buzzing noise when in 2nd over 4k
Old Feb 28, 2014 | 10:55 AM
jedr1337's Avatar
jedr1337
Default buzzing noise when in 2nd over 4k
Car just started this this morning.at first it was a constand whirring buzzing noise eminating from front of car past dash. Sort of an electrical hum. Turned off stereo and it was still there. Went away after a short drive. Now however, it persists in any gear over 4k, but is particularly noticeable in 2nd. Take offs from first are now also making more noise, and vibrating more.
Afterthought: it was about 16 degrees, today. Maybe cold has an effect?
Old Feb 28, 2014 | 11:50 AM
winchman's Avatar
winchman
I guess that's one issue I don't need to worry about...for several reasons.
Old Feb 28, 2014 | 01:57 PM
Demantic's Avatar
Demantic
I have some king of noise similar, its like a high pitched hum and appears worse in the lower rpms and after a while just dissapears.
Old Feb 28, 2014 | 04:41 PM
Spike100's Avatar
Spike100
Is your car a 2003 with the original transmission?
--Spike
Old Feb 28, 2014 | 10:30 PM
winchman's Avatar
winchman
--Spike
Doesn't look like it.
jedr1337
2006 Nissan 350Z
Old Mar 1, 2014 | 03:32 AM
SQuaLZ's Avatar
SQuaLZ
Mine makes a slight buzzing noise when I have my rear defroster on. Considering the temp, was your's on?
Old Mar 2, 2014 | 09:55 AM
1000gixxer's Avatar
1000gixxer
Default Noise issue
Sounds like one of your idler pulleys or tensioner pulleys have bad bearings . Remove your belts and turn and check for play or looseness .
If your belts are old (more than 3 years old) or with more than 25K miles on them , replace them . Check your other accessories they might be ready to crap out .
Good Luck
In Frostbite Falls (see Bull Winkle cartoons)
Old Mar 17, 2014 | 01:07 PM
Hornlesscow's Avatar
Hornlesscow
also experiancing the same thing. kind of like a low pitched whistle noise when its cold out and car hasnt warmed up right? idk what it is yet but i think it might be a bad oil pump?
Old Mar 17, 2014 | 08:53 PM
PJ_lemans's Avatar
PJ_lemans
I have 03 6mt this happens to mine as we'll once the car fully warms up it goes away.
Old Mar 18, 2014 | 01:24 AM
myfirstzcar's Avatar
myfirstzcar
Mine has alternator noise, the more load, the more noise. It's done it since I bought the car 4.5 years ago and hasn't gotten any worse.....Not that it's even close to being bad in the first place.
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
