Which year was the engines bad(using oil)??
Old Dec 11, 2012 | 10:39 AM
VIPERRACING's Avatar
VIPERRACING
Default Which year was the engines bad(using oil)??
Guys sorry if Im asking this in the wrong forum but I need to know which years to avoid that had engine problems. Im looking at an 03" but wasnt sure. How much oil pressure should they have after warmed up? Thanks for any & all help.
Old Dec 11, 2012 | 10:55 AM
SPirtle's Avatar
SPirtle
Oil pressure can depend on a lot of things like filter, oil weight, temperature. and other things. If you really want to know about the motor do a compression test on it. I have seen cars with 500,000 miles on them that have been well taken care of and I have also seen cars with 88,000 miles blow to pieces. The only problem with the 03 is the clutch fork in the transmission and also the transmission isn't as strong as the 06+.
Old Dec 11, 2012 | 11:06 AM
VIPERRACING
Thanks for the quick reply but do you know what year they had oil loss problems. I want to say that my buddies car was an 05 and he had issues with it using oil. I guess they replaced a lot of engines but cant remember what years they were.
Old Dec 11, 2012 | 11:09 AM
SPirtle's Avatar
SPirtle
I am a hair under 70,000 miles on my '03 and I have no noticeable oil consumption and on top of that it is drifted on the track 1-2 times a month and daily driven.
Old Dec 11, 2012 | 11:16 AM
acke15's Avatar
acke15
Op- http://bit.ly/USgKas
Old Dec 11, 2012 | 11:17 AM
thespottedcow's Avatar
thespottedcow
05 revups in the mt anniversary edition and 06 mts were the ones with oil consumption issues i believe
Old Dec 11, 2012 | 11:22 AM
cgkp0925's Avatar
cgkp0925
For being a member on this forum for 5+ years, I'm surprised you haven't found the answer yet.
Like others have said, it depends on many factors when you're looking at one specific vehicle. As a whole, the '06 year is infamous for oil consumption. But many members have claimed they never had issues.
Please search next time.
Old Dec 11, 2012 | 11:23 AM
Nismo350z#0310's Avatar
Nismo350z#0310
'06 is the year your looking for. (Name that similar movie line)
Old Dec 11, 2012 | 11:24 AM
JCITY's Avatar
JCITY
I too have a 03(Touring).Bought it new.Now has 83k miles.
Uses no oil between 5-6k oil changes.Always have used Valvolene
5W30 synthetic blend.Use only OEM filters.
VIPERRACING
Thanks for the info. I believe that my friends car was an 06. Thanks for all the replies.
Old Dec 11, 2012 | 12:52 PM
35thannyZowner's Avatar
35thannyZowner
I have an 05 35th. My first engine was replaced by Nissan at 25,000 miles. It required synthetic oil, and I would be down at least 2 quarts between changes from new. I no longer use synthetic, and if I keep the RPMs down I have no problems with consumption.
Old Dec 11, 2012 | 01:18 PM
Pengu's Avatar
Pengu
Mine just got it in the last 10k miles (around 70ish). Selling it ASAP really sad about that.
Old Dec 11, 2012 | 01:36 PM
ParanoidAndroid's Avatar
ParanoidAndroid
my 06 MT doesn't consume oil with Amsoil 5w30 and k&n oil filter......
Old Dec 11, 2012 | 01:38 PM
scotts300's Avatar
scotts300
The rev-up is the one you are referring to, however, MANY of the VQ engines consume oil, especially when synthetic oil is used. These cars are all out of warranty anyway, and just because the current owner says it doesn't consume oil, doesn't mean that it doesn't. Just find a clean car that fits your wishes at a price you can afford.
Old Dec 12, 2012 | 01:57 AM
thespottedcow
I mean my 06 goes through a quart every 700 miles or so, never thought about switching to non synthetic, I just keep adding oil :/
Old Dec 12, 2012 | 02:48 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
What's the point of having a Z?
Old Dec 12, 2012 | 04:23 AM
JasonZ-YA's Avatar
JasonZ-YA
Nissan designs their engines with dino...not synthetic....and its provided to them by Castrol motor oil comp..
Rear main seal on all their engines is a rubber/poly material that is made to regular CMOil specs....
I'm not saying Sythetic isn't allowed, the use of which is neither condoned or not condoned....its more that its not gonna do any detrimental damage or enough of a positive effect to warrant any concern...
The Mrev-up engines are what your asking, so as 'spottedcow' mentioned already its the 05 mt anniversarys editions and 06 MTranny cars.
-if your looking for a daily driver, pick another year...so you wont be worrying about oil consumption
-buy an 06 that you know had the engine swapped - due to oil consumption test and warranty replacement by Nissan??? this option would get you the better tranny....
Do you need the better tranny for daily driving - IMHO....NO...
--- if your looking to turbo a track car - get an 06, hands down......as the MREV will yield you better turbo HP numbers...and the maintenance to oil the car should be there with a track car.....
-J
liqalu04
Jan 2, 2022 12:58 PM
seagrasser
Oct 11, 2015 03:27 PM
Mattg350z
Oct 2, 2015 06:51 AM
RyansZ33
Sep 15, 2015 05:54 AM
