Diff breather leaking oil?
Old Dec 28, 2008 | 05:37 PM
Lawn Dart's Avatar
Lawn Dart
Default Diff breather leaking oil?
I was doing my 60,000 inspection and I noticed oil on the rear subframe. I followed it up and found that the differential breather hose was leaking oil. I have a 2-way LSD and I beat on the car pretty hard, mostly at drift events. Does anyone have any ideas how to correct this problem? Could I put loops in the hose or a catch tank?
Old Dec 28, 2008 | 06:57 PM
Z_ology's Avatar
Z_ology
This is a common problem. Hard driving (cornering) leads to higher temps in the diff. I would recommend a Nismo rear cover or if you are really hard core a dedicated oil cooler for the rear end
Old Dec 30, 2008 | 01:56 PM
terrasmak's Avatar
Throw a longer tube on the breather, thats what most do. It happens to all of us.
Old Jan 26, 2009 | 11:49 PM
Barzten1's Avatar
Barzten1
Any pics of this?
Old Jan 27, 2009 | 04:53 AM
gothchick's Avatar
gothchick
Originally Posted by Barzten1
Any pics of this?
Of a longer breather tube, or a diff cooler?
Old Jan 27, 2009 | 06:24 AM
Barzten1's Avatar
Barzten1
Well my diff is leaking fluid and not sure if its the bushings or if its the breather. Its actually coming from a round thing right above the diff but I dont know what it is.
Old Jan 27, 2009 | 10:17 AM
gothchick's Avatar
gothchick
You mean this thing?
Old Jan 28, 2009 | 05:36 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
What fluid are you using in the diff? For heavy racing/drifting use, try Motul 75-140. http://www.forgedperformance.com/sto...cat=280&page=1
Most people are running 75-90 in the diff, but we are finding that the thicker 75-140 oil works wonders with heavy abuse.
Also double check that it's not actually coming from the stub axle side seals. Those easily wear out, and can start spewing some oil all over the place.
Old Jan 28, 2009 | 09:27 AM
Barzten1's Avatar
Barzten1
Sharif Ive been meaning to call you about this but I know your extremely busy. Ive been pretty busy too but hope to get under the car to take pics this thursday so I know whats leaking exactly. If it is my diiferential should I just replace the bushings? Todd was telling me to go with different gears all together. Don't know much about them and was wondering what you would suggest for my setup.
Old Jan 30, 2009 | 04:11 PM
Barzten1's Avatar
Barzten1
How bad does it look. Ive been driving it like this for a few weeks.
Old Feb 1, 2009 | 03:51 AM
ChuckW's Avatar
ChuckW
Looks like it's time to upgrade to a solid differential bushing too.
Old Feb 1, 2009 | 09:39 AM
weslutes's Avatar
weslutes
The Nismo diff cooler was the solution for me.
IIRC the breather tube dumps to the drivers side in/on the frame.
Old Feb 1, 2009 | 11:23 AM
Sharif@Forged
Forged Performance
Yeah. mine has never been even close to that bad. Yes, change right away to the Nismo finned diff cover, which we always use, and some Motul 75-140 gear oil.
Your look doesnt "appear" to be coming from the stub axles seals, but you can check that yourself to confirm. That looks like definate dripping from above.
Old Feb 1, 2009 | 12:33 PM
Barzten1's Avatar
Barzten1
So what is that round thing above the GT Spec brace?
Old Feb 2, 2009 | 02:20 AM
ChuckW's Avatar
ChuckW
Differential bushing. They are liquid filled until they wear out and lose their juice. That's why I suggested a solid one.
Old Feb 2, 2009 | 08:29 AM
Barzten1's Avatar
Barzten1
ohhh ok. Thanks guys
Old Feb 2, 2009 | 01:13 PM
gothchick's Avatar
gothchick
Looks like your diff cover is cracked.... That bushing/stud is simply for mounting the diff. No fluid should ever come out of there...
Old Feb 2, 2009 | 03:50 PM
ChuckW's Avatar
ChuckW
http://www.splparts.com/main4/parts/...me/default.htm
First paragraph has a link called "picture". Looks just like yours.
Old Aug 7, 2009 | 10:39 PM
ChuckW's Avatar
ChuckW
Which repair did you choose? Sometimes those bushings do release fluid, huh?
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
