Motorsports The Z in its Natural Habitat
Explain a time slip from the track.
Old Jun 11, 2003 | 11:58 AM
Megatron's Avatar
Megatron
Default Explain a time slip from the track.
I been to the track plenty of times to watch, but never to run. I want to know, what does everything mean on a time slip. And what should be some numbers I should aim for on the slip?
Old Jun 11, 2003 | 01:30 PM
ELS1's Avatar
ELS1
60' = the first 60 foot of the track...lets you know how good of traction you pulled off...generally a 2.0x on street tires is ok, a sub 2 is superb
1/4 = 1/4 time
MPH = how fast you trapped...
thats basically all...
Old Jun 11, 2003 | 05:43 PM
euroguy's Avatar
euroguy
Another thing beginners will sometimes get confused with is reaction time doesn't effect your ET in any way. Correct me if I'm wrong, but I think .500 is perfect on a sportsman's tree and .400 on a pro tree.
Old Jun 11, 2003 | 07:55 PM
Silver Snake's Avatar
Silver Snake
1/4 = 1/4 time
what he said.
Old Jun 12, 2003 | 08:52 AM
phreezee's Avatar
phreezee
I think I need this explained... when does the clock start ticking if your reaction time to when the light turns green doesn't matter?
I always thought the timer started once the light turned green.
Old Jun 13, 2003 | 03:15 AM
Steve98TransAm's Avatar
Steve98TransAm
The timer doesn't start until your tires break the laser "starting line" beam. You can sit at the line with your brakes still held for 10 seconds if you like, yet still run a 14.0 @ 99mph. Your timeslip will still say 14.0 @ 99mph, yet your reaction time will be 10.000
Your reaction time will not effect your E.T.
The only place where reaction time matters is when you are bracket racing, because then the first person to the end of the track wins, so you want to react as quick as you can to the green light.
Old Jun 13, 2003 | 03:17 AM
Steve98TransAm
Double post. Sorry. My computer screwed up.
Old Jun 13, 2003 | 09:20 PM
obrien's Avatar
obrien
you might want to explain to him what bracket racing is.
Old Jun 14, 2003 | 02:11 AM
12SecZ's Avatar
12SecZ
I always launch on the last yellow (bracket reacing here) if you wait for the green you waited to long and will be +1 or greater. We are talking milleseconds
Old Jun 15, 2003 | 07:31 PM
Lokeey's Avatar
Lokeey
So those who have got a 2.0 60FT what rpm did you launch at and did you do a burn out before you went down the strip??? I could not seem to break a 2.25 60FT..
On stock tires.....
Old Jun 15, 2003 | 08:16 PM
12SecZ's Avatar
12SecZ
6MT ABOUT 2500 rpm's and getting the tires sticky helps regardless of what some say. If it is a real hard tire try it both ways.
A5T (like mine) completly diffferent, you pull the brake use to get any kind of sub 2.0 launch.
Old Jun 16, 2003 | 04:20 AM
Ben Davis's Avatar
Ben Davis
I agree here, do a DRY BURNOUT though, of you go thru the wet box water may get trappedi n your tread, drip out on the line and cuase too much wheel spin on take off...
Ben
Obadabot
Jun 18, 2023 11:31 PM
loudtoyz
Apr 6, 2023 04:52 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
