battery
Old Jan 29, 2009 | 01:32 PM
murderedout350z's Avatar
murderedout350z
Default battery
anyboy know a good aftermarket battery to get mine is toast!!!
Old Jan 29, 2009 | 01:39 PM
And this is in the Buying/Leasing for what reason?
Old Jan 29, 2009 | 02:09 PM
murderedout350z
well my car is dead in the driveway i own the car and was just wonder if anybody has had to replace thiers and seeing i anybody knew if any brand was better than the other
Old Jan 29, 2009 | 02:10 PM
murderedout350z
i though this was just under general
Old Jan 30, 2009 | 07:21 AM
murderedout350z
anybody?
Old Jan 30, 2009 | 08:08 AM
My OEM battery is 60 months old and doing fine. When I replace it I may as well go with OEM.
Old Jan 30, 2009 | 03:38 PM
kevincat's Avatar
kevincat
optima yellow top
Old Jan 31, 2009 | 07:02 AM
murderedout350z
Originally Posted by kevincat
optima yellow top
what is the difference in the colors of the tops??
Old Jan 31, 2009 | 07:20 AM
350Zenophile's Avatar
350Zenophile
I went with the Braille B3121...comparable in cost and performance to an Optima but 13lbs less weight.
If you buy it from TireRack they include the mounting bracket.
Old Feb 2, 2009 | 04:35 AM
HOMiEZ's Avatar
HOMiEZ
the optima yellow top is just the model. i believe its a gel type battery instead of the fluid type on the oem. making it lighter and less vulnerable to being killed if and when the battery is completely drained. i looked around for a bit and saw that the yellow tops were nearing $100, and I would've bought one if it was available at the shop near my place. But I ended up with buying a Wal mart battery with a 3 year warranty
my oem battery went dead when it was completely drained after I left my car in storage for 3 months. I should have at least disconnected the battery, but I didn't intend on leaving the car idle for so long.
Old Feb 2, 2009 | 04:48 AM
Z04's Avatar
Z04
go to autozone and get a duralast gold
35 DLG weight 38 lbs
640 cold crank amps
810 crank amps
$89.00
Old Feb 2, 2009 | 07:24 AM
murderedout350z
yeah that is what happened to mine it has been sitting since before thanksgiving and i went to start it and run it around for a while to blow all the dust out of it but she just wasn't having it
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
OdesiTT
Sep 30, 2015 10:47 AM
Shane86
Sep 17, 2015 05:33 PM
