Tire FEATHERING: FYI
Originally posted by pulpz2
Do you want tire problems or turbo problems???
LOL
I had the engine and the turbo problem on my RX7 (hence the reason I don't have it anymore)
Since my Z now has 26k on it, the dealer said that he couldn't even do the alignment under warranty, and wanted to charge me $85. Is that a fair price for an alignment, or should I take it somewhere else? Does anyone have the right specs so that I can make sure it has been aligned to those specs? And is anyone aware of any tires other than the Potenza's which will wear better and not feather as easily? I do a LOT of freeway driving, and have no windy roads in the area, so from what I am reading, I am a prime candidate to get feathering, as I have already had it twice now.
I had my alignment performed at an independent tire and brake shop that specializes in Mercedes, BMWs, Porches, and sports cars for $60. They laughed at the settings in Nissan's TSB that came out 0n 4/12/2004 for the extended tire warranty.
Don't worry about the correct numbers. If the shop is competent they will align your car to their specifications.
I also had them replaced my worn out rear tires and front feathered tires (3rd set) with Good Year Eagle F1's. I have 4k miles on them so far and have no feathering. The inner and outer tread blocks are agressive on the Good Year Eagle F1's. Toyo T1's are also great tires. I have a friend that got over 16k miles on his '03 Track.
The ride is much quieter and smoother than with the stock Bridgestones.
Good luck...
Originally posted by Pit Bull
I hope you don't believe that??? OEM high performance tire that is not rotated, you will be real lucky to get 20K miles from the fronts and you will get around 25K miles from the rears. Feel good about the 15K miles, get it aligned, buy some better tires and enjoy the ride. The Z is a great car that is hard on tires. Had a 1991 Acura NSX that needed rear tires every 8-10K miles, great car, fun to drive and worth every rear tire I bought for it. These are performance cars not Honda Accords. If you really have to get 30-60K miles out of your tires get a family car. JMHO and experience.
My dealership told Nissan North America that my car's alignment was checked every 3750 miles when they performed an oil change and a 100 point inspection. My Z was in alignment every time yet at 14,700 miles I was told not to drive on my tires as they were worn almost to the belt on the inside section.
Now maybe you feel this is normal but something here stinks to me. Am I really expected to go out every 9K miles and purchase a front alignment and new tires??? If so I will have to do that 3 times a year. That's $2100 on just the front weels and then add one set for the back and I'm spending $2800 a year to drive my Z without road roar and vibration. Had someone disclosed this to me before my purchase I would have walked.
[i]
I now have 15k miles on the original tires with about 8-10k left. I will be getting another alignment soon. I’m thinking about 0.1 degrees total toe instead on 0.2 degrees total toe because too much toe-in will cause feathering on outside tread blocks whereas too much toe-out will cause feathering on inside tread blocks. [/B]
Who am I to believe???
My Nissan dealership has serviced my two Pathfinders since 1997 with no issues to report.
The independent guy has nothing to gain except maybe my tire alignment business.
However, Nissan North America took 71 days until they had someone return call even though I called them 11 times. Nissan North America is in a class action lawsuit for '03 and '04 Z's.
I want to believe that there is no design issue with my Z but I'm just not convinced yet.
Originally posted by un7oucha8le
oh ok. I just heard today from a fleet manager that the reason it was started in the first place was due to the way they were shipped. But yeah since they were in the big crates and when they lowered them, it caused the front frame to bend itself, which caused the feathering. but yeah anyone else hear this from any dealer or anyone?
-Mark
-Mark
Originally posted by WNC350ZR
He said the tire problems were caused by the way they were strapped on the underside while being shipped over to the US. Since then they strap the Z's down using another method that doesn't knock the front end out of alignment. Because they caught this problem and corrected it early, no 2004's qualify for the 2 years free tires and alignments.
If you are interested in more info on alignment read this thread:
https://my350z.com/forum/showthread....threadid=92147
PM me with you email address and I can email the April 2004 TSB to you.
Originally posted by cpoe52
msims:
Good luck...
msims:
Good luck...
I spoke to a man at Nissan North America and he claims that nothing changed between the '03 and '04 Z to correct the tire problems. He said the tire problems were caused by the way they were strapped on the underside while being shipped over to the US. Since then they strap the Z's down using another method that doesn't knock the front end out of alignment. Because they caught this problem and corrected it early, no 2004's qualify for the 2 years free tires and alignments.
If you believe that, I have a bridge I can sell you. IF it were true, then the problem really wouldn't exist in the '04's, yet is alive and well. I don't want to give up the car, so I'm going to take it to a well respected alignment shop up here, and put some new tires on the front. I simply don't have the time to fight Nissan, and furthermore risk having to turn the car in for a refund. I love my Z, and if I have to be creative and shell out a few bucks to keep the car, then so be it. Even though I'm very dissappointed in Nissan. Especially since this is my third Nissan in 10 years.
http://www.sheller.com/Practice.asp?PracticeID=145
pulpz2:
I posted my before and after alignment specs on the link you requested back on 11/5/2004.
pulpz2:
pulpz2:
I forgot to mention that when I went to the independent tire and brake shop at 17,000 miles the feathering had returned with Nissan's magic settings of the April 2004 TSB.
The independent tire/brake shop performed the alignment settings from my above post, NOT NISSAN. They laughed at Nissan's numbers.
Nissan will never remove my wheels, inspect my brakes or perform another aligment on my car.
Stevie Wonder could do a better job than NISSAN!
Because looking back at your toe settings posted on the other thread it appears that the independent shop set it right to the TSB spec. The TSB calls for total toe of 0.08” and no less than 0.04”. You are at 1/16” = 0.06”. So your toe is right on and you no longer see feathering.
I bring this up because I was little confused about what you where saying. I thought they set the toe to something other than the TSB recommendation.
After my realignment (the second one after the first was done wrong), my toe i s 0.08”. I think this is too much toe in because I'm now getting slight feathering on the outside tread instead of the inside tread. So this spring I'm taking it in and having the total toe set to exactly what you r's is, 0.06”. Hopefully this is the sweet spot.
Thanks
http://home.woh.rr.com/hixpage/350z_docs/
Sorry cpoe52, didn't make the connection. I do have a question about exactly what you mean by,
When you say they laughed at the setting do you mean that the alignment was not done correctly by the dealership or the independent shop disagreed with the new toe settings specified in the April04 TSB?
Thanks
Thanks
The technician laughed at Nissan's settings in TSB-NTB04-043 because from the top view looking down at the front tires they were set like this:
\\ _______ //
Of course this is exaggerated, but that was what I was told.
So far I have 4k miles on my new Good Year Eagle F1's with no signs of feathering. Still a little bit early, so we will see. Lucky for me I live in Southern California so I am still racking the miles on this winter.
pulpz2:
\\ _______ //
pulpz2:
\\ _______ //
\\____// negative toe (toe-out) - 1/32" : old setting (notice the minus (-) sign)
//____\\ positve toe (toe-in) 1/16" : new setting (per NTB04-043-actually you have 0.0625" and the TSB calls for 0.08")
Sounds like the technican did what the TSB said to do.
CAVEAT EMPTOR:
"My dealership claims that my Z was in alignment every 3750 miles."
Guys when you go to dealer to get service ask for a copy of all work done. Some rotten apples request that you sign for work done at "NO CHARGE" that the dealer submits to Nissan (or FORD, GM or manufacture) that the dealer gets paid for as warranty or TSB work. So these dealers will try not to give you a copy of these work-orders.
Most manufactures request that customer sign these workorders or dealer does not get paid for work. Rotten apples submit work but do not perform the work. This is not just for Nissan Dealers but all dealers.
One incident with a Ford dealer showed work for replacing an ignition switch under TSB/warranty but work was never done. When the switch broke, Ford headquarters had records that the repair had already been done by a dealer in another town. This may have been a clerical error but when a request was made for copy of signature on the workorder.....well work was performed.
As a habit, I sign for nothing unless I get a copy and can read what I'm signing, no folded workorders where they request signature in back or they show only line to sign at.
OK this is why I'm confused, according to your before and after alignemt data you have:
Maybe that was the way the car was aligned when I brought it in 5k miles after Nissan performed TSB NTB04-043 in April 2004. If I remember correctly he didn't spend much time looking at the copy of the TSB I brought in. He aligned my car to his machine's specifications. I know it was not a Hunter system. I could find out what kind it is if you want me to.
They align alot BMWs, Porsches, Mercedes and autocross cars.
The guy that did my alignment, only does alignments. He is their only alignment technican.
Originally posted by Zexy
I have a question. I don't know if it's been asked but this thread is HUGE. Does anybody here have an aftermarket suspension setup?
Originally posted by dnguyent
"What will it take to win against a mighty corporation like Nissan???"
Write letters to Nissan, and cc the letters to every car magazine (including online car reviewers like edmunds). Mighty corporations hurt when their mass products are flawed. I'd love to get a list of magazine editors with their addresses on file so that I can send them a copy.
If you're an activist you can distribute handouts at local auto shows with nothing more than a link to this website.
I guess I am one of the only ones who stuck it out and had my car fixed (at no cost to me). Hopefully those who gave up and are slamming the car are not accelerating my depreciation...
