P0306 / P0300 With Freeze Frame HELP PLZ
Old 02-27-2013, 04:44 PM
trini_350z
trini_350z's Avatar
Default P0306 / P0300 With Freeze Frame HELP PLZ
Hey guys i need some help here.
Sent my 2003 Track 350z to do an engine re haul (all gaskets , seals etc)
when i got it back , car worked good for 2 days
One night while parked up i felt the idle change when i watched my tac i saw the idle was fluctuating alot and i could feel the engine was idling rough. I thought it was just a fuel choke or so and i decided to take the car for a run. Everytime i stop and the car starts to idle , you feel the problem. After about 10 mins the SES light came on (P0306) cleared the code and went home. Next morning i started the car ... no problems . i drove to work and everything was normal . That night on my way home SES again (P0306). When the car came to a standstill i noticed the same problem (idling bad) . I took the car back to the people that did the engine re haul and they said there is no problems and they dont have room to take the car right now. I took the car by a next mechanic a couple days later he said it wa ready to come and collect. Car worked good by him , i drove home (40-45miles) no problems .. next morning still no problems .. that night as i started the car (P0300) i took a freeze frame (posted below)
The new mechanic doesnt have space to take the car in right now and i need help to fix this. Listed below is everything i tried including the freeze frame data and observations
While i was getting P0306 i swapped spark plug and coil pack 5 & 6 (same problem)
Cleaned air filter
Cleaned TB
Not too sure what the mechanic did to clear the P0306
Now i have P0300
Observations -
1. Mainly happens at night
2. Exhaust smell is VERY strong (you cannot stand up behind the car while it is running)
3.Engine makes a different/weird noise while car is giving the problem (sounds like something is loose and shaking up)
4. Oil pressure drops while car is giving the problem
5. **Car doesnt do system check when ignition is turned on (5 beeps) but the first guage does the full cycle.. Car just doesnt beep**
Stock engine and ECU
90,000miles
CATS removed at 60k TP installed
Freeze frame data -
TROUBLE CODE P0300
FUEL SYS1 NA
FUEL SYS2 NA
CALC LOAD % 20.7
COOLANT TEMP 109F
ST FTRM1 % 24.9
LT FTRM1 % 2.3
ST FTRM2 % 24.9
LT FTRM2 % 0
ENGINE RPM 1000
VEH SPEED 0
Live Data - (after i cleared SES)
FUEL SYS1 CL,USING H02S
FUEL SYS2 CL,USING H02S
COOLANT TEMP 185F
ST FTRM1 % 11.7~
LT FTRM1 % 2.3~
ST FTRM2 % 2.3~
LT FTRM2 % -0.7 (doesnt fluctuate)
ENGINE RPM 688~
VEH SPEED 0
IGN ADV DEG 19~
IAT 147F
MAF LB/MIN 0.6~
ABSLY TPS% 0.7~
02S11 .010 V 17.9%
02S12 .07 V NA%
02S21 .01 V 5.4%
02S22 .08 V NA%
OBD2 STAT OBD2-CALIF
Old 03-01-2013, 07:04 AM
ericjackson
ericjackson's Avatar
not sure about the code. unless the timing chain wasnt put on right. also, try the throttle body relearn procedure. that fixed my idle problem after i rebuilt the engine. but the shop that did the work needs to own up and fix it right. or id be asking for some money back.
id be willing to bet the timing chain is off. it can be a hassle if you arent paying attention.
Old 03-01-2013, 08:36 AM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
It was a few years back but I pulled P0306 and it was an issue with the cam shaft position sensors…I can look at my paper work tonight if you like. Both were replaced and the code never came back.
Old 03-01-2013, 08:58 AM
trini_350z
trini_350z's Avatar
Thanks ericjackson will look into that
I am kinda leaning to a bad o2 sensor.
Before i left work last night i decided to just check the car for fault codes (SES was off)
i pulled a p0171 code and cleared it. About 1 minute later ... SES came on i got P0300
When i got home i checked the engine for vacuum leaks and i also took out and tested the PCV valve. The very stong gas smell coming from the exhaust made me stop what i was doing and lean towards the O2 sensor .. You literally cannot stand behind the car while it is idling
I checked Plugs , Coil Packs , MAF , PCV valve
Can someone give me some advice on the O2 sensor causing this strong gas scent coming from the exhaust
Old 03-01-2013, 09:00 AM
trini_350z
trini_350z's Avatar
Thanks for the info but i recently changed both cam position sensors and crank position sensor
Old 03-01-2013, 09:02 AM
andz33
andz33's Avatar
P0306 is a mis fire on the #6 cylinder. P0300 is a multiple cylinder mis fire. I would get a new coil pack for the #6 cylinder.
Old 03-01-2013, 09:06 AM
andz33
andz33's Avatar
Strong gas smell is caused by the #6 cylinder not firing because it has no spark to ignite the chamber. To test your coil packs and see if it's really bad just swap one cylinder to another and then you'll get a code for that cylinder which in turn will tell you it's a bad coil pack.
Old 03-01-2013, 09:10 AM
trini_350z
trini_350z's Avatar
I swapped spark plug & coil pack 5 and 6 already
Old 03-01-2013, 09:12 AM
andz33
andz33's Avatar
Are you still getting the same code?
Old 03-01-2013, 09:20 AM
trini_350z
trini_350z's Avatar
I got it twice after the swap ..
After the last mechanic did some work on it (checked and cleaned injectors , maf , tb etc.) all i am getting now is P0300 & P0171
Old 03-01-2013, 09:27 AM
andz33
andz33's Avatar
Have you done the ecu reset procedure not just clearing it on the obd2 reader?
I would reset the ecu and have it relearn the system.
Old 03-01-2013, 09:46 AM
trini_350z
trini_350z's Avatar
Yes i did
Old 03-01-2013, 09:51 AM
trini_350z
trini_350z's Avatar
What caught my eyes are the readings i am getting from the scan tool
this was taken 22nd FEB
02S11 .010 V 17.9%
02S12 .07 V NA%
02S21 .010 V 5.4%
02S22 .08 V NA%
This was taken 5 mins ago
02S11 .020 V 7.8%
02S12 .100 V NA%
02S21 .030 V 16.3%
02S22 .080 V NA%
Why does 2 of them have NA% ?
Is this common ?
Old 03-18-2013, 08:33 AM
trini_350z
trini_350z's Avatar
Just an update ..
Turns out i have a blown head gasket
Found coolant and oil mixing and my radiator is back pressuring coolant is spraying out the over flow bottle
I am taking it by the mechanic tomorrow night
Will give everyone an update
Old 06-24-2018, 07:06 AM
superd806
superd806's Avatar
Default 3
Cleaned air filter
Cleaned TB
Now i have P0300
Observations -
90,000miles
Freeze frame data -
TROUBLE CODE P0300
FUEL SYS1 NA
FUEL SYS2 NA
CALC LOAD % 20.7
COOLANT TEMP 109F
ST FTRM1 % 24.9
LT FTRM1 % 2.3
ST FTRM2 % 24.9
LT FTRM2 % 0
ENGINE RPM 1000
VEH SPEED 0
COOLANT TEMP 185F
ST FTRM1 % 11.7~
LT FTRM1 % 2.3~
ST FTRM2 % 2.3~
ENGINE RPM 688~
VEH SPEED 0
IGN ADV DEG 19~
IAT 147F
MAF LB/MIN 0.6~
ABSLY TPS% 0.7~
02S11 .010 V 17.9%
02S12 .07 V NA%
02S21 .01 V 5.4%
02S22 .08 V NA%
Did you ever figure out what was throwing the p0306 code
etkms
06-19-2022 06:30 PM
BEBO'S ZEE
06-07-2016 07:48 AM
AP350z223
09-08-2015 04:38 PM
GaryM05
Cleaning & Detailing
12-31-2002 05:13 PM
Zb4-18
09-08-2002 07:04 AM
Quick Reply: P0306 / P0300 With Freeze Frame HELP PLZ
