Tire FEATHERING: FYI
Old Apr 8, 2004 | 04:03 AM
  #2601
kbsig106's Avatar
kbsig106
Exclamation Pilot's take longer to wear - that's all!!!
Harder compound tire which will take longer to show the abnormal wear - either way the tire will go bad, just not in the same amount of time as the RE04's.
It's not a fix - it's a delay move on NNA's part. Because all the TSB's in the world still can't "FIX" the problem.
So good luck - but don't count on the problem going away just becuase Pilots were put on.
Old Apr 8, 2004 | 04:28 AM
  #2602
web guy's Avatar
web guy
Default Re: Re: New Tires ...again
I posted earlier about a possible class action but failed to provide the link to the site:
http://www.nissantireproblems.com/class_action.php
Old Apr 8, 2004 | 11:11 AM
  #2603
overZealous's Avatar
overZealous
Default Re: Re: Re: New Tires ...again
One possible stumbling block to that class action:
From 15 USC 2310...
3) One or more warrantors may establish an informal dispute settlement procedure which meets the requirements of the Commission's rules under paragraph (2). If -
(A) a warrantor establishes such a procedure,
(B) such procedure, and its implementation, meets the
requirements of such rules, and
(C) he incorporates in a written warranty a requirement that
the consumer resort to such procedure before pursuing any
legal remedy under this section respecting such warranty, then
(i) the consumer may not commence a civil action (other than
a class action) under subsection (d) of this section unless
he initially resorts to such procedure; and
(ii) a class of consumers may not proceed in a class action
under subsection (d) of this section except to the extent the
court determines necessary to establish the representative
capacity of the named plaintiffs, unless the named plaintiffs
(upon notifying the defendant that they are named plaintiffs
in a class action with respect to a warranty obligation) initially
resort to such procedure. In the case of such a class action
which is brought in a district court of the United States, the
representative capacity of the named plaintiffs shall be
established in the application of rule 23 of the Federal Rules
of Civil Procedure. In any civil action arising out of a warranty
obligation and relating to a matter considered in such a
procedure, any decision in such procedure shall be admissible
in evidence.
In other words, you can't intitiate a class action except as noted here unless you have first submitted to the Manufacturers Certified Program. A better approach is to satisfy your State's Lemon Law threshold as quickly as possible and enter the Certified Program (BBB Autoline), if it exists in your State. You will have a decision in 40 days that is binding on the Manufacturer and not you as opposed to waiting years for some class action.
Disclaimer: I am not a lawyer but I could use one right about now.
Old Apr 8, 2004 | 08:26 PM
  #2604
Toby's Avatar
Toby
Had tires replaced and realigned at dealership at approx. 8,500 miles due to feathering. I again have the same exact problem at around 18,000 miles (getting same mileage out of new tires/alignment)..feathering and roaring noise at low speeds and stopping. What do I do now? This is very frustrating.
Old Apr 9, 2004 | 05:42 AM
  #2605
ezchief's Avatar
ezchief
Just a thougth but being in Bossier City, you could head over to Binyon's and try some lady luck on the slots. Or get a couple of Ape's from the security force and start cracking some heads at NNA
Old Apr 9, 2004 | 07:03 AM
  #2606
web guy's Avatar
web guy
Default Re: Re: Re: Re: New Tires ...again
From 15 USC 2310...In other words, you can't intitiate a class action except as noted here unless you have first submitted to the Manufacturers Certified Program. A better approach is to satisfy your State's Lemon Law threshold as quickly as possible and enter the Certified Program (BBB Autoline), if it exists in your State. You will have a decision in 40 days that is binding on the Manufacturer and not you as opposed to waiting years for some class action.
This isn't accurate. The quote you provided has been held by the 3rd circuit court of appeals to be ineffective based upon the programs non-compliance with 16 CFR Part 703. The case that reached that holding was litigated by one of the firms that I deal with on my site.
Old Apr 9, 2004 | 07:21 AM
  #2607
overZealous
Default Re: Re: Re: Re: Re: New Tires ...again
That would be a case involving Nissan's certified program? Do you have a reference? Just curious as the prerequisite for cetifying, at least in Fla, is compliance with 16 CFR 703 and because, obviously, it would have to specifically apply to the Manufacturer's program for the vehicle involved in the class action. In this case, an individual would probably fare much better and in a much shorter period of time with a Lemon Law claim as opposed to a class action provided that window of opportunity has not been closed. The last class action that I was a party to netted about $1.91 for me from Citibank.
Old Apr 9, 2004 | 07:56 AM
  #2608
web guy's Avatar
web guy
Default Re: Re: Re: Re: Re: Re: New Tires ...again
This is not a lawyer's website and we do not wish to make it one. The purpose we are all trying to promote is resolution of the problem for all affected consumers. From experience we know that can be done that without going through the program referenced and if you chose not to agree, it is your right and we respect it.
Old Apr 9, 2004 | 06:38 PM
  #2609
BigNDFW's Avatar
BigNDFW
Default Pilot Sports
Ok some have a problem with complex questions. Let me try again.
Has anyone replaced their Bridgestones with the Michelin Pilots?
If so have you put any miles on them yet?
How are they wearing?
Yes they are a harder rubber compound. They are not quite as grippy as the Bridgestones and the ride seems to be a bit stiffer accompanied by a little more road noise than the new Bridgestones. I also noticed that they dont seem to have as flat of a tread as the Bridgestones so I am hoping there will be less scrub on the inside and outside edge of the tire. Just my .02.
D
Old Apr 9, 2004 | 08:21 PM
  #2610
danotto's Avatar
danotto
Default Re: Pilot Sports
I have Michelin Pilot Sports A/S and really like them. I have not noticed the feathering yet, but like you said they are a harder compound, so it might take longer to appear. I have put about 5k on them so far.
Old Apr 9, 2004 | 09:31 PM
  #2611
Boomer's Avatar
Boomer
D
I have 6600 miles on my Michelin A/Ss. I just had a set of Koni shocks put on and my installer realigned the wheels a bit to center the steering wheel. I don't have a wear problem since I discovered the 040s were beginning to wear abnormally at 1600 miles. I replaced the 040s because I hated them. I was lucky I did, otherwise I would have had serious cupping in 2-3000 miles on the OUTSIDE(too much toein). I plan to monitor the tire wear every 3-4000 miles and align if necessary. I believe changing both the tires, the weakneed shocks and monitoring will eliminate abnormal tire wear on the A/Ss. The 040s wear rating(UTOG) of 140 is unacceptable for use as street tires in my opinion. I like the A/Ss.
Boomer--my opinion, use it or lose it, I really don't care.
Old Apr 9, 2004 | 11:17 PM
  #2612
doc3763's Avatar
doc3763
Default My Tire Feathering Update:)
So.......The next day after I got my Z back I noticed my steering wheel was crooked. I left a message with the service manager telling him to call me back I needed to bring the car back in to get this fixed. I took a look at the alignment sheet and noticed they didn't even touch the car until 5:02. I dropped the car off at 9:00am, and when I called to check on things late in the after noon they said the car would be ready at 5:00. They called back and said 5:15 later.
Well, I got no call back yesterday, and then someone else called back today to do a follow up. I'm pissed now b/c the service advisor never called me back. She left me a message telling me how important it is to get all excellent on the survey they will be sending me on the service. I call her back! More pissed now She answers..... I told her my steering wheel was crooked after the alignment and she asked if I could bring it in tomorrow and leave it. I said nope. I said that isn't my only problem. What you guys need to do is call Nissan between now and Tuesday when I am bringing it in and get approval to do more then just align my tires. I told her I did not understand why they had my car all day on Wednesday and did not just call Nissan to get the go ahead on the fix instead of doing a rush job at 5 to get the RooooOAAaaaaRing car back to me. I offered to call NNA for them She said bring the car in Tuesday and she will make sure all is taken care of.
Apparently there are no TSB's on '04 tire feathering? So any work done on this has to get approval from NNA.
My fiance said she is going to wait for me in her car while I'm talking to the service advisor..lol..not going to be pretty.
To be continued............
Old Apr 11, 2004 | 05:39 AM
  #2613
lew f's Avatar
lew f
If it is not too late, file a Lemon Law suit against NNA
Old Apr 11, 2004 | 08:55 PM
  #2614
ml2316's Avatar
ml2316
this is kind of a random thought, but at this point anybody who has researched the z and knows of the feathering problem, but buys a Z anyway, then complains about feathering or tries to file a lawsuit... is an idiot. tire feathering has NOT been fixed in 04 Zs. don't buy one if you don't want feathering. buy an s2k or an rx8.
Old Apr 11, 2004 | 09:17 PM
  #2615
aznkukuboi's Avatar
aznkukuboi
my dealership guranteed no feather on their 04 modelz
Old Apr 11, 2004 | 11:08 PM
  #2616
doc3763's Avatar
doc3763
you get that in writing? lol
Old Apr 12, 2004 | 02:04 AM
  #2617
pulpz2's Avatar
pulpz2
Originally posted by ml2316
... tire feathering has NOT been fixed in 04 Zs. don't buy one if you don't want feathering. buy an s2k or an rx8.
Buy the S2k if you dont want the Z. Personally, I'd rather have a Z with feathered tires than an RX8.
Old Apr 12, 2004 | 04:31 AM
  #2618
cal_z's Avatar
cal_z
ditto
Old Apr 12, 2004 | 09:48 AM
  #2619
lew f's Avatar
lew f
The dealership I go too has already started experiencing feathering on the 04's
Old Apr 12, 2004 | 03:59 PM
  #2620
Pit Bull's Avatar
Pit Bull
Dealer put new front tires on my wifes 350Z last week. I noticed a big difference with the roar gone. My wife did not notice anything. I think that every owner has the problem but a lot of them don't notice it.
