How-To Repair Stuck / Broken Window Motor ...
Old Aug 23, 2009 | 10:36 AM
  #241
35oZephyR's Avatar
35oZephyR
Originally Posted by SILKZ03
Wow...guess I better get started. Tired of banging on the Door...people see ya...kinda embarassing.
Tell me about it...
Driving around with window down on a warm summer night = bliss.
Sitting in the parking lot banging and swearing to get the window up, while pedestrians wonder "wtf??" = Lose.
Deciding to go fast-food one late night and window decides to be stuck = Lose
Getting pulled over and having an officer wonder why you're not complying = Lose
I hate you Nissan... bait us with a stylish car and great motor and we get fail for everything else.
Old Aug 23, 2009 | 12:53 PM
  #242
SILKZ03's Avatar
SILKZ03
nuff said bro!
Originally Posted by 35oZephyR
Tell me about it...
Old Aug 25, 2009 | 12:00 PM
  #243
island03z's Avatar
island03z
If anyone had a problem like I did getting the motor back into the casing because the brushes were in the way. I cleaned the side walls next to the brushes so that I could use scotch tape to hold the brushes back against the spring (otherwise its really greasy and the tape won't hold). Be sure to leave enough tape exposed so that when the motor is back in the casing you can gently pull the tape back out. Spinning the motor while pulling the tape helped a lot. Then just add a dab of lithium grease and you're good.
Old Aug 28, 2009 | 07:46 PM
  #244
SILKZ03's Avatar
SILKZ03
okay...just got around to doing mine. I replaced the motor with a refurbished one instead of cleaning it....Since some guys said the cleaning lasted a couple of months, I thought I would just go ahead and purchase one with a waranty. Thanks for the write up. Everything worked and the instructions for reset is a must.
Old Aug 30, 2009 | 07:42 AM
  #245
Alterscape's Avatar
Alterscape
I'm probably going to be trying this repair (to install a new drivers-side motor) in the next couple of weeks.
I don't know much about the Z (yet!) but I do know photo/video gear. Has anyone tried to use gaffer's tape (or painter's tape) in place of duct-tape to hold the window up? It'll have MUCH less residue than duct tape and peel off easier, but I'm not sure if the adhesive is strong enough..
Old Aug 30, 2009 | 10:08 AM
  #246
35oZephyR's Avatar
35oZephyR
^^^Towel + Visegrips (if you have them)
Old Aug 30, 2009 | 12:58 PM
  #247
blaukal's Avatar
blaukal
I've been fighting this for about 4 months on my 04 roadster. Just followed the cleaning DIY and everything is coming up roses. I love you VO. In a platonic way. Now I'm crossing my fingers that it will last a while.
Old Aug 30, 2009 | 06:58 PM
  #248
Alterscape's Avatar
Alterscape
Good call re: vise-grips. I like that idea, and I have a set intended for woodworking w/rubberized grips that, plus a towel, would probably be very kind to the glass. Also, thanks VO for the incredibly detailed instructions. I usually disassemble smaller-scale finicky electronics, but those pics and detailed instructions make it seem approachable!
Old Aug 30, 2009 | 08:45 PM
  #249
SILKZ03's Avatar
SILKZ03
I used a nonresidue duct tape...no issue.
Old Aug 31, 2009 | 12:19 PM
  #250
nick2730's Avatar
nick2730
For the people that used this DIY and it worked successfully for you:
When actually pressing the switch itself, did it sound like the motor was trying to work before you cleaned up the motor? Or did you just hear a relay click and nothing else?
Does anyone know what the voltage should be across the wiring? And or a wiring schematic on the door?
Old Aug 31, 2009 | 01:57 PM
  #251
35oZephyR's Avatar
35oZephyR
It's almost all mechanical with exception to the motor's internals. The biggest issue you'll probably have during the disassembility will be lining up the window frame bolts when you put everything back together.
IMPORTANT: try not to over-tighten the gold/bronze bolts. Those will strip and next thing you know, your door rattles.
Old Sep 2, 2009 | 02:00 PM
  #252
Tony'sz's Avatar
Tony'sz
I just did my driver side repair and reset today and it took me a little over an hour, very simple and a big Thanks for the DIY it helped out allot and saved me some $$$$$$$$$$$!
Old Sep 3, 2009 | 10:13 PM
  #253
Chomorro's Avatar
Chomorro
Mine just went out today...Until i hit the inside door.
Autozone has this part for 144.99 Autozone window motor
Or Nissan part is 203.95 Oem nissan Parts
So im thinking 60 more for a new motor is a better deal correct?
And why does banging on the door make the motor work again? Sounds like a loose connector instead of a bad motor, but all of your experiences point to no on that lol.
Old Sep 4, 2009 | 09:32 AM
  #254
35oZephyR's Avatar
35oZephyR
If your's is broken for the first time, just take it out and clean it. They're all from the same flawed design anyway so you might as well make sure the current one is dead before taking life out of a new one. If you can't be bothered and rather spend the money then that's fine.
Hitting the door for it to work?
I'm going to say it's accounted to weak motor brushes that wear out and don't conduct enough current to make that initial spin. It seizes so when you agitate it, the brush is able to conduct enough to turn the motor.
I don't know a lot about electrical motors but that's what I gather from years with RC cars. Brushes wear out and you have graphite build up. They need replacing.
If this was the problem, then the motor is really just a brush replacement? I don't know if anyone has replaced the brushes but I know dealerships are not going to promote this. They rather sell you a whole new motor.
Old Sep 6, 2009 | 10:38 AM
  #255
Jay'Z's Avatar
Jay'Z
Im going to pull my door panel for a 3rd time to try and clean the inside of the motor.. I hope I dont have to buy a fawking motor....
Old Sep 7, 2009 | 04:24 PM
  #256
gto88's Avatar
gto88
Default Thanks, vo7848
I'd like to thank vo7848 who posted this repair instruction.
I just fixed my stuck window per your instruction.
vo7848, you are the man!!!
Old Sep 9, 2009 | 06:10 PM
  #257
Jay'Z's Avatar
Jay'Z
I did all of that, cleaned it etc.... Still doesnt fawking do the window reset....
Old Sep 17, 2009 | 05:15 PM
  #258
Chomorro's Avatar
Chomorro
For anyone who is still hitting their door to make your window go up. I never did it but i read some people do.
I thought that looked funny, so if you just open and shut the door it works the same . This is what i do and it has worked 100% of the time so far.
Old Sep 17, 2009 | 06:14 PM
  #259
SILKZ03's Avatar
SILKZ03
So far is right...thats just for now. I was doing the same thing just opening and closing the door. After awhile, then harder, then harder...then that didn't work...so I banged on the door, that did..after awhile that didn't work...just replaced the motor...f'k it.
Old Sep 17, 2009 | 10:53 PM
  #260
Chomorro's Avatar
Chomorro
Yea i figured that, i have a new motor sitting in my room waiting for some time to put it on
