High Pitch Noise At 80??
Old Dec 24, 2002 | 07:42 AM
skipp69's Avatar
skipp69
Question High Pitch Noise At 80??
Just A question, I have about 2000 miles on my Z and above 80 miles an hour I experience a wine noise. Somthing similar to what you might hear if your CV joints or rear end where going out.. Anyone else experiencing this or somthing similar? I've inquired with the dealer and they have expressed that it is nothing to worry about.
Skipp69
Sandiego Ca.
Old Dec 24, 2002 | 08:01 AM
black300zx's Avatar
black300zx
I have 4000 miles on my and just started to notice a similar noise around 80mph, it's almost like a whistle noise. If you get off the gas, it stops, if you press the gas again it comes back. It's not very loud, but it's notisable if the radio is a lower level. Could this be the same problem? I'll be interested to know if other have heard this and if it is indeed normal.
Eduardo.
Silverstone Performance
Old Dec 25, 2002 | 01:14 AM
cuki570's Avatar
cuki570
It doesn't have to be at 80, you can hear that whistling noise every time you step on the gas a little bit(with no radio). It really bothers me since I don't really listen to my shitty bose and have to listen to this whiny noise. I didn't notice this noise until approx. 2000 miles
Old Dec 25, 2002 | 08:38 AM
VandyZ's Avatar
VandyZ
Same here!
Old Dec 26, 2002 | 07:02 AM
chicago350z's Avatar
chicago350z
Originally posted by VandyZ
Same here!
is it the fuel pump? i can hear mine at idle
Old Dec 26, 2002 | 05:29 PM
DIGItonium's Avatar
DIGItonium
gawd i hate that buzzing motor noise... it reminds me of
some electric car.
G35c doesn't have that sound.
Old Dec 27, 2002 | 10:25 AM
chicago350z
yeah - i think you are hearing the fuel pump. i can hear mine at 80 w/ everything off (radio, etc.)
Old Dec 27, 2002 | 03:04 PM
black300zx's Avatar
black300zx
Does this indicate a faulty fuel pump or is it normal? Should I be concerned enough to take it to the dealer?
Old Dec 27, 2002 | 03:12 PM
N1k0's Avatar
N1k0
Default High Pitched Noise
I heard this sound for the first time at ~1200 miles. Somewhere around 80 MPH if you are on the gas, you hear a sound similar to whine of in a seat on comercial jet airliner. Let off the gas, and the sound goes away. Should I contact the dealer?
Old Dec 27, 2002 | 05:26 PM
ares's Avatar
ares
Veteran
its the fuel pump, I used to hear it over the radio in my truck that had a 5.9 liter engine, it needed lots of fuel.
jeez, I think Im gonna leave this section now. Ive never read so many people complain about the stupidest stuff. I know youll all jump on me for calling all this stupid, but it is. the only problems Ive seen worth worrying about is tire issues, maybe some alignment problems and the rest were restricted to maybe one or 2 cars.
stop worrying! all of your cars are fine! man, try a mercedes some time, its in the shop once a month, for real problems, like blown AC, or bad tranny. the Z is hardly a problematic car, everyones just getting so worried about it. like automotive hypocondriacs. worry about it once something actually goes wrong.
Old Dec 28, 2002 | 09:51 AM
chicago350z
this is normal. this is a high-performance car and needs a large fuel pump. the sound is damped in higher-end cars.
actually, if you have ever been in a car with an aftermarket turbo or S/C, the pump is usually upgraded and sounds 10X louder than this.
and by the way ares, i don't think this is a stupid question. he was simply asking if this was normal operation.
Old Dec 29, 2002 | 11:26 AM
ares's Avatar
ares
Veteran
the original question was, but the 5 following asking if theirs was broken was a little over done. owell.
Old Dec 29, 2002 | 11:34 AM
ttheisen93's Avatar
ttheisen93
Skipp,
If you ask the clerk at the liquor store to put the bottles into those little individual paper bags, that "wine" noise should go away.
Craig
Old Jan 1, 2003 | 09:52 AM
cturbo28's Avatar
cturbo28
Smile gear whine
I had a whine at 80mph to 92mph when the car was under a load. this was fixed by the dealer by replacing the rear diff. no problems now
Old Jan 16, 2003 | 02:30 PM
longshot01's Avatar
longshot01
Default Same noise on mine. It is from the tranny.
I have the same noise and symptoms you are mentioning. I noticed (especially when car is cold) that it is very noticeable at 2K rpm and up. If the clutch is pushed in, there is NO noise at all. The minute the clutch is let out, whether in gear or not, I get an incredible whining sound. During normal driving, it sounds like there is a supercharger attached!
The car is currently in the shop awaiting approval for a new transmission at the suggestion of the technician.
Old Jan 16, 2003 | 02:37 PM
SD350Z's Avatar
SD350Z
Perhaps a vacuum leak? It follows the symptoms.
Old Feb 7, 2003 | 10:21 AM
skipp69's Avatar
skipp69
Default Thanks for all your comments and concerns
For all of you who though that my post was of little concern, i have news. The dealer informed me that one of my CV joints was defective from the factory. Thus causing the wine/rumble noise. if you have this same noise i would recomend getting the car into the dealer asap and get it fixed.
Thanks,
Skipp
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
