SG Longtubes are back.
Old Apr 7, 2013 | 11:06 AM
  #101
2TH PWR's Avatar
2TH PWR
Yep, i recieved mine this week. Did not have a chance to take pictures as they went straight into the shop for instal. But I will try and get them to take some pictures for me.
Old Apr 22, 2013 | 07:12 AM
  #102
vex008's Avatar
vex008
any updates?
Old Apr 22, 2013 | 12:03 PM
  #103
2TH PWR's Avatar
2TH PWR
Shop hasn't sent me any pics yet. Should be installed soon and tuned. I will eventually get a dyno vid and some pics in the next week.
Old Apr 24, 2013 | 01:15 PM
  #104
Acidz's Avatar
Acidz
Old Apr 24, 2013 | 05:18 PM
  #105
2TH PWR's Avatar
2TH PWR
My car made 315 wheel hp.
Will see if I can post some more info later
Old Apr 24, 2013 | 05:57 PM
  #106
INTIMAZY's Avatar
INTIMAZY
Insane.
What a difference a proper set of headers can make.
Old Apr 24, 2013 | 06:10 PM
  #107
2TH PWR's Avatar
2TH PWR
Well its not all the headers. Don't be fooled although the headers were critical.
I swapped in the SGM motor itself out of Sasha's car. The one that used to have ITBs and made 376 whp.
Everything was the same except I had a stock upper plenum, maf, throttle body etc.
So that put a cork on the motor.
But it has ported heads and JWT C9/C10 cams.
And oh yeah, still running stock fuel system, except I am running 110 Octane with the 12:1 compression pistons.
Old Apr 24, 2013 | 07:00 PM
  #108
kacz07's Avatar
kacz07
Big cork. I made 310whp with SGs with smaller cams and a Cosworth plenum, but stock MAF and TB. Sounds like I'd make big power with some Jenvey ITBs and some better engine management.
Old Apr 24, 2013 | 07:06 PM
  #109
kacz07's Avatar
kacz07
Originally Posted by Acidz
Makes me wish mine weren't pc'd. Are there reducers after the collector?
Old Apr 24, 2013 | 07:41 PM
  #110
KingBaby's Avatar
KingBaby
Hardest Setting
Looks worth it too me!
Awesome stuff!
Old Apr 24, 2013 | 07:44 PM
  #111
vex008's Avatar
vex008
what cams are you running kacz? kacz/2TH any heat issues inside car from the headers?
Old Apr 24, 2013 | 08:07 PM
  #112
kacz07's Avatar
kacz07
I have a revup engine and run the C8R cams.
I deleted my AC compressor and plan to do the condenser to reduce heat soak. I noticed the heat coming in through the vents before the compressor delete. Nothing I couldn't deal with, but def noticeably more ambient with it out.
Old Apr 25, 2013 | 03:33 AM
  #113
2TH PWR's Avatar
2TH PWR
Hope that works. Posting from my phone.
Jwt c9 c10. If you want to know about the motor read all the old posts by SGSash as he built it.
Old Apr 28, 2013 | 07:21 PM
  #114
jwttz's Avatar
jwttz
Sounds great! How high are you reving it and what engine management are you using?
Old Apr 28, 2013 | 10:26 PM
  #115
Frostydc4's Avatar
Frostydc4
These should fit the HR without any fitment issues right?
Old May 1, 2013 | 06:53 AM
  #116
Acidz's Avatar
Acidz
Fitment On HR..... I'm not sure, we haven't tested these on a HR. I would like to, but I would need a car....
Old May 1, 2013 | 11:31 AM
  #117
Frostydc4's Avatar
Frostydc4
I'm worried about the pipes hitting the steering shaft.
Old May 1, 2013 | 12:35 PM
  #118
KingBaby's Avatar
KingBaby
Hardest Setting
do it...
EDIT:
I think the only issue with Headers between DE/RevUp and HR was that it may hit the floorboard on the HR passenger side. No steering shaft issues with Z33s, G35s and G35 Sedans however are a tight fit when it comes to steering shaft clearance.
Old May 1, 2013 | 01:49 PM
  #119
2TH PWR's Avatar
2TH PWR
right now its limited to 6600 until i can get better injectors and fuel pump installed.
will rev to 8300.
Stock ECU tuned with UPREV.
Old May 1, 2013 | 03:02 PM
  #120
2004Black350z's Avatar
2004Black350z
Exhaust Whore
As posted on YouTube sounds wicked.brah
Dsowe
Feb 17, 2021 10:38 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
jelledge
Dec 31, 2002 07:58 AM
