Change Drive Belts Myself or Send it to a Shop?
I can't find the thread were someone said how to do it.
Should I do it myself or send it to the shop? Do I need airtools?
Changing the belts is pretty simple. The hardest part is making sure you have the tension set correctly.
In the diagram below, loosen nuts A, C - DO NOT REMOVE THEM!
Then loosen bolts B, D so you can slip the belts over the pulleys.
Reverse the process to install the new ones.
DO NOT overtighten nuts A, C or you'll wear out the bearings in those pulleys.
Originally Posted by ken350z
Is a gauge required to get the tension right? My belt squeals ever since I changed the crank pulley. Are the gauges expensive?
Most people do it by feel.
Originally Posted by Wired 24/7
Do you have to take off any major parts to do belts, or is it pretty do-able without removing anything?
It can easily be done on ramps or jack stands in your driveway.
Originally Posted by DavesZ#3
Besides the plastic underpan, nothing major has to come off. You just have to loosen the tensioning bolts enough to slip each belt over a pulley then they are loose enough to work their way out.
thanks Not that I need to do it now, just nice to know
Originally Posted by imntcrzy
I changed my belts the a couple weeks ago using my high tech finger defection measurererer thing. No problems no squeeks.
new belts will give a little after a few weeks. Just adjust the tension one more time if it squeals. Make sure you don't overtighten the first time. i've heard horror stories from a mechanic when belts were too tight.
