vibration in the z
Old Nov 4, 2007 | 07:00 PM
ace350z's Avatar
ace350z
Default vibration in the z
hey, im not sure if there is any techs on here ( im still kinds new to the site) i have an 03 touring 350z and i know they are infamous for having bad tranny problems. my car has 14k miles. there is a strong vibration when i let off the gas and come to a stop. is this normal? if you know a little about cars, its like in an older car when a bearing goes out. that strong vibration but in the front on the z. any advice? thanks
Old Nov 4, 2007 | 07:38 PM
Rob10_99's Avatar
Rob10_99
Mine started doing the 3kish driveshaft vibration as soon as I installed the solid trans mount.
Any mods on your car? 14k is really low for an 03!
Old Nov 4, 2007 | 07:40 PM
ace350z's Avatar
ace350z
yeah but no mods
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Brake rotors or crappy tire
Old Nov 4, 2007 | 08:28 PM
ace350z's Avatar
ace350z
def not either of those.
Old Nov 4, 2007 | 09:04 PM
bamyi's Avatar
bamyi
It's still under warranty so take it to the dealer.
Old Nov 4, 2007 | 09:09 PM
ace350z's Avatar
ace350z
yeah i think its still under the powertrain warranty for 2 more months. and it seems like it would be a powertrain thing.
Old Nov 5, 2007 | 03:48 PM
Zrated's Avatar
Zrated
My car has done that since new in 2002. Vibration while decelerating, but not always. There was a topic about this a while ago. You are not alone with this. I don't think there is a fix.
Old Nov 5, 2007 | 05:31 PM
cheshirecat79's Avatar
cheshirecat79
Take it in to the dealer. Don't waste your time troubleshooting a problem that you don't have to.
What you describe isn't something normal that you should tolerate. The Z is noisy and tempermental sometimes but this doesn't fall under those categories.
That being said, make sure your wheels and tires aren't damaged somehow... just cover your bases.
Old Nov 6, 2007 | 08:20 AM
ReelBigAndy's Avatar
ReelBigAndy
I had a very similar problem when I bought my '03 with 29kmi back in june of 2007. I noticed it would grumble to a stop from about 20mph to 0. I recognized it during the test drive, and the techs replaced the front tires and the noise completely went away.
My assumption is that the previous owner had the the tire feathering TSB corrected, but left the feathered tires on. The opposing camber of the tires (now aligned properly) induced a load on the wheel bearings creating the loud vibration.
check your tread depth to see if you have feathered tires. Also, if your car is a manual), you can isolate the problem by turning your car off at 20mph, and slowing to a stop and see if the sound remains. putting it in neutral for this may also tell you where in your trans. the problem exists. Im not sure though, im not a tech.
good luck!
silverstoned
Jul 12, 2003 02:47 PM
ss350
Jun 18, 2003 10:27 AM
FCallender
May 19, 2003 01:45 AM
jaxxxx
May 6, 2003 08:26 AM
Daytona Blue Z in Bo
Feb 9, 2003 04:24 PM
