Smoking when accelerating? Help!
Old Feb 24, 2013 | 08:31 AM
wonderbean's Avatar
wonderbean
Default Smoking when accelerating? Help!
So I have an 05 bone stock 350z, bought it from a customer at my dads shop already smoking.
It smokes blueish/white smoke, burns an excessive amount of oil. I believe only one cylinder is filled with carbon build up, just can't find out where or how to approach the problem.
It will completely fry the spark plug on cyl. 5 every few weeks or if I push the car.
On low gears such as 1, 2, 3 it will smoke past 2000 rpm but on higher ones or on the highway, after I stop accelerating it won't smoke anymore.
This is my first post here, thanks in advance.
Old Feb 24, 2013 | 05:32 PM
Jets350's Avatar
Jets350
how many miles are on the vehicle? maybe you need to do coils?
Old Feb 24, 2013 | 09:38 PM
wonderbean's Avatar
wonderbean
Vehicle has 135k, relatively certain its not the coils but I'll bite. Why do you think it's the coils?
Old Feb 25, 2013 | 09:55 AM
zakmartin's Avatar
zakmartin
If I were to guess, blue smoke generally indicates a bad valve seal.
Old Feb 25, 2013 | 11:43 AM
Tracktimeplz's Avatar
Tracktimeplz
and/or piston rings
Either way, it sounds like this car is due for a rebuild/swap. Check the compression and let us know what you get
Old Feb 25, 2013 | 12:00 PM
wonderbean's Avatar
wonderbean
Originally Posted by Tracktimeplz
and/or piston rings
These are my guesses, but the only thing that has me curious is the fact that only ONE cylinder is causing this.
I'm hoping its buildup somewhere, or if someone else has a familiar problem. I'm trying to avoid taking the head out for now, hoping there's a simpler fix. I can't imagine why only one cylinder is doing this and has been for over a year (with the previous owner).
Old Feb 25, 2013 | 12:18 PM
Tracktimeplz
Cracked rings or ring-lands often occur in just one or two cylinders, unless there was a catastrophic event. You would still do the same rebuild if it were all of them, so it doesnt change anything
Id be willing to bet that you have significantly decreased compression on the cylinder. Compression test will take you ~half an hour on this car, the gauge is cheap and can be found at almost any parts store.
Old Feb 25, 2013 | 12:20 PM
350z006's Avatar
350z006
Not too suprising to have only one cylinder issue....a compression test will tell you for sure...
When my stock block was dying I did a compression test and all the numbers were good except for cylinder 2 with low compression, so it isn't out of the ordinary...
Old Feb 25, 2013 | 01:07 PM
wonderbean's Avatar
wonderbean
Got the gauge at my dads shop, will test when I go back. He's really only familiar with old Z's, wasn't aware that it was ordinary for these cars to have single cylinder compression issues.
Thank you to you both, much appreciated.
Old Feb 25, 2013 | 02:29 PM
str8dum1's Avatar
str8dum1
but you shoulda been aware of their horrible oil consumption/burning history.... a million threads on it
Old Feb 25, 2013 | 04:11 PM
wonderbean's Avatar
wonderbean
Aware sir.
2 quarts every time I put gas is not normal oil consumption lol.
Its burning excess oil because of the same reason that its smoking.
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
ti837
Sep 22, 2015 07:46 AM
