Help please - transmission issues
Old Mar 31, 2015 | 04:23 AM
053z's Avatar
053z
Default Help please - transmission issues
So I just bought an 03 z that ran pretty good for the day I had it.( one point it was throwing a misfire code that went away). Well while I was driving I tried to shift into 3rd and the car wouldn't let me and the pedal was stuck. I had to power shift the way home which was close. So at first the pedal wouldn't even alow me to get into gear, but now it does but when I try to release the clutch an awful noise comes, like a broken power steering pump. And maybe I'm crazy but I smell burning. I'm assuming the slave and master cylinders, btw the clutch goes up and down now but it's very sticky
Old Mar 31, 2015 | 09:47 AM
TenneZee's Avatar
TenneZee
The noise sounds like it could be the throwout bearing. Your assumptions on the slave and master cylinders are certainly a good place to start for the sticky pedal.
Old Mar 31, 2015 | 01:32 PM
oldschool350z's Avatar
oldschool350z
Can you get a video of the noise? The throw out bearing is always a cause of noise with the z, it's normal.
However the clutch pedal could be those isssyes you noted. I would check the engine with a scanner to see if there are any codes pending.
Old Mar 31, 2015 | 04:27 PM
travlee's Avatar
travlee
Master
sounds ike you bought someone else's headache. i am going to say slave and master are going/gone
Old Mar 31, 2015 | 06:48 PM
Golden_Armz's Avatar
Golden_Armz
03s trans are known to have bad syncros. Did u test drive before you bought it?
Old Mar 31, 2015 | 07:44 PM
053z's Avatar
053z
Yes I test drove it, it had the 3rd gear grind but it wasn't too bad. The car ran perfectly fine until this happened. No when I release the clutch in first the car makes a sort of grinding sound, but not like I'm used to hearing with gears ? Im just hoping I don't need a new tranny
Old Apr 1, 2015 | 07:44 PM
053z's Avatar
053z
Help please
Old Apr 1, 2015 | 08:33 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Have you tried draining the tranny and examining what's on the magnetic plug as well as what sits on top of the drained fluid. Try refilling with a quality lubricant like Redline MT85, which meets the viscoity requirements of our six-speed trannys.
But I'm also guessing you'll need to drop the tranny and take a close look at the slave, release bearing and clutch/flywheel. There's no getting around it if you want to repair it the right way.
Old Apr 2, 2015 | 08:04 AM
monztr's Avatar
monztr
Noise when you have the pedal pressed in (clutch disengaged) is a throwout bearing. Noise when releasing the pedal (engaging the clutch) would indicate a problem with the clutch itself or worse the transmission.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
