Issues after Spacer Install
Old Mar 10, 2012 | 03:43 PM
installation's Avatar
installation
Exclamation Issues after Spacer Install
Today i installed a Motordyne 5/16 plenum spacer.
I already have a jwt pop charger and resonated test pipes and it was all working before.
Since install of the plenum spacer; the car idle is very rough and sometimes it dips so low that it stalls out.
I was driving today at roughly 4000 rpms going perhaps 60 km/h and the car stalled while driving!
There is no hissing noise and all hoses appear to be on correctly. And I have reset the ecu, done all the throttle position learning / idle setting, etc.. to no avail
Someone please give me some insight!
Old Mar 10, 2012 | 03:56 PM
huyrua's Avatar
huyrua
Check your MAF sensor. It might be installed backward.
Old Mar 10, 2012 | 04:00 PM
installation
^ I never took it off, its the same way it was before with clip on the top side, But I can try taking it out and turning it around the other way I guess to see if it helps
Old Mar 10, 2012 | 04:07 PM
installation
Any other ideas?
Old Mar 10, 2012 | 04:08 PM
Z33Garage's Avatar
Z33Garage
Hmm one of the things that can cause your car to die while driving is cam/ crank pos sensor. That usually gives codes. BTW is your car spitting any SES codes?
Old Mar 10, 2012 | 05:13 PM
CTS13's Avatar
CTS13
Take the spacer back off and see if it goes back to normal. If it fixes the issue, throw the ***** out. You're not getting much power in addition to be worth the headache. If the car still acts the same way, you need to quadruple check everything.
Old Mar 10, 2012 | 06:05 PM
huyrua's Avatar
huyrua
Did you reinstall the hose on the underside of the intake?
Old Mar 10, 2012 | 06:47 PM
805350z's Avatar
805350z
^ car would still run
Old Mar 10, 2012 | 08:22 PM
Dallasmavs92's Avatar
Dallasmavs92
How did you torque the spacer? Make sure to re-check all your bolts. I checked mine a few days later and like 6 of them had backed their way out..
Old Mar 10, 2012 | 08:54 PM
installation
I torqued to 100 INCH pounds as recommended.
All hoses seem to be fine.
Error codes are 0057 and 0037, Secondary O2 sensors, I dont currently have them in.
Old Mar 11, 2012 | 03:34 AM
*ICE*'s Avatar
*ICE*
sound like there is a leak. I had a Kinetix plenum and the same exact problem pop up after 7k miles. Idling at stop lights is very rough. The rpm needle would jump below 700rpm to 1100 rpm, fluctuating up and down randomly, never stay the same at the exact spot...
i pop the hood, feel my finger around the edge of the plenum and there was a big leak which suck in the air when i feel my finger at the bend spot of the plenum, where the throttle body is connected to it. Turn out my Kinetix plenum had a bad gasket leak. End up putting stock plenum on and a new 5/16 spacer. Problem fixed.
Your problem could be bad torque or bad seal. Try to do a compression check on the plenum to troubleshoot this.
Old Mar 11, 2012 | 05:08 PM
installation
Is it possible it could leak if I tightened it too much?
Old Mar 11, 2012 | 05:13 PM
derekinthez's Avatar
derekinthez
Leak.
Old Mar 12, 2012 | 11:39 AM
installation
Took it off and reinstalled, used locktite this time.
Seems to be okay so far. I will update should anything change.
Old Mar 12, 2012 | 01:08 PM
thisishk350's Avatar
thisishk350
gotta make sure everythings hooked up right.. you might have forgot one of the vacuum lines or something
350z82
Oct 1, 2015 06:25 PM
