NWP 75mm throttle body
Old Jun 28, 2013 | 05:48 AM
Pholicious's Avatar
Pholicious
Default NWP 75mm throttle body
Friend of mine sent me this looks interesting
Old Jun 28, 2013 | 06:07 AM
JaE35z's Avatar
JaE35z
Want it, need a new throttle body anyway
Old Jun 28, 2013 | 06:12 AM
JaE35z's Avatar
JaE35z
It'll be 365 bucks
Old Jun 28, 2013 | 06:38 AM
XChacalX's Avatar
XChacalX
Originally Posted by JaE35z
It'll be 365 bucks
if that is true , then its correctly priced since those maxima 09+ Throttle body sells for around 170$ on ebay.
Old Jun 28, 2013 | 07:17 AM
MrEous's Avatar
MrEous
$365 for a plug n play larger throttle body that doesn't require tuning...comes with 75mm TB, tapered mounting plate & wire harness
Not too bad for +15hp top end gains on Z/Gs... https://www.facebook.com/NWPEngineering
The dyno they used for the Maxima was on an auto that only had NWP phenolic spacers and NWP block off plate as the other mods...so I would assume the Z/G they tested the new TB kit on were similarily modded.
Old Jun 28, 2013 | 07:42 AM
mw9's Avatar
mw9
Interesting
Old Jun 28, 2013 | 08:26 AM
wird06's Avatar
wird06
I have seen that guy around the track. He has an impressive car.
Old Jun 28, 2013 | 08:30 AM
str8dum1's Avatar
str8dum1
user surratt is supplying the adapter harness. there was a thread about this months ago. guess finally someone wanted to start making a huge profit on a 5mm TB difference.
Old Jun 28, 2013 | 08:35 AM
RedBullRR's Avatar
RedBullRR
Looks impressive.
Old Jun 28, 2013 | 09:27 AM
taywan's Avatar
taywan
hmmm, no tuning and +15hp is nice but idk if its worth $350~ish Curious on FI applications..thanks for sharing.
Old Jun 28, 2013 | 09:45 AM
The_Assassin's Avatar
The_Assassin
if there really is a gain I hope they make one for the hr or would it be the same?...It should I guess probably just buy 2 lol
Old Jun 28, 2013 | 10:01 AM
JaE35z's Avatar
JaE35z
i don't like the price either...also wonder how they plan to support the headache everyone will run into with the idle air relearn procedure LOL
Old Jun 28, 2013 | 10:08 AM
MrEous's Avatar
MrEous
That's a good point. I 'think' on previous installation instructions they included the 'pedal dance' procedure to fix any idle issues. I have their BOP and Spacers already...but I'm already headed down a different route as far as TBs are concerned.
Old Jun 28, 2013 | 10:12 AM
XChacalX's Avatar
XChacalX
I find it funny that some peoples are saying that 15whp doesn't seem to be worth 365$ ...
you guys pay for an exhaust in the 1000$+ for the same gain.
even some gets HFC at 400+ for 10whp ...
the more you mod the Z the les gain there is, and that 365$ is cheap ! when overall in NA fully bolts on cost quite over 50$/WHP
Old Jun 28, 2013 | 12:50 PM
terrasmak's Avatar
10mm difference, and 10mm is a lot of difference in volume
Old Jun 28, 2013 | 04:15 PM
MrEous's Avatar
MrEous
I thought stock z was 70mm like the 02-08 Maxima?
Old Jun 28, 2013 | 05:25 PM
XChacalX's Avatar
XChacalX
70mm is oem 350z 03-06.
The setup that is gonna be sold is with the the Maxima 09+ TB which are 75mm and compatible.
so its 5mm of difference and way more flow than 70mm.
it should be an easy swap once the relearn procedure are done properly.
Old Jun 28, 2013 | 06:11 PM
terrasmak's Avatar
just measured, I stand corrected. The MAF sensor housing is still 65mm and the choke point
Old Jun 28, 2013 | 06:30 PM
TuckerE36's Avatar
TuckerE36
they said it might not match up perfectly to the Kinetix V+ plenum, some porting might be required... hmmm
Old Jun 28, 2013 | 08:27 PM
MrEous's Avatar
MrEous
Oh ok...I'm running a 4" intake/maf setup so my current choke point is the tb.
