Whining Noise??
Old Jul 2, 2009 | 06:08 PM
tjw992's Avatar
tjw992
Default Whining Noise??
I have an 04 automatic Z. When I accelerate from zero or very low speeds I here a whining noise that gets louder until I let off the gas. It doesn't occur when I accelerate when I am already up to speed.
Any Ideas on what it is?
Old Jul 2, 2009 | 06:31 PM
Liquidice944's Avatar
Liquidice944
I have an Automatic 04 Z as well. Mine does the same thing. ?
Old Jul 2, 2009 | 07:34 PM
tjw992's Avatar
tjw992
bump.
Old Jul 2, 2009 | 08:16 PM
Mike@Blackline's Avatar
Mike@Blackline
if you have a sound system sounds like a bad grounding wire
Old Jul 2, 2009 | 08:20 PM
tjw992's Avatar
tjw992
The car is all stock, but has the Bose system. The noise souds like it is coming from the front of the car.
Old Jul 2, 2009 | 08:42 PM
Mike@Blackline
hmm subtract my input then. sounds like a diff noise but since its coming from the front, scratch that too. i had a 2003 AT but no whine noises, just the standard clicking from the rear suspension. gl with it
Old Jul 2, 2009 | 10:24 PM
kyx4n's Avatar
kyx4n
if its kinda soft, it could just be the intakes..
or you have a supercharger you don't know about installed.
Old Jul 2, 2009 | 10:49 PM
v0lc0m|350z's Avatar
v0lc0m|350z
its your turbo spooling
Old Jul 2, 2009 | 10:57 PM
R350Zz33's Avatar
R350Zz33
intake?
Old Jul 3, 2009 | 04:24 AM
johns350's Avatar
johns350
Girlfriend?
Check things like alternator, p/s pump, etc. Hopefully NOT tranny - but check all fluids to make sure they are at proper level. Make sure belts are in good shape too.
Good Luck.
Old Jul 6, 2009 | 09:27 AM
ngynnhu's Avatar
ngynnhu
it could be the alternator. If the whining gets higher in pitch when your acclelerate then it could be the bearings inside the alternator or bad rectifier assembly (diodes).
Old Jul 7, 2009 | 12:57 AM
tw8715's Avatar
tw8715
bump
same thing here but manaul
can hear it most in 5th gear when i barly press the gas
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
