Tire FEATHERING: FYI
Originally posted by Boomer
Don't worry about Caster. Go to a good alignment shop for a professional alignment by experts, instead of untrained part-timers at your dealership. Then take off the RE040s and use them only on track days, thats all they are good for. Get a good set of high performance tires using Tire Rack's Customer Surveys and, if you really want to be absolutely sure the problem goes away, change the shocks and/or springs. I NEVER got the problem because I replaced the tires and got a real 4 wheel alignment at 1600 miles.
A huge number of 03 and early 04 Zs were delivered out of alignment and the 040s won't come back even after alignment, unless you drive the **** out of them and spend most of your driving going around corners at high speed to wear out the OUTSIDE part of the tread. I can't believe this thread hasn't died, read what I've said and learn.
Boomer-my opinion and experience (Hell, I wrote the 1st Problem List on this site in 2002!), use it or lose it, I really don't care at all now, I sold my 03 Z 2 weeks ago and it was perfect, no abnormal tire wear at all after 10,000 miles+. HELLO!
Originally posted by ericf
Talked to 1800nissan today and they assured me that the problem is with the 2003 only. After reading this I'm buying a G35 instead.
My Z was an early 2003 (Build date in Sept 2002), my G is an '04 purchased Dec 2003. I loved the Z's ride and many other things. I did not love the tire wear, grease streaks on windows, TSB for the compression rod up front, driver's seat rocking on the rails until I put in the 6-point harness...nasty noise coming out of the tranny going into 3rd gear on downshifts, seemed like the '03 had a problem a month after the first 5-6k miles.
None at all so far with the G. Cross my fingers...and note that even the Pilots are only something like 220-240, they don't wear too long if your driving is 99% non-highway (mine is almost all backroads due to where I live).
Haven't seen much here on the 2004/05's, have these things gotten better, or we just seeing a runout of 2003 problems?
Until the warranty is expired, then YOU have to pay for new tires at about $ a pop. That's what happened to me.
Good luck,
Johntek
Good luck,
Johntek
Originally posted by InItIaLD
just for you guys to know, my dealer said they could not do anything about the 04's tire feathering, well.. just got off the phone with Alita from 1800nissan1, who was VERY helpful, she gave me a ref #, a dealer address and number who is known for great customer service, she asked for the names of the serv tech's at Gwinnett place nissan who did not help one bit, and she said my car would be adjusted in all depths, if the tires were too bad they would be replaced, if re-feathering occurs the car will be re-adjusted and tires replaced as often as they need to be until i have 0 feathering,cupping,roaring whatever, i suggest everyone call 1800nissan1 who has a problem, be formal well-mannered, be sure to say you are dissapointed in nissan, and scared to even drive your car... and they will do us justice
How can you prove that these Z's were delivered out of alignment?
Shocked as I am that this is still running, I'm now back at this thread since the Feathering has just returned. I haven't posted here in over a year and the October 2003 front replacement RE040s worked fine for about 13 months and 10k miles. I just had another bi-annual full alignment, less than 60 days ago, just to keep up with things and prevent this from recurring [oh, well...]
At this point, with 21,000 miles, at 27+ months in service, the rears are done and it's time to switch to Kuhmos, go up a bit in size with a lower aspect ratio and be done with these half-a$$ed Bridgestones. Good riddence!
Originally posted by mike952
I had 2 2003 models and was indecisive beween G35 and the Z...after the accident I had the opportunity to decide again. -- I chose the Z again (2005).
No problems yet...4000+ miles already.
I had a 2004 Touring that I purchased in Feb and traded it for a Toyota Sequoia in Aug 04 because of the tire feathering. A guy I work with also had a 2004 and traded it for a Titan because of the tire problem. I am watching the 2005's closely and really want another 350. I like the aniversary but want a red one which is not avail in the aniv model. I spoke with a service manager today about my situation because the salesman had no clue. I asked him if there were any modifications done to the 05 suspension to fix the problem. He said that some "tweaking" had been done. I asked directly, did they change any hardware. He said in a conversation that took forever that they beefed up the mechanism that adjusts and keeps the car in allignment. I asked for something in writing that talked about the modifications and he could not provide it. If the problem is fixed in 05, I am in there. Pleas let me know if you have any feathering with your 05. Thanks.
Bueno
waynebunker@peoplepc.com
bunker, my situation was much like yours. I kept my 2004 Enth for one year and 2,750 miles before feathering set in. Since I drove it so little, I had originally intended to keep it till the cows came home, accepting that I might have to change tires every 3 or 4 years. But, the more I thought about it, the more it just pissed me off. I sold it and my old S10 driver and I now drive a 2005 Avalanche (I had a 2002 Avalanche before the Z) and love it.
Nissan's unwillingness to confront the issue with honesty has driven me away. What a shame! It was a pleasure to drive. BTW, I've owned 7 Nissan vehicles, 5 of which were Z's.
With regard to your question, I don't believe Nissan will ever own up to a mechanical fix unless they can relate the fix to something other than feathering. I think they've dug this hole too deep to admit to a fix designed to correct the feathering.
GM is known for not taking care of issues. Example, the V8 in your Avalanche will start having Piston Slap and GM is going to tell you that it is "normal". I sure hope you are lucky and don't have any issues with your new ride.
Originally posted by Pit Bull
Ronny you went from Nissan to GM because you felt that Nissan was "unwilling to confront this tire feathering issue"? WOW, I hope you don't have any problems with your Avalanche or you will find out what the definition of "unwilling to confront an issue is"
To be honest, it didn't take much for me to decide on the change because it was apparent that I was going to get very little use out of the Z, unlike my previous Z's. I put 2,700 miles on it in the first 12 months, and it was apparent that wasn't going to change a lot. That's just poor money management.
In my opinion, Nissan has cut and run on the feathering issue. They have taken what they think is the cheapest way out. Even after over two years of experience with the issue, my dealer's canned response was classic ********. I played dumb just to see where it would go. It went everywhere but the real source of the problem. I just didn't want to put up with that ******** for the next several years; I'm not young, you know.
I have spent a lot of hours on the GM forums and have read a lot about the piston slap. I believe they've lengthened the piston skirts to resolve it. Both my two previous 5.3's didn't have it. I've got my fingers crossed. One thing about piston slap, you can't deny it's there.
I've just turned 4K miles on my '03 Z and awaiting my tires to begin showing signs. I had the car into the dealer at 1K miles for an alignment check after the TSB. Everything looked fine - no adjustments. Dealer picked up the tab for that. Since the RE40's are extremely low wear rated tires I wouldn't expect too many miles anyway. I've had the same -camber wear on other cars with similar set up and high performance tires (although the RE40's are way overpriced for the tire you get)...........I still feel like this Z is great bang for the buck.
daequitz, don't get me wrong. The Z is a pleasure to drive. For the price, it's a piece of work; that's good work.
Actually, before I bailed out, I seriously looked at a G35. Frankly, it's another great car; very Z-like. But, would have been in pretty much the same situation as with the Z; just not getting my money's worth out of it. I came to that realization before I put up my money.
I do everything in the Avalanche. It just made more sense. I should thank Nissan for forcing the decision on me.
Still wish I had the Z for sunny days. Wish I was rich.
Ronny I think your right that GM fixed the Piston slap in the 2004 and 2005. Enjoy your ride
By the way you can now tell everyone that you drive a "Sport Luxury Utility Truck" (****)
Personally I've ridden a few of them in my life time. Enjoyed everyone of them.
Originally posted by GaryK
Sorry I wasn't able to reply sooner, been very busy. Part of my argument was that this is a design flaw, which was met with lies from the Nissan rep, and the arbitrator didn't seem to comprehend the technical aspects that would prove this. In a nutshell, the problem we are having is usuallly caused by exessive caster, and since this is not adjustable there is no way to fix the problem. I presented supporting documentation to validate all of my claims, but to no avail. In my case it was a lost cause, and a waste of about two days of my time to deal with this through the BBB.
My experience with the BBB has been horrible every time, so my expectations were low when I submitted to their program. They seem to not really care about supporting consumers, at least in my dealings with them. Their attitude is , and this is actually a quote: "Its a free service, so you can't expect much". And they strive to live up to that one.
There are obviously some people that have been successful using the BBB for the LL resolution. Those people apparently got lucky and had a decent arbitrator and/or rep from Nissan. I envy them.
Originally posted by mark77
I am having the a delay problem with my dealer in Kennesaw, Ga. They claim tires are on back order, but it's been nearly seven weeks since I first went to them about the tire problem.
Is this normal or am I getting the run around from the dealer?
Well guys I'm outa luck. I previously contact Khron and Moss to look into what they could do against Nissan, and the result... nada...
So basically Nissan wins. I guess I better get use to hearing that tire roar...
Dear Matt,
We have completed our investigation of your case. Upon our complete review, we have determined that we are unable to represent you further in this matter. Our decision is based on our perceived chances at success, as well as the economic commitment we would have to undertake to prove your case. Thank you again for the opportunity to review this matter and good luck.
Sincerely,
Krohn & Moss, Ltd
3 Summit Park Drive Suite 100
Independence, Ohio 44131
(216) 901-0609
(866) 861-1390 Fax
email: georgiapnc@consumerlawcenter.com
web: www.krohnandmoss.com
Sincerely,
Krohn & Moss, Ltd
(216) 901-0609
(866) 861-1390 Fax
Of course you can buy a lot of tires for $15K.
I have a 2004 Base 350Z and this tire issue started to surface around 9000 miles. I've had a HORRIBLE experience trying to get this fixed, and as of right now both Nissan and my dealership flat out told me that they can't help me.
It's a real shame too. I called 1-800-Nissan1 and spoke with an extremely rude fellow named Aaron. I was polite the entire time, yet he had a hostile tone to his voice from the start. When I told him that the tires are so bad that I'm even afraid I might get in an accident, he said, and I quote, "Are you trying to give me an empty threat?". He also went on to say that my complaints weren't valid and that whatever I try to do in terms of complaints will always be re-directed to him (in other words he's telling me that there's no way Nissan will help as long as he's working)
It's just been an absolutely horrible experience with Nissan. I used to have such respect for the brand and what it stood for, but after dealing with this issue I'm going back to BMW. They've always had good service.
Does anyone know how I can contact someone higher up in Consumer Affairs? I'd like to write a formal letter complaining about the service I've received. If anyone has a mailing address or email I can send a letter that'd be great. I'm looking at a supervisor level or something higher. I don't want to deal with the service reps anymore. Thanks in advance for the help.
Originally posted by bnbutler
I did it! I went in and traded my 2003 (built in 11/02) Z for a 2004 white touring roadster with the navy blue top. Boy is it ever hot. LET'S KEEP OUR FINGERS CROSSED THAT I DON'T HAVE THE FEATHERING AGAIN!
The grease streaks are gone.
And the ride is smoother.
