Grinding Gears!!
Old Jul 10, 2009 | 10:04 PM
pollinatrix11's Avatar
pollinatrix11
Default Grinding Gears!!
I purchased an 03 touring 6MT about a month ago, and lately whenever i drop a gear(happens only when i drop from 5th to 4th or 4th to third) it will either grind or not lock into place very easily. any idea on what this could be any help would be greatly appreciated
Old Jul 10, 2009 | 10:09 PM
Gibbs's Avatar
Gibbs
Know it all
Is this your first manual car?
Old Jul 10, 2009 | 10:14 PM
pollinatrix11
No its not. ive previously owned a 93 Accord, a VW gti and a beater honda civic. If im coasting in neutral around 30 mph and I want to toss it back in 3rd or 4th it will stick or grind every once and a while
JasonZ-YA's Avatar
JasonZ-YA
hum, are you rev matching? are you purposely using downshifting to slow down over braking??
more details please? was the car serviced prior to purchasing and if so, you sure they did tranny fluid change?
Old Jul 10, 2009 | 10:18 PM
JasonZ-YA's Avatar
JasonZ-YA
Well, in general with a car you purchased used i would do a complete service.......change ALL fluids and start your maintence clock from there.
in this case i would start with checking the tranny fluid and then test driving and going from there...
-J
pollinatrix11
No im not rev matching. I'll be coasting in neutral, ill push the cluth in and tru to put the car back in 3rd or 4th and every so often it either grinds or its a ***** to shift into the gear
Old Jul 10, 2009 | 10:20 PM
Spork's Avatar
Spork
Where is Willmar?
Old Jul 10, 2009 | 10:22 PM
pollinatrix11
It's a little under an hour south of st.cloud
Old Jul 10, 2009 | 10:31 PM
HDPDZO6's Avatar
HDPDZO6
There's your problem right there. Driver mod will fix that.
Old Jul 10, 2009 | 10:41 PM
Gibbs's Avatar
Gibbs
Know it all
Mabey the synchro's are starting to go for those gears?
Old Jul 10, 2009 | 11:11 PM
03brembo's Avatar
03brembo
how many miles?
Old Jul 10, 2009 | 11:28 PM
youngh's Avatar
youngh
you have to rev match :x 30-40 miles for me on neutral is usually 4-5th gear if i want to keep it at low rpms
Old Jul 11, 2009 | 02:58 AM
Gibbs's Avatar
Gibbs
Know it all
Rev matching wont stop the gears from grinding or sticking.
Old Jul 11, 2009 | 05:42 AM
Probably need a new transmission.
Old Jul 11, 2009 | 07:04 AM
TJGILROY's Avatar
TJGILROY
it happens in third gear on the 6 MT in the 03's....search in here, you'll find were people have had problems with this...but it's an everyonceinawhile thing so either get used to it or take it in and get ready to be raped!!!!!
Old Jul 11, 2009 | 11:42 AM
djtomski's Avatar
djtomski
it does that to me going from 6th to 5th if i don't rev match. when i rev match it shifts just fine.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
