1/2 plenum spacer w/ strut bar?
Old Aug 4, 2010 | 08:38 AM
TheBlue350z's Avatar
TheBlue350z
Default 1/2 plenum spacer w/ strut bar?
i want to get the mrev2 with the 1/2 plenum spacer. I know i need to get a aftermarket strut bar, but are there any that will fit the 1/2, or wil i just have to get the 5/16
Old Aug 4, 2010 | 08:43 AM
DB350's Avatar
DB350
why do you want the 1/2? i'm pretty sure that the 5/16 has been proven to give the best gains, and you dont need an aftermarket strut
Old Aug 4, 2010 | 08:49 AM
ajcool2's Avatar
ajcool2
Fail.
You can try using spacers for the stock strut bar. Some people says it works and some says it doesnt. It didnt work for me. I know the APS strut bar will work with it and theres another one I cant remember at the moment.
Old Aug 4, 2010 | 08:57 AM
DB350's Avatar
DB350
mind telling me how i failed?
Old Aug 4, 2010 | 09:05 AM
GeauxLadyZ's Avatar
GeauxLadyZ
You didnt.
Old Aug 4, 2010 | 05:41 PM
TheBlue350z
i heard greddy strut bars fit 1/2. is that true?
Old Aug 5, 2010 | 12:36 PM
BoomerZ33's Avatar
BoomerZ33
you're better off with the 5/16 if you want everything to fit. i have the isothermal 5/16 and used washer spacers under the strut bar.
Old Aug 5, 2010 | 12:43 PM
JasonZ-YA's Avatar
JasonZ-YA
about the best think you can do if you already have the 1/2 inch spacer is to install the thick spacers that they send you and then from there loosen the strut bar at the adjustment point shown here:
Bottom left of this pic - ignore the rest - Adjust at the middle hex, the other two are lock nuts to hold it in place.
- adjust it to fit all the bolts loosely by only turning them a few threads, do not tighten.
- do this for all locations
- then from there play with the adjustment **** and ensure you are clearing it with out pushing into the threads of the bolts
- use of a broken yard stick at contact points helps in finding the right position. (stick them between strut bar and engine points that its hitting. that will give you a yard stick worth of clearance) get it?
- tighten down if you get it to clear.
Like other said, some get it to work, others don't.
-J
BEBO'S ZEE
Jun 7, 2016 07:48 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
torchkc
Sep 11, 2015 08:26 PM
