipes! Asap
So about to order these. But seems there are two different version.
Aluminized and Stainless Steal.
Stainless Steal cost $30 more.
What is the main differences?
THANKS!
Old Feb 11, 2010 | 02:37 PM
tylerxfire's Avatar
tylerxfire
beleive on their website it describes the diffefence...and the only difference was one was polished..look on their site only ones i see are stainless..
http://www.fastintentions.com/produc...roducts_id=102
id change out that nismo y pipe if thats what u have going by ur sig if u do test pipes or high flows if u dont want cracking issues
Old Feb 11, 2010 | 02:51 PM
s31t8n8's Avatar
s31t8n8
really man?? its right on their fukcing site
Old Feb 11, 2010 | 02:52 PM
SatchScream's Avatar
SatchScream
The stainless steal ones' steal does not stain.
Old Feb 11, 2010 | 02:53 PM
skaterbasist's Avatar
skaterbasist
The main difference is that the aluminum is made out of aluminum, whereas the stainless steal is stainless steal...
Old Feb 11, 2010 | 03:01 PM
s31t8n8's Avatar
s31t8n8
Old Feb 11, 2010 | 03:11 PM
jblz's Avatar
jblz
I actually ordered the resonated cat pipes from them today. I spoke with Tony (from FI) at length, and with regards to the polishing...he said that no matter what they are going to turn a "goldish" color over time. but the polished ones will retain a slight shine whereas the non-polished ones will turn dull gold.
Old Feb 11, 2010 | 03:50 PM
tw8715's Avatar
tw8715
well i got the off here.
was wonder if the product used would make a difference.
not if polished or not.
i guess on the fast intention website they dont have aluminized.. weird
Aluminized: $329 Shipped
Stainless Steel: $369 Shipped
Polished SS: $389 Shipped
https://my350z.com/forum/engine/3436...ntentions.html
Old Feb 11, 2010 | 04:58 PM
scotts300's Avatar
scotts300
You're right, you DON'T know, because you are absolutely 100% incorrect.
Is Lynwood in CA? If so, you can get away with the aluminized steel, though for 40 bucks, I'd always opt for the superior SS material.
Old Feb 11, 2010 | 05:03 PM
Italianjoe1's Avatar
Italianjoe1
Yeah, "aluminized" is coated mild steel. If you live in an area with rough weather (snow/ice, rusty conditions), they won't hold up nearly as well if the coating is breached at all. Stainless is pretty damn solid in an automotive environment.
Old Feb 11, 2010 | 06:39 PM
tw8715's Avatar
tw8715
Ahhh finally some good answer lol
thanks for the heads up
I accually live in rainy wa so I went and got the stainless steel
thanks again!
Old Feb 11, 2010 | 07:04 PM
dhays's Avatar
dhays
That is true, but... Whenever I'm underneath my Z, I see LOTS of steel, and don't see any stainless except for what I've put there.
If you want to avoid a patina of rust, then go stainless. However, if you don't care (because is really is only cosmetic) then go with the aluminized steel.
Old Feb 11, 2010 | 07:37 PM
onagao's Avatar
onagao
"steel"
Old Feb 11, 2010 | 08:04 PM
Italianjoe1
There won't be anything from the oem that is the same quality as generic exhaust pipe. Most factory components are coated with something pretty solid to prevent rust, or are aluminum/plastic. For instance, most truck frames are made of regular steel, but are dipped in a wax like substance to keep them protected reliably.
Agreed though, aluminized exhaust piping is never really that bad, it's fairly cheap compared to stainless, easier to work with, and for all practical purposes works just fine. I've run both type of material in exhaust systems, and never had a problem either way.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
