HID just went out!
Old Jan 17, 2007 | 10:50 AM
Tayzzer22's Avatar
Tayzzer22
Default HID just went out!
I bought my 03 used, (base) and the previous owner upgraded the headlights to HIDs. Now one of the lights went out so I need to replace them, but don't know how. Since I can't get in contact with the original owner I can't find out what brand HIDs they were or where to get them from.
I tried doing a search for 5-10 minutes but couldn't find anything. Anyone know how to check what kind of HIDs they are? Where to buy them? And is this something I can do myself? Or should I just take my car down to a local shop?
Any help is much appreciated! Thanks!!
Old Jan 17, 2007 | 11:00 AM
2005daytonaZ's Avatar
2005daytonaZ
https://my350z.com/forum/showthread....HID+conversion
I'm sure you can find out something in there.
Old Jan 17, 2007 | 11:42 AM
Tayzzer22's Avatar
Tayzzer22
Thanks, but it looks like he is selling only the full kits, not just the bulbs themselves. And I don't know what bulbs would work...
I guess I can PM Jun to see if he could forward me the installation instructions. Thanks for the help!
Old Jan 17, 2007 | 08:54 PM
showstoppertk's Avatar
showstoppertk
only way to know is to get underneath there and check it out for yourself. more than likely its just a cheap aftermarket hid kit, in which case the only real option is to buy a new kit or go back to using the stock halogens. it won't be cost effective to troubleshoot what is causing the problem and then try to buy a replacement for that single component on what is likely a proprietary and cheap kit in the first place.
Old Jan 18, 2007 | 08:30 AM
Ztalker's Avatar
Ztalker
your best bet is to replace the entire conversion kit with a new kit cuz the other bulb is likely to burn out soon. The base Z uses H7 bulbs. The newer HIDS(better/less expensive)are much easier to install than the older generation kits. Good luck.
Old Jan 18, 2007 | 08:39 AM
Tayzzer22's Avatar
Tayzzer22
So it would be easier to get an entirely new conversion kit than just getting two bulbs?? wow.. how much are the new/better kits? where do I look? Thanks for the help people!
Old Jan 18, 2007 | 10:21 AM
Ztalker's Avatar
Ztalker
just do a search under hids online....there are so many of them out there to choose from. The cost of buying the bulbs alone ain't cheap...besides they might not be compatible with your existing ballast and ignitors. i'd go for a new conversion kit if i was you. i got an 03 with HID conversion also.
Old Jan 18, 2007 | 10:31 AM
mk12booze's Avatar
mk12booze
try this
http://sfbay.craigslist.org/eby/pts/264440604.html
Old Jan 18, 2007 | 10:36 AM
QuicksilverZ33's Avatar
QuicksilverZ33
Wow...that is 100% exactly what happened to me....i just took the hids out and put in reg bulbs not to deal with finding hid's and paying 100+ for a single bulb...I actually have 1 hid bulb and 1 ballast as a set laying around because of this...
PS: The bumper has to come off along with some other plastics pieces...if you plan of changing them...I did it myself...but is was a P.I.T.A.!
Old Jan 18, 2007 | 11:23 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
There's only 2 major types of HID bulbs I think. Take the bad bulb out and look at it. It shouldn't be that hard. It's easiest to remove the front wheel and get to the headlight from behind the fender lining.
Old Jan 26, 2007 | 09:10 AM
derek173's Avatar
derek173
I have two stock HID Bulbs for sale if you are interested, they are from my 03 coupe used very little before replaced.
PM me if interested
Old Jan 26, 2007 | 09:18 AM
derek173's Avatar
derek173
also Yes you can replace the HIDs yourself, Very easy, remove front wheels, remove fender lining clips..thats it.
IMO...Aftermarket HIDs are hit or miss unless you get philips. Never had a problem with Philips HID bulbs or ballasts which I had in my old car, 1996 accord.
Old Jan 26, 2007 | 09:21 AM
slowxturtle's Avatar
slowxturtle
just pull the bad bulb out using method mentioned in posts above and buy the same bulb on ebay! You can get a pair of bulbs as low as $55 shipped. I did. Get 6000k. The kit I bought was so old that the plugs didn't match the newer bulbs I bought, so I just cut the ends off and sodered the wires together. This is all done after the ballast, so the original wiring on the car itself will not be modified at all. If you need additional help, pm me after you've pulled the bad bulb out.
Pleask
Dec 21, 2021 03:17 PM
SirZaLot
Mar 4, 2003 12:34 PM
Daddy
Feb 4, 2003 11:13 AM
Mr Fairlady
Jan 28, 2003 06:08 PM
dvlad
Sep 15, 2002 07:48 PM
