Squeaking sound after repairs
Old Feb 18, 2016 | 12:31 PM
dragoonkane's Avatar
dragoonkane
Default Squeaking sound after repairs
i have this squeak sound on my passenger side of the car. if i lift up or push down on that side of the car i get the sound it is almost continuous when i drive. i didn't go in to the shop with the sound it was only after they replaced the lower control arms,struts and strut mounts no sound but they ruined my old struts so i went back they replaced it with new struts that started the sound then i took it back they replaced the struts a 2nd time i didn't have the sound at first but after about 10 minutes of driving it came back then went away for like 2 hours and then came back again
this is a link of the sound with me just lifting up on the fender
Old Feb 18, 2016 | 05:05 PM
travlee's Avatar
travlee
Master
sounds like my bed
Old Feb 18, 2016 | 09:15 PM
jtbinvalrico's Avatar
jtbinvalrico
Check the bolts securing top of the strut on the passenger side......check the bolts securing that strut bar too.
Old Feb 19, 2016 | 02:40 AM
dcains's Avatar
dcains
Aftermarket swaybar? I finally switched my front Hotchkis for a Nismo bar after trying every type of grease available and two sets of bushings. Yours sounds more like metal on metal, though.
Old Feb 19, 2016 | 08:34 AM
RWDBajan's Avatar
RWDBajan
Does the spring on that corner still have the plastic insulator at the bottom, between it and the strut?
Old Feb 20, 2016 | 09:13 AM
dragoonkane
Default checked under the car
I was able to get under the car last night and yea the plastic insulator that loops around the bottom of the spring was there. That was my guess that maybe something like that was missing but once i jacked the car up i could no longer make the noise, so i lowered it down on top of a board so i could peek my head under the car and couldnt get the noise then either.
Old Feb 20, 2016 | 09:17 AM
dragoonkane
Default bolts seem tight
the sound seems lower then that when standing next to the car it was my first thought too that the bolts weren't tight on top
Old Feb 22, 2016 | 03:06 PM
RWDBajan's Avatar
RWDBajan
You could try spraying the various potential squeak points with silicone one at a time. Carefully so you don't get any on the brakes or tires. Red circled areas, I'm thinking.
Old Mar 3, 2016 | 08:18 PM
dragoonkane
Default problem fixed
So just to recap and to help anyone that has this issue. it turns out that the shop damaged the strut mount and messed up the rubber insulator and there was metal on metal inside the strut mount. So i replaced the mounts and no more squeak
thx for all the help
Dustin350
Jan 10, 2025 03:09 PM
phelannz
Feb 26, 2016 08:27 AM
J_Nunez33
Feb 19, 2016 01:17 PM
shadowm891
Feb 16, 2016 12:13 PM
zachary.newsom
Feb 15, 2016 04:14 PM
