? for anyone running RT cats...
Old Feb 13, 2004 | 07:42 PM
lotus's Avatar
lotus
Default ? for anyone running RT cats...
I installed a set of these today and needless to say fitment was kinda a hastle. I have about 90 miles on them and noticed a few things. At certain RPM's the cats seem to introduce a vibration into the car around 3500 4000. I also noticed that under WOT the car seems to ok but under normal to slow driving there is a raspy sound given off. This sound seems to come and go. And finally when I sit idle and get on and off the gas a little im getting a light rattle.
Now all that being said I did install the shims and seemed to have plenty of room between the x brace and the exhaust. Im curious how many people that own these have these same issues, and is there something you did to fix any or all of these issues. I know there are alot of threads that have various stuff in them but I wanted to start a new one
Any feedback would be great....
Old Feb 14, 2004 | 12:40 AM
mgl's Avatar
mgl
no rattles here.
it get a little raspy at high rpms, but its bareable.
it did seem to lower my exhaust piping a little, but lowered enough to slightly scrape my y-pipe on a huge driveway hump.
Old Feb 14, 2004 | 01:10 PM
OCG35Coupe's Avatar
OCG35Coupe
Originally posted by mgl
no rattles here.
How long have you had the RT Cats? Is that the stock Y-Pipe you scraped? Do you have aftermarket exhaust?
Old Feb 14, 2004 | 01:24 PM
tylerdurden's Avatar
tylerdurden
I just had mine installed today also. I paired the cats with the Nismo exhaust and stock headers. I drove approx. 45 miles with nothing noticeably vibrating. I even toasted a teenager in a GTI who got intimidated by the new growl. I've seen a bunch of threads with complaints of that same vibration. I'm sure something will pop up though, always seems to when the mods start.
Old Feb 14, 2004 | 02:03 PM
lotus's Avatar
lotus
Yah the vibration seems to be in 4th gear around 4k rpm's.
Im going to try and lower the brace a bit more ....
Old Feb 14, 2004 | 03:14 PM
pimp1911's Avatar
pimp1911
I had the problem. But not now. I had to double shim. There is about a 1 inch gap between exhaust and brace. Be careful going over speed bumps.
Old Feb 14, 2004 | 04:57 PM
mgl's Avatar
mgl
i had the cats for close to 2 months. i still have the oem ypipe and exhaust.
Old Feb 14, 2004 | 05:32 PM
lotus's Avatar
lotus
Going to try to double up the the spacers. I noticed while driving today the cats add alot of volume to the Nismo exhaust when you get on it even just a little. They are quiet when cruising. Still undecided if the increase in volume is ok or not. Still hoping the vibration goes away.....
Old Feb 14, 2004 | 06:51 PM
EL Diablo's Avatar
EL Diablo
Had my R/T Cats installed today. Put 100 miles on them and no rattles. Just loud as hell ! especially once you pass 2500 RPM's.
Old Feb 15, 2004 | 01:57 PM
tylerdurden
Where did you get the extra shim. I'm getting the vibration during warm ups. It goes away when the engine and exhaust heats up.
Old Feb 15, 2004 | 02:20 PM
ajk4's Avatar
ajk4
yea, I totally agree. on the first z, i had the borla td exhaust w/ stock cats, and it didn't increase the volume, just the exhaust tone. but after putting both the rt cats and the borla exhaust on my new z, i was blown away by the volume change. with the rt cats, it makes the exhaust considerably louder. i never really understood why people called the borla's sound like a muscle car, but with the rt cats i would have to say this is true. to my ears its a good sound, but just loud as all h@ll!!
Old Feb 15, 2004 | 02:36 PM
Philthy's Avatar
Philthy
Boost Junkie
I'm installing the RT cats tomorrow, and I'll get it on a dyno by weeks end - if the weather holds...
I know you'll never see them unless you're up on a lift, but damn they're sure pretty... very impressed with the finish and craftsmanship.
Old Feb 15, 2004 | 02:37 PM
lotus's Avatar
lotus
Doubled up on the spacers solved the rattle problem. Vibration seems to be gone. After driving alot today only thing I dont like is how much louder the exhast is. Power is great cars pulls harder now thru all gears but I might go back to stock to get the original tone of my Nismo back...
Old Feb 15, 2004 | 02:38 PM
Philthy's Avatar
Philthy
Boost Junkie
Do you have any pics of your install?
Old Feb 15, 2004 | 02:48 PM
Philthy's Avatar
Philthy
Boost Junkie
Old Feb 15, 2004 | 03:48 PM
lotus's Avatar
lotus
No sorry =(
Old Feb 15, 2004 | 04:23 PM
pimp1911's Avatar
pimp1911
You can use washers to shim as well.
Old Feb 15, 2004 | 04:26 PM
pimp1911's Avatar
pimp1911
Give it about 200 or 300 miles. And then see how it sounds.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
