350z cranks but wont start
Old Jan 30, 2020 | 08:49 PM
jonathan_337's Avatar
jonathan_337
Default 350z cranks but wont start
Hey guys,
I’m absolutely out of ideas and pulling my hair out on this. For the last couple months I’ve had intermittent starting issues. Sometimes it’ll turn over, sometimes it won’t. But now, it just won’t. I replaced the crank sensor already, but not the cam. I don’t think the cam sensors are bad cause it’s not throwing any codes.
However, my Z does not have the original key nor does it have the original alarm system. It’s a Viper alarm system. I’m wondering if the car’s security system/ Immobilizer is locking me out but I have no clue how to test this. Can anyone please offer some advice? I have no idea what to do
Old Jan 31, 2020 | 03:52 AM
travlee's Avatar
travlee
Master
bad cam shaft sensors dont throw codes
Old Jan 31, 2020 | 04:06 AM
jonathan_337
I did not know this. I assumed they would cause most bad sensors usually do. I’ll order a pair of these tonight and see from there.
Old Jan 31, 2020 | 04:14 AM
travlee's Avatar
travlee
Master
what year is the car, and how many miles? i had a buddy that had an 03, same symptoms as you, no codes... replaced the cam sensors and problem solved. hope this is the case for you sir
Old Jan 31, 2020 | 07:52 AM
jonathan_337
It's 2004 doing 120,000km (we use km where I'm from lol, it's also a RHD). So basically the same setup as you mentioned above. I guess this is my first thing to try! I will be getting a new bank 1 and bank 2 sensor tomorrow once they have in stock. Will update if it works, thanks a lot for the advice.
Old Jan 31, 2020 | 08:27 AM
iideadeyeii's Avatar
iideadeyeii
Use a better scanner that can read hidden codes.
Old Jan 31, 2020 | 01:50 PM
Spike100's Avatar
Spike100
Are you reading codes with Nissan's Consult ODB scanner?
Originally Posted by jonathan_337
[… ] I don’t think the cam sensors are bad cause it’s not throwing any codes. […]
Old Feb 1, 2020 | 07:26 AM
jonathan_337
I don’t have access to a consult scanner but wouldn’t the check engine light be on if something was throwing a code? I made a discovery today just before buying the cam sensors - on ignition, the security light stays constantly illuminated red. Could this point to a faulty Immobilizer/ key?
Old Feb 1, 2020 | 09:15 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
No, not all codes throw the SES (CEL). Never assume, plug in the diag tool.
cbeneke
Oct 30, 2009 09:08 AM
puertorican
Pacific
13
Dec 29, 2008 11:30 AM
shortbus1981
Aug 5, 2005 10:39 PM
SDZ
Jul 2, 2002 10:39 AM
