Flashing airbag lights
Old Jun 30, 2007 | 02:10 PM
bacalhau16's Avatar
bacalhau16
Wow, thats awesome. I just did it, and it worked just fine. I thought I was going to have to go to the dealer and get it cleared for sure.
Old Jul 19, 2007 | 02:03 PM
Jes-Z's Avatar
Jes-Z
Great thread. Worked fine for me.
Old Jul 20, 2007 | 12:40 PM
HitLines's Avatar
HitLines
Mine just came on today. I'll try and reset it after work. Nothing has changed with the car in weeks. Randomness!!
Old Jul 20, 2007 | 01:44 PM
Jes-Z's Avatar
Jes-Z
Mine cam on radomly too. Car was perfectly fine until light came on.
Old Jul 27, 2007 | 04:30 PM
zxpwr's Avatar
zxpwr
anybody know the PN for the Spiral Cable?
my airbag light still blinks... when i try to reset it, it's fine but when i turn the wheel, it's on again.. on top of that my horn doesn't work..
Old Aug 2, 2007 | 02:14 PM
Chaser720's Avatar
Chaser720
Lemoned Z
Yeah i tried to reset mine and it worked for a week or two then it came on again, I reset it again, off for another 2 days, back on reset again and now it still comes back on. Im about to use the black electrical tape method cause i hate my dealerships service department with a passion.
Old Aug 2, 2007 | 02:16 PM
zxpwr's Avatar
zxpwr
does you cruise control still work.. i just found out that mine doesnt.. basically anything connected to the spiral cable doesnt work.
Old Aug 3, 2007 | 02:00 AM
BRONZEE's Avatar
BRONZEE
Club Moderator
One of my friends with an 03 Track 2 months ago had his airbag module replaced. Following is what he emailed me.
"Airbag light started flashing. They ran the computer diagnostics and found it was a known problem with the drivers seat airbag and a wire being caught or something like that. They are changing the whole module. They turned the flashing off but it has just come back again. Don’t know if airbag is working or if it is just the wire giving a fault reading. Not wanting to test the airbag at this point in time."
Airbags aren't something you want to be messing with if you don't know what you are doing. Don't want to hear someone's airbag went off whilst driving.
Old Dec 11, 2007 | 02:37 PM
Mr_pharmD's Avatar
Mr_pharmD
Originally Posted by Sam405
Okay this is how I got mine to reset.
1.) First I open my door and use that as a timer.
2.) Turn my car into the on position wait for the airbag light to come on.
3.) Turn key to off position. When the airbag light starts to blink . You will hear the beeping sound from your door being open. Count 10 beeps and follow the same steps as number 2.) For 4 times it should go off.
So after u do this, the airbag light should turn off afterawhile on the ON position, right?
Old Oct 30, 2008 | 06:18 PM
mason's Avatar
mason
I've tried the airbag reset procedure Many times now with no luck, it only changes the light in and out of diagnostics mode, the flashes read the left and right side airbags have a problem. any ideas on what this means, and how to fix it, in trying to avoid going to the dealership, thanks
Old Nov 2, 2008 | 09:36 PM
tobysoprano's Avatar
tobysoprano
This one did it for me thanks!
Old Nov 7, 2008 | 12:55 PM
Master Shake's Avatar
Master Shake
Originally Posted by Chebosto
airbag reset procedure (taken from my racing seat install thread):
For the Airbag Reseting procedure…You must first change the SRS system to self-diagnosis mode, and then back to user mode to clear the airbag fault you might be getting after unplugging the side-impact seat airbag and driving with the car..
How to Change to Self-Diagnosis Mode:
1. Turn Ignition switch from OFF to ON.
2. Within 1 second after air bag warning lamp is on for 7 seconds and turns off, turn OFF ignition switch
3. After ignition switch is turned off, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice. (perform 3 times in total)
5. Turn ignition switch ON again (turn to Diagnosis Mode.)
Turn to USER mode
1. Turn Ignition switch to OFF to ON.
2. Within 1 second after airbag warning lamp is on for 7 seconds and turns off, turn off the ignition switch.
3. After ignition switch is turned OFF, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice (perform 3 times in total)
5. Turn ignition switch ON again (Turn to User Mode)
Your Airbag light should no longer flash while driving…
Search button FTW!!!
I just got this problem and your steps above worked perfectly. They tore up the road where I work, but I still have to drive on it for about 2/10th of a mile. Probably rattled the sensor or some of the wires a little too much.
For those of you who had trouble with this, make sure when you switch the ignition off, you only go back one click (ie: you should not be able to pull out the key at that point). I think if you go back too far, such as enough to pull out the key, the reset cycle doesn't complete.
Old Dec 8, 2008 | 03:41 PM
pablos Z's Avatar
pablos Z
i just did this earlier today thought it was fixed it was off for a couple of minutes (30 or so) but all of a sudden it started flashing again am i doing something wrong
Old Dec 11, 2008 | 01:21 AM
jkebun's Avatar
jkebun
i just got this problem tonight. was messing around with the z in a parking lot and when i was going home afterwards the airbag light started flashing. i sit pretty close to the wheel but once that light started blinking, i pulled my seat ALL the way back and was clutching in with my toes cuz i thought the airbag was going to randomly blow up in my face... lol~ i gotta give that procedure a try in the morning. thanks in advance!
Old Dec 11, 2008 | 03:33 PM
supra crazy's Avatar
supra crazy
I'm having the same problem I tried this procedure multiple times but it just goes off then comes back on not to far down the road. **** is pissing me off because I'm trying to sell my car.
Old Jan 4, 2009 | 02:17 AM
quakerroatmeal's Avatar
quakerroatmeal
Can't seem to get this either. I took out my seats to install my system. I put it in and randomly one day it came on and now it won't turn off.
Old May 6, 2009 | 05:31 PM
epic1966's Avatar
epic1966
Default Flashing airbag lights
I was driving the other day and the airbag light started flashing. Took it to the dealer and they told me that the airbag module had an open circut and had to be replaced at the cost of $600 plus dollars. Have anyone else had or now of this????? Still the Original seat.....
Old May 6, 2009 | 05:58 PM
  #38
350z_Gio's Avatar
350z_Gio
My friends G35 had the airbag light also. He took it to the dealer and they said that the airbag sensor or something like that had gone bad. They charged him like 400 to fix it. I have had that light on my z for about a year already, but I don't want to dish out the money to fix it.
And welcome to my350z
Old May 6, 2009 | 06:01 PM
  #39
epic1966's Avatar
epic1966
Ok thank you for the info. and the welcome. Man I have to shell out about 1100 the that, brakes and drive belt.. wow.
Old May 6, 2009 | 06:12 PM
  #40
JMT's Avatar
JMT
Before you shell out the $$ for the airbag, you might want to try this:
https://my350z.com/forum/3603538-post3.html
I had my airbag module replaced under warranty when it started flashing. About a year later it started doing it again so I tried the procedure above. It worked like a charm.
