Front wheel brakes by itself VDC off slip on
Old Jan 1, 2015 | 12:42 PM
Mcdildoude's Avatar
Mcdildoude
Default Front wheel brakes by itself VDC off slip on
Been having this issue since i bought the car and finaly getting the time to look at the issue so here it goes.
2003 350 touring
When i start the car and start rolling the front right wheel will apply the brakes by itself, lock up the wheel and let go, lock up again and let go and on the third time around the VDC off light and slip will turn on and stay on.
The abs light does not come on at any point and no CEL either.
If i turn off vdc before i start moving i avoid all of this ( which is what ive been doing but anyways id like to solve the problem)
Im running 18's that are within tolerance for the vdc but still checked to make sure with a friends 2003 350z and it never gave him any issues.
Any help is appreciated , ive looked around the forums for similar issues without any luck.
Old Jan 1, 2015 | 01:16 PM
Spike100's Avatar
Spike100
I know you said you are running 18 inch wheels, but tell us what size tires you have front and back. --Spike
Old Jan 1, 2015 | 03:22 PM
Mcdildoude's Avatar
Mcdildoude
Off the top of my head (car is in storage and im at sea working)
Front 235/40
Rear 275/35(these im sure of)
Old Jan 1, 2015 | 03:41 PM
Spike100's Avatar
Spike100
If you are in fact on 18” wheels, the sizes you report are wholly wrong.
The front should be something like 245/40-18”
The rear should be something like 275/40-18”
The sizes you mention are very wrong.
Front 235/40
2003 350 touring
Old Jan 1, 2015 | 06:14 PM
dkmura's Avatar
dkmura
General & DIY Moderator
If the rolling diameter of your front tires are larger than your rears, it will throw off your VDC system. This could lead to VDC trying to activate and the problems you're experiencing. Check the tire sizes when you get back and let us know.
Old Jan 2, 2015 | 08:38 AM
terrasmak's Avatar
Steering angle sensor being screwed up will also cause this
Old Jan 3, 2015 | 02:24 PM
Mcdildoude's Avatar
Mcdildoude
245 40 18 sounds about right
Ill be home around the 18th of jan ill let you guys know then thanks very much for the help!
Old Jan 3, 2015 | 03:29 PM
Spike100's Avatar
Spike100
245/40-18 is the correct size for the front. The rear would need to be taller.
When you get home the middle of this month, post the actual tire sizes and I'll try to help. --Spike
Old Jan 16, 2015 | 01:01 PM
Mcdildoude's Avatar
Mcdildoude
Well 235/40 front and 275/35 rears so i guess thats my issue
Weird it never did that on my buddys car with the samw wheels and tires
Old Jan 16, 2015 | 02:38 PM
Spike100's Avatar
Spike100
Your fronts and rears are close to the same overall diameter with the fronts slightly shorter. So, you should be OK with those sizes. I have a 2003 with VDC and run an all-square winter tire/wheel setup.
I think you should follow-up on terrasmak's suggestion.
Old Jan 16, 2015 | 02:53 PM
tommy smith's Avatar
tommy smith
I don't see anything wrong with the sizes you have. I like 235/45 front & 275/40 rear better but what you have shouldn't be a problem..
I would immediately have your car checked cause that sounds like a dangerous situation.
Old Jan 16, 2015 | 05:47 PM
Spike100's Avatar
Spike100
What would you have checked?
Just asking because you said: "I would immediately have your car checked cause that sounds like a dangerous situation."
Old Jan 18, 2015 | 01:48 PM
Mcdildoude's Avatar
Mcdildoude
Next step will be to pull the code, my code scanner is at my dads 8hrs away ill see if i can get it shipped to me.
Dangerous? I wouldnt say so it doesnt act up once i hit the vdc off button. Just annoying that i have to switch it off every time
Old Dec 11, 2017 | 01:50 PM
Ravon's Avatar
Ravon
Default Same problem
I have a 2006 G35 sedan base model and I am having the exact same problem I have replaced the ABS wheel sensor on that wheel and the problem persists.
Old Jan 5, 2025 | 02:45 PM
iamahmedlz's Avatar
iamahmedlz
Default asking!
did u manage to fix this??!!
2003 350 touring
Old Jan 5, 2025 | 03:08 PM
dkmura's Avatar
dkmura
These kind of brake problems are usually associated with wiring problems. I'd suggest pulling codes from the ABS section to gain any information there. Next check the wheel speed sensors on all corners to make sure they are properly installed and functioning. After that, it gets more complicated (ask me how I know) and you may need to check the cabin harness for breaks or shorts.
07ZEKE
Aug 23, 2021 09:15 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
