octan gas
Old Jun 12, 2003 | 08:50 PM
GY-Z's Avatar
GY-Z
Default octan gas
wat kind of octan gas Z33 driver's usually using?
will it do any harms if we have a higher grade of octane gas than what the owners manual says?
or will the total distance u can travel decrease?
thanks for the information
Old Jun 12, 2003 | 10:22 PM
n8vz's Avatar
n8vz
i run 91 pump since that is the grade for premium gas in CA. In theory, running higher octane then specified for the engine can only hurt your wallet. Actual performance gain is questionable. But running lower then speficied octane can increase pinging and lead to engine damage.
BTW, anyone know what kind of gas are specified for other Nissan 3.5L VQ equipped cars. Since Altima 3.5 is only 'rated' at 240Hp..does it require only 87 octane or does th that car also require premium grade?
Old Jun 13, 2003 | 06:21 AM
Z'd's Avatar
Z'd
Altimas only require 87 octane, but 91 is recommended for better performance.
Old Jun 13, 2003 | 08:09 AM
AZ350Z's Avatar
AZ350Z
Default 100+ Octane
I have run 3 tanks of $4.99 100 octane gas now and see absolutely no difference.
Save your cash and run 91.
Old Jun 13, 2003 | 08:26 AM
n8vz's Avatar
n8vz
what brand of 100octane gas do you folks get in AZ? Here in Cali, some Unical 76 carry "Nascar Fuel" which i think is also 100 octane, but it runs more like $5.50/gallon if you can find a station that has them.
Old Jun 14, 2003 | 04:08 PM
Stilyle's Avatar
Stilyle
I fill up the car with 94 Octane (Sunoco) only.
Old Jun 16, 2003 | 05:54 AM
dr_gallup's Avatar
dr_gallup
Significantly higher octane than required can actually reduce performance and milage due to reduced speed of combustion. Stick to what is recommended unless you are using forced induction, then you will need all you can buy. 100 octane gas in a stock motor is a major waste of money.
Old May 27, 2005 | 10:09 AM
Grottizy's Avatar
Grottizy
Default I have ran 100 oc
I run 100 oc some times to clean the jets i do notice a small dif in how the car runs all though I know its not needed all the time I also get to tell people im runing 100 oc lol makes me feel cooler haha
Old Jun 1, 2005 | 09:58 PM
DAYTONA-ZED's Avatar
DAYTONA-ZED
Could probably get away with 87 octane ,but performance maybe down and pinging up.
Old Jun 2, 2005 | 05:14 AM
DomZ's Avatar
DomZ
93, nothing less. When I go to the track, I try to mix 1 gallon of 103 with 3 gallons of 93 (the ECU can't adjust too much more past 94 from what I understand)
Old Jun 5, 2005 | 09:10 PM
justock's Avatar
justock
I'm not sure that higher octane is cleaner. I thought that cleaning finction was mostly related to the detergent additives in the fuel like Chevron's techron and etc. I thought that octane relates to resistance to premature combustion from compression--but I am no expert.
Old Jun 6, 2005 | 07:17 AM
Stailey's Avatar
Stailey
93 Only... nothing less
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
