Attn: Z owners - Alignment Issues - Please Read (moderators included)
Old Apr 18, 2005 | 05:01 AM
  #241
dh21187's Avatar
dh21187
A major news network is coming to my house today, April 18,2005, to do a story on this car. If anyone is in the Nanuet, NY area and wants to bring their car to share their story email me at dh21187@spamcop.net and I'll give you directions on where the shoot is going to be Serioulsy..
Old Apr 18, 2005 | 06:38 AM
  #242
pulpz2's Avatar
pulpz2
How did you pull that off? Good luck!
Old Apr 18, 2005 | 04:07 PM
  #243
MB311's Avatar
MB311
Good job man, Hopefully the news-people can get into the heads of Nissan to issue a recall on all 350Z's whether it's an 04 or 05.
Old Apr 18, 2005 | 05:26 PM
  #244
dh21187's Avatar
dh21187
The footage is in the can after about 2 hours of interviewing and taping. You will start to see teases for it in about a week. Once they give me an air date I will post it here so you can all watch. Its going to be on the 11:00 news and should be about 2.5 minutes in length which is huge in prime news time during sweeps. They claimed I gave them an awesome story and that they will be using it during sweeps for ratings. I used a good number of quotes against them so hopefully they will take notice and do the right thing. This will hopefully put an end to our suffering with these cars. Yeah, I know I'm no Marlon Brando but I think I got my points across.
Car pulls off to the right due to design defect in suspension
Tires replaced every 3k miles at $700.00 plus labor
Navigation door wouldn't open
Clutch chatter during idle and at takeoff
Leaks from the softtop
Tachometer stops working while driving
Passenger Door wouldn't open
Gas filler door wouldn't open
Etc, etc..
Old Apr 19, 2005 | 05:59 AM
  #245
dilledille's Avatar
dilledille
I went to the dealer to have the front end inspected and repaired, my front tires are cupping and has a lot of road noise. There is a TSB that extends the front end from a one year warranty to a two year warranty. Mine is a 2003 and I missed the time span. If you are under the two year warranty extension they will repair and replace tires.
Old Apr 19, 2005 | 07:29 AM
  #246
dh21187's Avatar
dh21187
I have a 2004 350ZR and according to the Nissan Rep, Miranda Carter, it isn't happening in my car so they won't do anything for me. The dealership has already confirmed that it is and replaced the tires once without reimbursement from Nissan as well as an alignment. Its been there three times for an alignment this month and they still can't get it right. The car handles like crap now that they changed the toe setting. The car is still sitting there as I type with them trying again.
Miranda now admits that they installed a drag kit on my car but they didn't put it on my repair invoice which isn't legal. Then she says that this happens routinely where they do stuff to your car without telling you. Nice to know...Huh..
Old Apr 19, 2005 | 01:17 PM
  #247
dh21187's Avatar
dh21187
I just got another call from Nissan and they still won't admit to the problems I am having with the car. They claim to be unaware of my situation, but they are now supposedly diligently trying to fix the problems. Yeah right, like a dog chasing it's tail..
Old Apr 19, 2005 | 07:52 PM
  #248
arejohn's Avatar
arejohn
Default what's a drag kit?
What parts are in a drag kit.
Old Apr 20, 2005 | 10:53 AM
  #249
infinite z's Avatar
infinite z
I own an 03 coupe, and still have the pulling to the right problem, even after getting a brand new control arm put on under warranty. They say that since it takes 14 seconds to change lanes that they won't fix it any more. Is there anything else I can do?
Old Apr 20, 2005 | 11:09 AM
  #250
arejohn's Avatar
arejohn
14 sec to change lane. Are there many cars that do better?
Old Apr 20, 2005 | 11:12 AM
  #251
infinite z's Avatar
infinite z
No idea, but it just doesn't seem right that I have to keep my steering wheel turned left a little at all times just to go straight
Old Apr 20, 2005 | 12:43 PM
  #252
arejohn's Avatar
arejohn
If you must have the wheel turned from center to go straight you have another problem. My first guess is R and L toe incorrect although total toe may be correct. Might you be looking too close.
Old Apr 20, 2005 | 12:45 PM
  #253
infinite z's Avatar
infinite z
I've had it aligned several times, and it still does it. They swear it was aligned to spec.
Old Apr 20, 2005 | 05:30 PM
  #254
arejohn's Avatar
arejohn
After wheel alignment the vehicle should be road tested to make sure the steering wheel is centered.
Old Apr 21, 2005 | 08:50 AM
  #255
infinite z's Avatar
infinite z
Is that something the mechanic does? Or do I just test it and tell them it still isn't straight. Sorry I'm car illiterate.
Old Apr 21, 2005 | 03:39 PM
  #256
arejohn's Avatar
arejohn
Default crooked wheel
Just how crooked is your wheel?
If the tech adjusts the alignment on the front wheels with the steering wheel not level, straight, what ever you want to call it, the alignment can be correct and give the results you describe. This can also be caused by the rear wheel aligment being out of spec. Was the alignment 4 wheel?
Old Apr 22, 2005 | 12:10 AM
  #257
2005350z's Avatar
2005350z
Man thats sweet news
Old Apr 22, 2005 | 08:59 AM
  #258
jkk4's Avatar
jkk4
cpoe52, are you still around? I've got the feathering problem on my 04 and was wondering if your new alignment settings and the tire rotation helped this past November?
jkk
Old Apr 22, 2005 | 05:28 PM
  #259
BostonZ's Avatar
BostonZ
Just had a four wheel alignment, lowerd w/ hotchkis, shows I'm in specs, but still looks very much out of camber???
Old Apr 22, 2005 | 08:12 PM
  #260
dh21187's Avatar
dh21187
Default TV Special
The 350Z special is set to air April 28,2005 at 11:00pm on CBS in New York. The reporter is Kirstin Cole and you should start to see teases on the special starting on the 25, maybe sooner depending on their decisions. Hopefully this will force Nissan to accept their design failures and do the right thing.
